U-Boot SPL 2021.04-lf_v2021.04+gd1528947bd (Sep 06 2021 - 08:48:23 +0000) pca9450_bind: 'pca9450@25' - found regulators subnode pmic_bind_children for 'pca9450@25' at node offset: 5064 Bound: 0 children for PMIC: 'pca9450@25' pca9450_bind: pca9450@25 - no child found pmic_reg_write: reg=c, value=29 priv->trans_len:1, ret=0 pmic_reg_write: reg=10, value=59 priv->trans_len:1, ret=0 pmic_reg_write: reg=1e, value=18 priv->trans_len:1, ret=0 pmic_reg_write: reg=8, value=a1 priv->trans_len:1, ret=0 DDRINFO: start DRAM init DDRINFO: cfg clk DDRINFO: DRAM rate 3200MTS DDRINFO: ddrc config start DDRINFO: ddrc config done DDRINFO:ddrphy config start DRAM PHY training for 3200MTS check ddr_pmu_train_imem code check ddr_pmu_train_imem code pass check ddr4_pmu_train_dmem code check ddr_pmu_train_dmem code pass [PMU Major message = 0x00000000] [PMU Major message = 0x00000002] [PMU Major message = 0x00000001] [PMU Major message = 0x0000000a] [PMU Major message = 0x000000fd] [PMU Major message = 0x000000fe] [PMU Major message = 0x00000004] [PMU Major message = 0x00000003] [PMU Major message = 0x00000009] [PMU Major message = 0x00000007] Training PASS DRAM PHY training for 3200MTS check ddr_pmu_train_imem code check ddr_pmu_train_imem code pass check ddr4_pmu_train_dmem code check ddr_pmu_train_dmem code pass [PMU Major message = 0x00000000] [PMU Major message = 0x00000006] [PMU Major message = 0x00000005] [PMU Major message = 0x00000007] Training PASS DDRINFO: ddrphy config done DDRINFO:ddrphy calibration done DDRINFO: ddrmix config done SEC0: RNG instantiated Normal Boot WDT: Not found! Trying to boot from BOOTROM image offset 0x8000, pagesize 0x200, ivt offset 0x0 Can't support legacy image SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### 与 EVK 上的运行图像相比,似乎找不到 BL31 图像: U-Boot SPL 2021.04-lf_v2021.04+g1c0116f3da (Sep 06 2021 - 08:48:23 +0000) DDRINFO: start DRAM init DDRINFO: DRAM rate 4000MTS DDRINFO:ddrphy calibration done DDRINFO: ddrmix config done SEC0: RNG instantiated Normal Boot WDT: Not found! Trying to boot from BOOTROM image offset 0x8000, pagesize 0x200, ivt offset 0x0 NOTICE: BL31: v2.4(release):lf-5.10.52-2.1.0-rc1-39-gbb4957067 NOTICE: BL31: Built : 04:45:39, Sep 8 2021 U-Boot 2021.04-lf_v2021.04+g1c0116f3da (Sep 06 2021 - 08:48:23 +0000) CPU: i.MX8MP[8] rev1.0 1800 MHz (running at 1200 MHz) CPU: Commercial temperature grade (0C to 95C) at 30C Reset cause: POR Model: NXP i.MX8MPlus LPDDR4 EVK board DRAM: 6 GiB 知道我们的定制设计中没有eMMC,只有 micro SD 卡可用,类似于 8MPLUSDR4-CPU 设计。 你能帮助指导我们走得更远吗? |
只有小组成员才能发言,加入小组>>
2135个成员聚集在这个小组
加入小组我的项目我做主,使用GN+Ninja来完成构建系统(VSCode开发RT106X)
37376 浏览 0 评论
NXP IMX8应用处理器快速入门必备:技巧、使用、设计指南
6775 浏览 1 评论
7793 浏览 1 评论
7642 浏览 0 评论
NXP i.MX6UL开发板(linux系统烧录+规格+硬件+模块移植)使用手册
5071 浏览 0 评论
1556浏览 2评论
关于NINA-W132 Wi-Fi模块SPI通信遇到的疑问求解
1207浏览 2评论
如何在MPC PowerPC MCU上首次刷写后禁用BDM?
749浏览 1评论
将HFREFR和LFREFR寄存器值设置为错误的值来将故障注入CMU,但CMU_ISR值始终为零,为什么?
735浏览 1评论
将SPSDK for FRDM-MCX-W71 SDK与VS一起安装时出现hidapi构建错误怎么解决?
678浏览 1评论
/9
GMT+8, 2025-12-1 23:57 , Processed in 0.569610 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
565
