电子发烧友论坛|
错误代码:
Executing action: menuconfig Running cmake in directory /home/esp/esp/station/build Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32 -DCCACHE_ENABLE=0 /home/esp/esp/station"... -- Found Git: /usr/bin/git (found version "2.30.2") -- The C compiler identification is GNU 8.4.0 -- The CXX compiler identification is GNU 8.4.0 -- The ASM compiler identification is GNU -- Found assembler: /home/esp/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: /home/esp/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: /home/esp/.espressif/tools/xtensa-esp32-elf/esp-2020r3-8.4.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++ - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER. -- Building ESP-IDF components for target esp32 Cannot parse CMake requirements line: __component_set_property(___idf_LinkSDK REQUIRES "mbedtls;cxx;newlib;freertos;esp_hw_support;heap;log;lwip;soc;hal;esp_rom;esp_common;esp_system;esp32") CMake Error at /home/esp/esp/esp-idf/tools/cmake/component.cmake:243 (message): Call Stack (most recent call first): /home/esp/esp/esp-idf/tools/cmake/build.cmake:487 (__component_get_requirements) /home/esp/esp/esp-idf/tools/cmake/project.cmake:361 (idf_build_process) CMakeLists.txt:6 (project) -- Configuring incomplete, errors occurred! See also "/home/esp/esp/station/build/CMakeFiles/CMakeOutput.log". cmake failed with exit code 1 LinkSDK的CMakeLists.txt 9 idf_component_register(SRCS "core/*.c" 8 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ "core/utils/*.c" 7 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ "core/sysdep/*.c" 6 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ "portfiles/aiot_port/*.c" 5 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ "external/*.c" 4 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊INCLUDE_DIRS core 3 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊INCLUDE_DIRS core/sysdep 2 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊INCLUDE_DIRS core/utils 1 ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊ ┊REQUIRES mbedtls) 10 tree . ├── ChangeLog.md ├── CMakeLists.txt ├── components │ ├── bootstrap │ │ ├── aiot_bootstrap_api.c │ │ ├── aiot_bootstrap_api.h │ │ ├── bootstrap_private.h │ │ └── README.md │ ├── data-model │ │ ├── aiot_dm_api.c │ │ ├── aiot_dm_api.h │ │ ├── dm_private.h │ │ └── README.md │ ├── devinfo │ │ ├── aiot_devinfo_api.c │ │ ├── aiot_devinfo_api.h │ │ ├── devinfo_private.h │ │ └── README.md │ ├── diag │ │ ├── aiot_diag_api.c │ │ ├── aiot_diag_api.h │ │ ├── diag_private.h │ │ └── README.md │ ├── logpost │ │ ├── aiot_logpost_api.c │ │ ├── aiot_logpost_api.h │ │ ├── logpost_private.h │ │ └── README.md │ ├── ntp │ │ ├── aiot_ntp_api.c │ │ ├── aiot_ntp_api.h │ │ ├── ntp_private.h │ │ └── README.md │ ├── ota │ │ ├── aiot_ota_api.c │ │ ├── aiot_ota_api.h │ │ ├── ota_md5.c │ │ ├── ota_md5.h │ │ ├── ota_private.h │ │ └── README.md │ ├── remote-access │ │ ├── aiot_ra_api.c │ │ ├── aiot_ra_api.h │ │ ├── aiot_ra_private.h │ │ ├── COPYING │ │ ├── NOTICE │ │ └── src │ │ ├── nopoll │ │ │ ├── include │ │ │ │ ├── nopoll_config.h │ │ │ │ ├── nopoll_conn.h │ │ │ │ ├── nopoll_conn_opts.h │ │ │ │ ├── nopoll_ctx.h │ │ │ │ ├── nopoll_decl.h │ │ │ │ ├── nopoll.h │ │ │ │ ├── nopoll_handlers.h │ │ │ │ ├── nopoll_log.h │ │ │ │ ├── nopoll_msg.h │ │ │ │ └── nopoll_private.h │ │ │ ├── library │ │ │ │ ├── nopoll.c │ │ │ │ ├── nopoll_conn.c │ │ │ │ ├── nopoll_conn_opts.c │ │ │ │ ├── nopoll_ctx.c │ │ │ │ ├── nopoll_decl.c │ │ │ │ ├── nopoll_log.c │ │ │ │ └── nopoll_msg.c │ │ │ └── makefile │ │ ├── ra_buffer_mgr.c │ │ ├── ra_buffer_mgr.h │ │ ├── ra_proxy_channel.c │ │ ├── ra_proxy_channel.h │ │ ├── ra_proxy_protocol.c │ │ ├── ra_proxy_protocol.h │ │ ├── ra_proxy_thread.c │ │ ├── ra_proxy_thread.h │ │ ├── ra_proxy_trans.c │ │ ├── ra_proxy_trans.h │ │ ├── ra_session_mgr.c │ │ └── ra_session_mgr.h │ ├── shadow │ │ ├── aiot_shadow_api.c │ │ ├── aiot_shadow_api.h │ │ ├── README.md │ │ └── shadow_private.h │ ├── subdev │ │ ├── aiot_subdev_api.c │ │ ├── aiot_subdev_api.h │ │ ├── cJSON.c │ │ ├── cJSON.h │ │ ├── README.md │ │ └── subdev_private.h │ └── task │ ├── aiot_task_api.c │ ├── aiot_task_api.h │ ├── README.md │ └── task_private.h ├── core │ ├── aiot_http_api.h │ ├── aiot_mqtt_api.c │ ├── aiot_mqtt_api.h │ ├── aiot_state_api.c │ ├── aiot_state_api.h │ ├── aiot_sysdep_api.h │ ├── README.md │ ├── sysdep │ │ ├── core_adapter.c │ │ ├── core_adapter.h │ │ ├── core_stdinc.h │ │ ├── core_sysdep.c │ │ └── core_sysdep.h │ └── utils │ ├── core_auth.c │ ├── core_auth.h │ ├── core_diag.c │ ├── core_diag.h │ ├── core_global.c │ ├── core_global.h │ ├── core_http.c │ ├── core_http.h │ ├── core_list.h │ ├── core_log.c │ ├── core_log.h │ ├── core_mqtt.h │ ├── core_sha256.c │ ├── core_sha256.h │ ├── core_string.c │ └── core_string.h ├── external │ ├── ali_ca_cert.c │ ├── mbedtls │ │ ├── include │ │ │ └── mbedtls │ │ │ ├── aes.h │ │ │ ├── asn1.h │ │ │ ├── base64.h │ │ │ ├── bignum.h │ │ │ ├── bn_mul.h │ │ │ ├── check_config.h │ │ │ ├── cipher.h │ │ │ ├── cipher_internal.h │ │ │ ├── config.h │ │ │ ├── ctr_drbg.h │ │ │ ├── debug.h │ │ │ ├── des.h │ │ │ ├── ecp.h │ │ │ ├── entropy.h │ │ │ ├── entropy_poll.h │ │ │ ├── error.h │ │ │ ├── md5.h │ │ │ ├── md.h │ │ │ ├── md_internal.h │ │ │ ├── net.h │ │ │ ├── net_sockets.h │ │ │ ├── oid.h │ │ │ ├── pem.h │ │ │ ├── pk.h │ │ │ ├── pk_internal.h │ │ │ ├── platform.h │ │ │ ├── rsa.h │ │ │ ├── sha1.h │ │ │ ├── sha256.h │ │ │ ├── ssl_ciphersuites.h │ │ │ ├── ssl_cookie.h │ │ │ ├── ssl.h │ │ │ ├── ssl_internal.h │ │ │ ├── timing.h │ │ │ ├── x509_crl.h │ │ │ ├── x509_crt.h │ │ │ └── x509.h │ │ └── library │ │ ├── aes.c │ │ ├── asn1parse.c │ │ ├── base64.c │ │ ├── bignum.c │ │ ├── cipher.c │ │ ├── cipher_wrap.c │ │ ├── ctr_drbg.c │ │ ├── debug.c │ │ ├── entropy.c │ │ ├── entropy_poll.c │ │ ├── error.c │ │ ├── md.c │ │ ├── md_wrap.c │ │ ├── net_sockets.c │ │ ├── oid.c │ │ ├── pem.c │ │ ├── pk.c │ │ ├── pkparse.c │ │ ├── pk_wrap.c │ │ ├── platform.c │ │ ├── rsa.c │ │ ├── sha1.c │ │ ├── sha256.c │ │ ├── ssl_ciphersuites.c │ │ ├── ssl_cli.c │ │ ├── ssl_cookie.c │ │ ├── ssl_tls.c │ │ ├── timing.c │ │ ├── x509.c │ │ └── x509_crt.c │ └── README.md ├── Makefile └── portfiles ├── aiot_port │ ├── posix_port.c │ └── posix_port.c(8266) └── README.md |
只有小组成员才能发言,加入小组>>
471 浏览 0 评论
994 浏览 0 评论
1710 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1370 浏览 1 评论
1256 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1289浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2387浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2577浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-14 14:59 , Processed in 0.597510 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
592
