电子发烧友论坛|
发了两个问题,一直都没有看到厂家的技术支持有回复,只好把原来的MDF都删除,然后git了一个最新的esp-mdf,demo总算编译通过了,但是有出现了make flash的问题,把python改成3.6了,sudo chmod 777 /dev/ttyUSB0也试过了,在python 控制台状态下能open这个USB转串口(CP系列),并且能接受到串口数据,但make flash后就出现以下错误:
App "eth2ap" version: 1 Flashing binaries to serial port '/dev/ttyUSB0' (app at offset 0x10000)... esptool.py v3.0-dev Serial port "/dev/ttyUSB0" Traceback (most recent call last): File "/home/willen/.local/lib/python3.6/site-packages/serial/serialposix.py", line 291, in open self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK) FileNotFoundError: [Errno 2] No such file or directory: '"/dev/ttyUSB0"' During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/home/willen/esp/esp-mdf/esp-idf/components/esptool_py/esptool/esptool.py", line 3430, in _main() File "/home/willen/esp/esp-mdf/esp-idf/components/esptool_py/esptool/esptool.py", line 3423, in _main main() File "/home/willen/esp/esp-mdf/esp-idf/components/esptool_py/esptool/esptool.py", line 3087, in main esp = chip_class(each_port, initial_baud, args.trace) File "/home/willen/esp/esp-mdf/esp-idf/components/esptool_py/esptool/esptool.py", line 261, in __init__ self._port = serial.serial_for_url(port) File "/home/willen/.local/lib/python3.6/site-packages/serial/__init__.py", line 85, in serial_for_url instance.open() File "/home/willen/.local/lib/python3.6/site-packages/serial/serialposix.py", line 294, in open raise SerialException(msg.errno, "could not open port %s: %s" % (self._port, msg)) serial.serialutil.SerialException: [Errno 2] could not open port "/dev/ttyUSB0": [Errno 2] No such file or directory: '"/dev/ttyUSB0"' /home/willen/esp/esp-mdf/esp-idf/components/esptool_py/Makefile.projbuild:104: recipe for target 'flash' failed |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2333浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 00:31 , Processed in 0.758091 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
380
