模块esp32-wrover-e + es8388S 开发voip对讲,播放声音很好声音清晰没有噪音,
没有说话的时候背景噪音比较大。 但是话筒人说话时距离话筒近一点,声音大一点说话没问题还是比较清晰的,距离远一点声音一下就很小了,不是按距离衰减的。 请问这个芯片录音部分有哪些参数 可以音量增大。灵敏度高一点。 esp_err_t es8388_init(audio_hal_codec_config_t *cfg) { int res = 0; #ifdef CONFIG_ESP_LYRAT_V4_3_BOARD // headphone_detect_init(get_headphone_detect_gpio()); #endif res = i2c_init(); // ESP32 in master mode res |= es_write_reg(ES8388_ADDR, ES8388_DACCONTROL3, 0x04); // 0x04 mute/0x00 unmute&ramp;DAC unmute and disabled digital volume control soft ramp /* Chip Control and Power Management */ // res |= es_write_reg(ES8388_ADDR, ES8388_CONTROL2, 0x50); res |= es_write_reg(ES8388_ADDR, ES8388_CONTROL2, 0x00); res |= es_write_reg(ES8388_ADDR, ES8388_CHIPPOWER, 0x00); //normal all and power up all // Disable the internal DLL to improve 8K sample rate res |= es_write_reg(ES8388_ADDR, 0x35, 0xA0); res |= es_write_reg(ES8388_ADDR, 0x37, 0xD0); res |= es_write_reg(ES8388_ADDR, 0x39, 0xD0); res |= es_write_reg(ES8388_ADDR, ES8388_MASTERMODE, cfg->i2s_iface.mode); //CODEC IN I2S SLAVE MODE /* dac */ res |= es_write_reg(ES8388_ADDR, ES8388_DACPOWER, 0xC0); //disable DAC and disable Lout/Rout/1/2 #ifdef ES8388S res |= es_write_reg(ES8388_ADDR, ES8388_CONTROL1, 0x06); //1001 0010 Enfr=0,Play&Record Mode,(0x17-both of mic&paly) #else res |= es_write_reg(ES8388_ADDR, ES8388_CONTROL1, 0x12); //Enfr=0,Play&Record Mode,(0x17-both of mic&paly) #endif // res |= es_write_reg(ES8388_ADDR, ES8388_CONTROL2, 0); //LPVrefBuf=0,Pdn_ana=0 res |= es_write_reg(ES8388_ADDR, ES8388_DACCONTROL1, 0x18);//1a 0x18:16bit iis , 0x00:24 #ifdef ES8388S res |= es_write_reg(ES8388_ADDR, ES8388_DACCONTROL2, 0x44); //DACFsMode,SINGLE SPEED; DACFsRatio,512 #else res |= es_write_reg(ES8388_ADDR, ES8388_DACCONTROL2, 0x02); //DACFsMode,SINGLE SPEED; DACFsRatio,512 #endif res |= es_write_reg(ES8388_ADDR, ES8388_DACCONTROL16, 0x00); // 0x00 audio on LIN1&RIN1, 0x09 LIN2&RIN2 res |= es_write_reg(ES8388_ADDR, ES8388_DACCONTROL17, 0x90); // only left DAC to left mixer enable 0db res |= es_write_reg(ES8388_ADDR, ES8388_DACCONTROL20, 0x90); // only right DAC to right mixer enable 0db res |= es_write_reg(ES8388_ADDR, ES8388_DACCONTROL21, 0x80); //set internal ADC and DAC use the same LRCK clock, ADC LRCK as internal LRCK res |= es_write_reg(ES8388_ADDR, ES8388_DACCONTROL23, 0x00); //vroi=0 res |= es8388_set_adc_dac_volume(ES_MODULE_DAC, 0, 0); // 0db int tmp = 0; if (AUDIO_HAL_DAC_OUTPUT_LINE2 == cfg->dac_output) { tmp = DAC_OUTPUT_LOUT1 | DAC_OUTPUT_ROUT1; } else if (AUDIO_HAL_DAC_OUTPUT_LINE1 == cfg->dac_output) { tmp = DAC_OUTPUT_LOUT2 | DAC_OUTPUT_ROUT2; } else { tmp = DAC_OUTPUT_LOUT1 | DAC_OUTPUT_LOUT2 | DAC_OUTPUT_ROUT1 | DAC_OUTPUT_ROUT2; } res |= es_write_reg(ES8388_ADDR, ES8388_DACPOWER, tmp); //0x3c Enable DAC and Enable Lout/Rout/1/2 /* adc */ res |= es_write_reg(ES8388_ADDR, ES8388_ADCPOWER, 0xFF); tmp = 0; if (AUDIO_HAL_ADC_INPUT_LINE1 == cfg->adc_input) { tmp = ADC_INPUT_LINPUT1_RINPUT1; } else if (AUDIO_HAL_ADC_INPUT_LINE2 == cfg->adc_input) { tmp = ADC_INPUT_LINPUT2_RINPUT2; } else { tmp = ADC_INPUT_DIFFERENCE; } //ALC for Microphone #ifdef ES8388S res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL1, 0x80); // MIC Left and Right channel PGA gain res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL2, 0xc1); //0x00 LINSEL & RINSEL, LIN1/RIN1 as ADC Input; DSSEL,use one DS Reg11; DSR, LINPUT1-RINPUT1 res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL3, 0x02); //I2S res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL4, 0x0d); // Left/Right data, Left/Right justified mode, Bits length, I2S format res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL5, 0x44); //ADCFsMode,singel SPEED,RATIO=512 res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL6, 0x20); //0010 1100 enable high pass rate , max gain 11, min gain 00 res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL10, 0xfC); //1111 1000 alc on max gain PGA 111 min gain PGA 100 12DB //res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL11, 0xB5); //1011 0101 //res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL11, 0x51); //0101 0001 -50dbfs pga gain NOISE GATE enable res |= es8388_set_adc_dac_volume(ES_MODULE_ADC, 0, 0); // 0db res |= es_write_reg(ES8388_ADDR, ES8388_ADCPOWER, 0); //Power on ADC, Enable ALL //LIN&RIN, Power off MICBIAS, set int1lp to low power mode #else res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL1, 0x88); // MIC Left and Right channel PGA gain res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL2, tmp); //0x00 LINSEL & RINSEL, LIN1/RIN1 as ADC Input; DSSEL,use one DS Reg11; DSR, LINPUT1-RINPUT1 res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL3, 0x02); //I2S res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL4, 0x0d); // Left/Right data, Left/Right justified mode, Bits length, I2S format res |= es_write_reg(ES8388_ADDR, ES8388_ADCCONTROL5, 0x02); //ADCFsMode,singel SPEED,RATIO=128 res |= es8388_set_adc_dac_volume(ES_MODULE_ADC, 0, 0); // 0db res |= es_write_reg(ES8388_ADDR, ES8388_ADCPOWER, 0x09); //Power on ADC, Enable ALL //LIN&RIN, Power off MICBIAS, set int1lp to low power mode #endif /* enable es8388 PA */ // es8388_pa_power(true); //自己主板需要屏蔽的 ESP_LOGI(ES_TAG, "init,out:%02x, in:%02x", cfg->dac_output, cfg->adc_input); return res; } |
只有小组成员才能发言,加入小组>>
1138 浏览 1 评论
576浏览 6评论
477浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
461浏览 5评论
462浏览 4评论
435浏览 4评论
GMT+8, 2024-12-22 13:17 , Processed in 0.818296 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
