电子发烧友论坛|
使用方式如下:
链接脚本: ... . = ALIGN(4); user_section_tab_local_start = ABSOLUTE(.); KEEP (*(SORT(*user_section_tab*))) user_section_tab_local_end = ABSOLUTE(.); ... a.h: Code: Select all #define USER_SECTION_NAME __attribute__((section("user_section_name_tab"))) #define USER_SECTION __attribute__((section("user_section_tab"))) extern void *user_section_tab_local_start; extern void *user_section_tab_local_end; const static uint32_t user_section_tab_local_start_addr = (uint32_t)&user_section_tab_local_start; const static uint32_t user_section_tab_local_end_addr = (uint32_t)&user_section_tab_local_end; b.h: Code: Select all typedef int (*user_func_t)(void *); struct user_cmd_object { user_func_t func; const char *breif; uint32_t *const param; }; #define USER_CMD_EXPORT(name, f, c, p) uint32_t _USER_CMD_##name##_param = (uint32_t)p; const char _USER_CMD_##name##_name[] SECTION_A_NAME = #c; __attribute__((used)) const struct user_cmd_object _USER_CMD_##name##_obj USER_SECTION = { .func = f, .breif = _USER_CMD_##name##_name, .param = &_USER_CMD_##name##_param } b.c: Code: Select all #include "b.h" //at+version static int func_version(void *param) { printf("%srn", "V1.0.0"); return 0; } USER_CMD_EXPORT(VERSION, func_version, AT+VERSION, 0); //at+uid static int func_uid(void *param) { printf("%08xrn", u_devid_get()); return 0; } USER_CMD_EXPORT(UID, func_uid, AT+UID, 0); 编译后得到的map文件: Code: Select all 0x000000003c029614 . = ALIGN (0x4) 0x000000003c029614 user_section_tab_local_start = ABSOLUTE (.) *(SORT_BY_NAME(*user_section_tab*)) 0x000000003c029614 user_section_tab_local_end = ABSOLUTE (.) 问题是编译之后user_section_tab段里的内容是空的,请问这个问题怎么处理呢? |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2333浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 23:59 , Processed in 0.731225 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
434
