之前为解决wifi重启出现pll_cap_ext 10的问题,更新了IDF版本,看github上有5.0,更新后发现wifi-provisioning有问题,于是再更新5.1,也还是同样的问题。
使用esp-idfexamplesprovisioningwifi_prov_mgr这个例程,配网失败。 menuconfig 里面相关配置如下 # Example Configuration # CONFIG_EXAMPLE_PROV_TRANSPORT_BLE=y # CONFIG_EXAMPLE_PROV_TRANSPORT_SOFTAP is not set # CONFIG_EXAMPLE_PROV_SECURITY_VERSION_1 is not set CONFIG_EXAMPLE_PROV_SECURITY_VERSION_2=y CONFIG_EXAMPLE_PROV_SEC2_DEV_MODE=y # CONFIG_EXAMPLE_PROV_SEC2_PROD_MODE is not set CONFIG_EXAMPLE_PROV_TRANSPORT=1 CONFIG_EXAMPLE_RESET_PROVISIONED=y CONFIG_EXAMPLE_RESET_PROV_MGR_ON_FAILURE=y CONFIG_EXAMPLE_PROV_MGR_MAX_RETRY_CNT=5 # CONFIG_EXAMPLE_PROV_SHOW_QR is not set # CONFIG_EXAMPLE_REPROVISIONING is not set # end of Example Configuration # Wi-Fi Provisioning Manager # CONFIG_WIFI_PROV_SCAN_MAX_ENTRIES=16 CONFIG_WIFI_PROV_AUTOSTOP_TIMEOUT=30 CONFIG_WIFI_PROV_BLE_BONDING=y CONFIG_WIFI_PROV_BLE_SEC_CONN=y CONFIG_WIFI_PROV_BLE_FORCE_ENCRYPTION=y # CONFIG_WIFI_PROV_KEEP_BLE_ON_AFTER_PROV is not set # end of Wi-Fi Provisioning Manager 打印日志如下 I (623) wifi_prov_scheme_ble: BT memory released I (643) app: Starting provisioning I (653) BT_INIT: BT controller compile version [76c24c9] I (653) phy_init: phy_version 503,13653eb,Jun 1 2022,17:47:08 I (693) BT_INIT: Bluetooth MAC: f4:12:fa:e0:b5:c2 I (693) protocomm_nimble: BLE Host Task Started I (703) NimBLE: GAP procedure initiated: stop advertising. I (703) NimBLE: GAP procedure initiated: advertise; I (703) NimBLE: disc_mode=2 I (713) NimBLE: adv_channel_map=0 own_addr_type=0 adv_filter_policy=0 adv_itvl_min=256 adv_itvl_max=256 I (723) NimBLE: I (723) wifi_prov_mgr: Provisioning started with service name : PROV_E0B5C0 I (733) app: Provisioning started I (733) app: If QR code is not visible, copy paste the below URL in a browser. https://espressif.github.io/esp-jumpstart/qrcode.html?data={"ver":"v1","name":"PROV_E0B5C0","pop":"abcd1234","transport":"ble"} I (19083) app: BLE transport: Connected! I (19243) protocomm_nimble: mtu update event; conn_handle=1 cid=4 mtu=185 I (23113) NimBLE: GAP procedure initiated: stop advertising. I (25573) NimBLE: GAP procedure initiated: advertise; I (25573) NimBLE: disc_mode=2 I (25573) NimBLE: adv_channel_map=0 own_addr_type=0 adv_filter_policy=0 adv_itvl_min=256 adv_itvl_max=256 I (25583) NimBLE: I (25583) app: BLE transport: Disconnected! I (25593) app: BLE transport: Disconnected! I (25753) app: BLE transport: Connected! I (26113) protocomm_nimble: mtu update event; conn_handle=1 cid=4 mtu=185 E (27013) security1: Key mismatch. Close connection E (27013) security1: Session setup error -1 E (27013) protocomm_nimble: Invalid content received, killing connection 手机上面提示是 Sending Wi-Fi credentials. Failed to initialise session with the device |
只有小组成员才能发言,加入小组>>
462 浏览 0 评论
982 浏览 0 评论
1703 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1359 浏览 1 评论
1249 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1274浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
942浏览 3评论
2372浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2560浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1067浏览 2评论
/9
GMT+8, 2025-12-10 18:48 , Processed in 0.845605 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
508
