1. 使用ESP32-S3 ADC2 CH7(GPIO18),读取校准后的电压偏低。实际是2V左右,log打印只有1.8V多。没有打开wifi,请问可能是什么问题?
2. 另外如果直接计算adc_raw/4095*Vref,这个Vref是多少 Code: Select all I (100531) bat_adc: adc_raw= 2238 cali_data= 1803mV I (102531) bat_adc: adc_raw= 2238 cali_data= 1803mV I (104531) bat_adc: adc_raw= 2236 cali_data= 1800mV I (106531) bat_adc: adc_raw= 2236 cali_data= 1800mV I (108531) bat_adc: adc_raw= 2238 cali_data= 1803mV I (110531) bat_adc: adc_raw= 2237 cali_data= 1802mV I (112531) bat_adc: adc_raw= 2237 cali_data= 1802mV I (114531) bat_adc: adc_raw= 2237 cali_data= 1802mV I (116531) bat_adc: adc_raw= 2237 cali_data= 1802mV I (118531) bat_adc: adc_raw= 2237 cali_data= 1802mV I (120531) bat_adc: adc_raw= 2235 cali_data= 1800mV I (122531) bat_adc: adc_raw= 2239 cali_data= 1803mV 附上ADC2读取函数: Code: Select all //ADC Channels #define ADC_EXAMPLE_CHAN0 ADC2_CHANNEL_7 // GPIO18 //ADC Attenuation #define ADC_EXAMPLE_ATTEN ADC_ATTEN_DB_11 //ADC Calibration #if CONFIG_IDF_TARGET_ESP32 #define ADC_EXAMPLE_CALI_SCHEME ESP_ADC_CAL_VAL_EFUSE_VREF #elif CONFIG_IDF_TARGET_ESP32S2 #define ADC_EXAMPLE_CALI_SCHEME ESP_ADC_CAL_VAL_EFUSE_TP #elif CONFIG_IDF_TARGET_ESP32C3 #define ADC_EXAMPLE_CALI_SCHEME ESP_ADC_CAL_VAL_EFUSE_TP #elif CONFIG_IDF_TARGET_ESP32S3 #define ADC_EXAMPLE_CALI_SCHEME ESP_ADC_CAL_VAL_EFUSE_TP_FIT #endif static esp_adc_cal_characteristics_t adc_chars; static bool adc_calibration_init(void) { esp_err_t ret; bool cali_enable = false; ret = esp_adc_cal_check_efuse(ADC_EXAMPLE_CALI_SCHEME); if (ret == ESP_ERR_NOT_SUPPORTED) { ESP_LOGW(TAG, "Calibration scheme not supported, skip software calibration"); } else if (ret == ESP_ERR_INVALID_VERSION) { ESP_LOGW(TAG, "eFuse not burnt, skip software calibration"); } else if (ret == ESP_OK) { cali_enable = true; esp_adc_cal_characterize(ADC_UNIT_2, ADC_EXAMPLE_ATTEN, ADC_WIDTH_BIT_DEFAULT, 0, &adc_chars); } else { ESP_LOGE(TAG, "Invalid arg"); } return cali_enable; } esp_err_t adc_init(void) { bool cali_enable = adc_calibration_init(); if (true != cali_enable) { ESP_LOGI(TAG, "adc init fail!!!"); return ESP_FAIL; } //ADC2 config ESP_ERROR_CHECK(adc2_config_channel_atten(ADC_EXAMPLE_CHAN0, ADC_EXAMPLE_ATTEN)); ESP_LOGI(TAG, "adc init ok"); return ESP_OK; } uint16_t adc_get_voltage(void) { uint16_t adc_raw; uint16_t voltage = 0; adc2_get_raw(ADC_EXAMPLE_CHAN0, ADC_WIDTH_BIT_DEFAULT, &adc_raw); voltage = esp_adc_cal_raw_to_voltage(adc_raw, &adc_chars); ESP_LOGI(TAG, "adc_raw= %d cali_data= %dmV", adc_raw, voltage); return voltage; } |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1250浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2330浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 21:48 , Processed in 0.692459 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
533
