我做了一块自己的板子,用的是esp32 Wroom 32UE 和SR8201F 以太网芯片,一开始eth2sta跑得很好,我的PC通过板子可以上网,但是过了1分钟或者5分钟后,会突然不断重启,然后 电源会被急剧拉低,请问一下有人知道为什么吗?代码log在下方:
[14:44:15:805]Rx←⦁ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:6624
load:0x40078000,len:147
[14:44:15:853]Rx←⦁80
load:0x40080400,len:3792
entry 0x40080694
[0;32mI (27) boot: ESP-IDF v4.4-dirty 2nd stage bootloader[0m
[0;32mI (27) boot: compile time 19:47:35[0m
[0;32mI (27) boot: chip revision: 3[0m
[0;32mI (30) boot_comm: chip revision: 3, min. bootloader chip revision: 0[0m
[0;32mI (38) boot.esp32: SPI Speed : 40MHz[0m
[0;32mI (42) boot.esp32: SPI Mode : DIO[0m
[0;32mI (47) boot.esp32: SPI Flash Size : 4MB[0m
[0;32mI (51) boot: Enabling RNG early entropy source...[0m
[0;32mI (57) boot: Parti
[14:44:15:896]Rx←⦁tion Table:[0m
[0;32mI (60) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (68) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m
[0;32mI (75) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (82) boot: 2 factory factory app 00 00 00010000 00100000[0m
[0;32mI (90) boot: End of partition table[0m
[0;32mI (94) boot_comm: chip revision: 3, min. application chip revision
[14:44:15:940]Rx←⦁: 0[0m
[0;32mI (101) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=17e50h ( 97872) map[0m
[0;32mI (145) esp_image: segment 1: paddr=00027e78 vaddr=3ffb0000 size=03838h ( 14392) load[0m
[0;32mI (151) esp_image: segm
[14:44:15:984]Rx←⦁ent 2: paddr=0002b6b8 vaddr=40080000 size=04960h ( 18784) load[0m
[0;32mI (159) esp_image: segment 3: paddr=00030020 vaddr=400d0020 size=74dech (478700) map[0m
[14:44:16:138]Rx←⦁[0;32mI (333) esp_image: segment 4: paddr=000a4e14 vaddr=40084960 size=109d8h ( 68056) load[0m
[14:44:16:186]Rx←⦁[0;32mI (361) esp_image: segment 5: paddr=000b57f4 vaddr=50000000 size=00010h ( 16) load[0m
[0;32mI (372) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (372) boot: Disabling RNG early entropy source...[0m
[0;32mI (383) cpu_start: Pro cpu up.[0m
[0;32mI (384) cpu_start: Starting app cpu, entry point is 0x40081278[0m
[0;32mI (0) cpu_start: App cpu up.[0m
[0;32mI (398) cpu_start: Pro cp
[14:44:16:226]Rx←⦁u start user code[0m
[0;32mI (398) cpu_start: cpu freq: 160000000[0m
[0;32mI (398) cpu_start: Application information:[0m
[0;32mI (402) cpu_start: Project name: eth2ap[0m
[0;32mI (407) cpu_start: App version: ec93f4e-dirty[0m
[0;32mI (412) cpu_start: Compile time: Jul 13 2022 19:46:26[0m
[0;32mI (419) cpu_start: ELF file SHA256: c5db9b0097c80e54...[0m
[0;32mI (425) cpu_start: ESP-IDF: v4.4-dirty[0m
[14:44:16:272]Rx←⦁[0;32mI (430) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (437) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM[0m
[0;32mI (443) heap_init: At 3FFB74D8 len 00028B28 (162 KiB): DRAM[0m
[0;32mI (449) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM[0m
[0;32mI (456) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m
[0;32mI (462) heap_init: At 40095338 len 0000ACC8 (43 KiB): IRAM[0m
[0;32mI (470) spi_flash: detected chip: generic[0m
[0;32mI (473) spi_flash: flash io: dio[0m
[14:44:16:313]Rx←⦁0;33mW (477) spi_flash: Detected size(8192k) larger than the size in the binary image header(4096k). Using the size in the binary image header.[0m
[0;32mI (491) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m
[14:44:16:353]Rx←⦁[0;32mI (560) ua[0;32mI (560) system_api: Base MAC address is not set[0m
[0;32mI (570) system_api: read default base MAC address from EFUSE[0m
[0;31mE (570) rtl8201: Before Write bmcr.power_down is 0[0m
[0;31mE (570) rtl8201: After Write bmcr.power_down is 0[0m
[0;31mE (580) rtl8201: H2 bmcr.power_down is 0[0m
[0;31mE (580) rtl8201: During waiting num 0 bmcr.power_down is 0[0m
[0;31mE (600) rt
[14:44:16:394]Rx←⦁l8201: During waiting num 0 bmcr.power_down is 0[0m
[0;31mE (600) rtl8201: During waiting num 0 bmcr.power_down is 0[0m
[14:44:17:991]Rx←⦁[0;32mI (2220) eth2sta: Ethernet Started[0m
[0;32mI (2220) eth2sta: Ethernet Link Up[0m
[0;32mI (2220) eth2sta: Ethernet s_eth_mac Addr 24:4cd2:be:4f[0m
[0;32mI (2220) eth2sta: ETHERNET_EVENT_CONNECTED DONE
[0m
I (2240) wifi:wifi driver t
[14:44:18:042]Rx←⦁ask: 3ffc6240, prio:23, stack:6656, core=0
I (2250) wifi:wifi firmware version: 7679c42
I (2250) wifi:wifi certification version: v7.0
I (2250) wifi:config NVS flash: enabled
I (2250) wifi:config nano formating: disabled
I (2260) wifi:Init data frame dynamic rx buffer num: 32
I (2260) wifi:Init management frame dynamic rx buffer num: 32
I (2270) wifi:Init management short buffer num: 32
I (2270) wifi:Init dynamic tx buffer num: 32
I (2270) wifi:Init static rx buffer size: 1600
[14:44:18:088]Rx←⦁I (2280) wifi:Init static rx buffer num: 10
I (2280) wifi:Init dynamic rx buffer num: 32
[0;32mI (2290) wifi_init: rx ba win: 6[0m
[0;32mI (2290) wifi_init: tcpip mbox: 32[0m
[0;32mI (2290) wifi_init: udp mbox: 6[0m
[0;32mI (2300) wifi_init: tcp mbox: 6[0m
[0;32mI (2300) wifi_init: tcp tx win: 5744[0m
[0;32mI (2310) wifi_init: tcp rx win: 5744[0m
[0;32mI (2310) wifi_init: tcp mss: 1440[0m
[0;32mI (2310) wifi_init: WiFi IRAM OP enabled[0m
[0;32mI (2320) wifi_init: WiFi RX IRAM OP e
[14:44:18:130]Rx←⦁nabled[0m
[0;32mI (2330) eth2sta: wifi_init_sta finished.[0m
[14:44:18:296]Rx←⦁[0;32mI (2520) eth2sta: Ethernet s_eth_mac Addr REPLACE TIME 00:0e:c6:78:f1:02[0m
[0;32mI (2520) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07[0m
[14:44:18:398]Rx←⦁I (2620) wifi:mode : sta (24:4cd2:be:4c)
I (2620) wifi:enable tsf
[0;32mI (2630) eth2sta: WIFI_EVENT_STA_START
[0m
[0m
E (2630) wifi:sta is connecting, return error
I (
[14:44:18:446]Rx←⦁2640) wifi<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1
I (2640) wifi:state: init -> auth (b0)
I (2650) wifi:state: auth -> assoc (0)
I (2690) wifi:state: assoc -> ru
[14:44:18:492]Rx←⦁n (10)
I (2730) wifi:connected with fpoap, aid = 3, channel 6, BW20, bssid = 62:55b3:9b:09
I (2730
[14:44:18:528]Rx←⦁) wifi:security: WPA2-PSK, phy: bgn, rssi: -44
I (2730) wifi:pm start, type: 1
[0;32mI (2740) eth2sta: WIFI_EVENT_STA_CONNECTED
[0m
[0;32mI (2740) eth2sta: AP 62:55b3:9b:09 HAS CONNECTED[0m
[0;32mI (2740) eth2sta: connected to ap SSID:fpoap password:jjjkkk05[0m
W (2760) wifi:idx:0 (ifx:0, 62:55b3:9b:09), tid:0, ssn:0, winSize:64
[14:44:18:597]Rx←⦁I (2820) wifi:AP's beacon interval = 102400 us, DTIM period = 2
[14:44:19:807]Rx←⦁W (4030) wifi:idx:1 (ifx:0, 62:55b3:9b:09), tid:6, ssn:2, winSize:64
[14:44:21:881]Rx←⦁[0;31mE (6100) esp.emac: emac_esp32_transmit(235): insufficient TX buffer size[0m
[0;31mE (6100) eth2sta: Ethernet send packet failed[0m
[14:44:26:411]Rx←⦁[0;31mE (10630) esp.emac: emac_esp32_transmit(235): insufficient TX buffer size[0m
[0;31mE (10630) eth2sta: Ethernet send packet failed[0m
[14:49:21:084]Rx←⦁
褧嵮缴亀as triggered
Brownout detector was triggered
[0;31mE (10630) eth2sta: ets Jul 29 2019 12:21:46
rst:
[14:49:21:149]Rx←⦁0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
load:0x40078000,len:14780
entry 0x40080694
[0;32mI (57) boot: Partition Table:[0m
[14:49:21:202]Rx←⦁
[0;32mI (94) boot_comm: chip revision: 3, min. application chip revision: 0[0m
[14:49:21:256]Rx←⦁[0;32mI (145) esp_image: segment 1: paddr=00027e78 vaddr=3ffb0000 size=03838h ( 14392) load[0m
[0;32mI (151) esp_image: segment 2: paddr=0002b6b8 vaddr=40080000 size=04960h ( 18784) load[0m
[14:49:21:432]Rx←⦁[0;32mI (333) esp_image: segment 4: paddr=000a4e14 vaddr=40084960 size=109d8h ( 68056) load[0m
[14:49:21:476]Rx←⦁[0;32mI (361) esp_image: segment 5: paddr=000b57f4 vaddr=50000000 size=00010h ( 16) load[0m
[14:49:21:511]Rx←⦁[0;32mI (398) cpu_start: Pro cpu start user code[0m
[14:49:21:558]Rx←⦁e SHA256: c5db9b0097c80e54...[0m
[0;3
[14:49:21:612]Rx←⦁2mI (470) spi_flash: detected chip: generic[0m
[0;33mW (477) spi_flash: Detected size(8192k) larger than the size in the binary image header(4096k). Using the size in the binary image header.[0m
[14:49:21:671]Rx←⦁[0;32mI (560) ua[0;32mI (560) system_api: Base MAC address is not set[0m
[14:49:23:285]Rx←⦁[0;32mI (2220) eth2sta: Ethernet Started[0m
[0m
[14:49:23:339]Rx←⦁ask: 3ffc6240, prio:23,K曱0
[14:49:23:865]Rx←⦁
[14:49:24:313]Rx←⦁ets Jul 29 2019 12:21:46
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
load:0x40078000,len
[14:49:24:362]Rx←⦁:14780
entry 0x40080694
[0;32mI (28) boot: ESP-IDF v4.4-dirty 2nd stage bootloader[0m
[0;32mI (28) boot: compile time 19:47:35[0m
[0;32mI (28) boot: chip revision: 3[0m
[0;32mI (31) boot_comm: chip revision: 3, min. bootloader chip revision: 0[0m
[0;32mI (43) boot.esp32: SPI Mode : DIO[0m
[0;32mI (52) boot: Enabling RNG early entropy source...[0m
[14:49:24:407]Rx←⦁tion Table:[0m
[0;32mI (61) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (83) boot: 2 factory factory app 00 00 00010000 00100000[0m
[0;32mI (102) esp_image: segment 0: paddr=00010020 vad
[14:49:24:446]Rx←⦁dr=3f400020 size=17e50h ( 97872) map[0m
[0;32mI (146) esp_image: segment 1: paddr=00027e78 vaddr=3ffb0000 size=03838h ( 14392) load[0m
[14:49:24:490]Rx←⦁
[14:49:24:646]Rx←⦁[0;32mI (333) esp_image: segment 4: paddr=000a4e14 vaddr=40084960 size=109d8h ( 68056) load[0m
[14:49:24:702]Rx←⦁[0;32mI (361) esp_image: segment 5: paddr=000b57f4 vaddr=50000000 size=00010h ( 16) load[0m
[0;32mI (384) cpu_start: Pro cpu up.[0m
[14:49:24:749]Rx←⦁rt: Application information:[0m
[0;32mI (413) cpu_start: Compile time: Jul 13 2022 19:46:26[0m
[14:49:24:790]Rx←⦁en 00028B28 (162 KiB): DRAM[0m
[0;32mI (450) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM[0m
[14:49:24:837]Rx←⦁y image header.[0m
[0;31mE (
[14:49:24:873]Rx←⦁570) rtl8201: Before Write bmcr.power_down is 0[0m
[14:49:26:499]Rx←⦁[0;32mI (2220) eth2sta: Ethernet Started[0m
[0m
[14:49:26:545]Rx←⦁ask: 3ffc6240, prio:23, stack:6656, core=0
ctor was triggered
