在做ST7789 240×240的驱动,修改自官方SPI_MASTER下的LCD例子,附上主要的修改
引脚部分 #ifdef CONFIG_IDF_TARGET_ESP32 #define LCD_HOST HSPI_HOST #define DMA_CHAN 2 #define PIN_NUM_MISO -1 #define PIN_NUM_MOSI 25 #define PIN_NUM_CLK 12 #define PIN_NUM_CS 27 #define PIN_NUM_DC 33 #define PIN_NUM_RST 14 #define PIN_NUM_BCKL -1 一次刷新120行 #define PARALLEL_LINES 120 主函数 Code: Select all void app_main(void) { esp_err_t ret; spi_device_handle_t spi; spi_bus_config_t buscfg={ .miso_io_num=PIN_NUM_MISO, .mosi_io_num=PIN_NUM_MOSI, .sclk_io_num=PIN_NUM_CLK, .quadwp_io_num=-1, .quadhd_io_num=-1, .max_transfer_sz=PARALLEL_LINES*240*2+8 }; spi_device_interface_config_t devcfg={ .clock_speed_hz=25*1000*1000, //Clock out at 10 MHz .mode=0, //SPI mode 0 .spics_io_num=PIN_NUM_CS, //CS pin .queue_size=7, //We want to be able to queue 7 transactions at a time .pre_cb=lcd_spi_pre_transfer_callback, //Specify pre-transfer callback to handle D/C line }; //Initialize the SPI bus ret=spi_bus_initialize(LCD_HOST, &buscfg, DMA_CHAN); ESP_ERROR_CHECK(ret); //Attach the LCD to the SPI bus ret=spi_bus_add_device(LCD_HOST, &devcfg, &spi); ESP_ERROR_CHECK(ret); //Initialize the LCD lcd_init(spi); //Go do nice stuff. display_pretty_colors(spi); } Code: Select all static void display_pretty_colors(spi_device_handle_t spi) { uint16_t *lines[2]; uint8_t pix[240]; //Allocate memory for the pixel buffers ESP_LOGI(TAG,"start heap caps malloc"); for (int i=0; i<2; i++) { lines=heap_caps_malloc(240*PARALLEL_LINES*sizeof(uint16_t), MALLOC_CAP_DMA); assert(lines!=NULL); } uint16_t frame=0xFFFF; //Indexes of the line currently being sent to the LCD and the line we're calculating. int sending_line=-1; int calc_line=0; while(1) { frame--; if (frame==0) frame = 0xFFFF; for (int y=0; y<240; y+=PARALLEL_LINES) { //Calculate a line. // pretty_effect_calc_lines(lines[calc_line], y, frame, PARALLEL_LINES); for (int j=0; j<240*PARALLEL_LINES; j++) lines[0][j] = (frame<<8) + (frame>>8); //Finish up the sending process of the previous line, if any ESP_LOGI(TAG,"fill color %2x", frame); if (sending_line!=-1) send_line_finish(spi); ESP_LOGI(TAG,"send line"); send_lines(spi, y, lines[0]); ESP_LOGI(TAG,"finish send line"); } } } Code: Select all static void send_lines(spi_device_handle_t spi, int ypos, uint16_t *linedata) { esp_err_t ret; int x; //Transaction descriptors. Declared static so they're not allocated on the stack; we need this memory even when this //function is finished because the SPI driver needs access to it even while we're already calculating the next line. DRAM_ATTR static spi_transaction_t trans[6]; DRAM_ATTR static uint8_t data_command=0x2c; static uint8_t ydata_pos_command[5]; //In theory, it's better to initialize trans and data only once and hang on to the initialized //variables. We allocate them on the stack, so we need to re-init them each call. for (x=0; x<6; x++) { memset(&trans[x], 0, sizeof(spi_transaction_t)); if ((x&1)==0) { //Even transfers are commands trans[x].length=8; trans[x].user=(void*)0; } else { //Odd transfers are data trans[x].length=8*4; trans[x].user=(void*)1; } trans[x].flags=SPI_TRANS_USE_TXDATA; } trans[0].tx_data[0]=0x2A; //Column Address Set trans[1].tx_data[0]=0; //Start Col High trans[1].tx_data[1]=0; //Start Col Low trans[1].tx_data[2]=((uint16_t)239)>>8; //End Col High trans[1].tx_data[3]=((uint16_t)239)&0xff; //End Col Low trans[2].tx_data[0]=0x2B; //Page address set ydata_pos_command[0] = ypos>>8; ydata_pos_command[1] = ypos&0xff; ydata_pos_command[2] = (ypos+PARALLEL_LINES)>>8; ydata_pos_command[3] = (ypos+PARALLEL_LINES)&0xff; trans[3].tx_buffer = ydata_pos_command; trans[3].length=4*8; //Data length, in bits trans[3].flags=0; //undo SPI_TRANS_USE_TXDATA flag trans[4].tx_buffer=&data_command; //finally send the line data trans[4].length = 8; trans[4].flags=0; trans[5].tx_buffer = linedata; trans[5].length=240*2*8*PARALLEL_LINES; //Data length, in bits trans[5].flags=0; //undo SPI_TRANS_USE_TXDATA flag //Queue all transactions. for (x=0; x<6; x++) { ret=spi_device_queue_trans(spi, &trans[x], portMAX_DELAY); // ret=spi_device_polling_transmit(spi, &trans[x]); assert(ret==ESP_OK); } } |
只有小组成员才能发言,加入小组>>
282浏览 6评论
232浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
239浏览 5评论
231浏览 4评论
215浏览 4评论
GMT+8, 2024-5-15 14:14 , Processed in 0.807317 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
