当有多个串口共同注册一个回调函数,怎么通过rt_device_t判断是那个串口触发的回调函数? 以及如何快速清除串口接收缓冲区,没有发现相关的api。 |
1个回答
串口的中断回调函数第一个参数是 rt_device_t dev,定义如下
struct rt_device { struct rt_object parent; /**< inherit from rt_object */ enum rt_device_class_type type; /**< device type */ rt_uint16_t flag; /**< device flag */ rt_uint16_t open_flag; /**< device open flag */ rt_uint8_t ref_count; /**< reference count */ rt_uint8_t device_id; /**< 0 - 255 */ /* device call back */ rt_err_t (*rx_indicate)(rt_device_t dev, rt_size_t size); rt_err_t (*tx_complete)(rt_device_t dev, void *buffer); #ifdef RT_USING_DEVICE_OPS const struct rt_device_ops *ops; #else /* common device interface */ rt_err_t (*init) (rt_device_t dev); rt_err_t (*open) (rt_device_t dev, rt_uint16_t oflag); rt_err_t (*close) (rt_device_t dev); rt_size_t (*read) (rt_device_t dev, rt_off_t pos, void *buffer, rt_size_t size); rt_size_t (*write) (rt_device_t dev, rt_off_t pos, const void *buffer, rt_size_t size); rt_err_t (*control)(rt_device_t dev, int cmd, void *args); #endif #if defined(RT_USING_POSIX) const struct dfs_file_ops *fops; struct rt_wqueue wait_queue; #endif void *user_data; /**< device private data */ }; struct rt_object { char name[RT_NAME_MAX]; /**< name of kernel object */ rt_uint8_t type; /**< type of kernel object */ rt_uint8_t flag; /**< flag of kernel object */ #ifdef RT_USING_MODULE void *module_id; /**< id of application module */ #endif rt_list_t list; /**< list node of kernel object */ }; typedef struct rt_object *rt_object_t; /**< Type for kernel objects. */ 在串口驱动注册时,每个串口的名字是不一样的,可以用 dev->parent->name 来进行区分。串口设备的名字在文件 drivers/include/config/uart_config.h 中定义。 #ifndef UART1_CONFIG #define UART1_CONFIG { .name = "uart1", .Instance = USART1, .irq_type = USART1_IRQn, .tx_pin_name = BSP_UART1_TX_PIN, .rx_pin_name = BSP_UART1_RX_PIN, } #endif /* UART1_CONFIG */ #ifndef UART2_CONFIG #define UART2_CONFIG { .name = "uart2", .Instance = USART2, .irq_type = USART2_IRQn, .tx_pin_name = BSP_UART2_TX_PIN, .rx_pin_name = BSP_UART2_RX_PIN, } #endif /* UART2_CONFIG */ |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1033 浏览 0 评论
2877 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9386 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2898 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2302 浏览 1 评论
/9
GMT+8, 2025-12-2 13:34 , Processed in 0.971486 second(s), Total 63, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
895
