扫一扫,分享给好友
我使用的板子是ESP32camera板,下面时启动时打印的Log,然后一直重启,有遇到过的伙伴吗,原因时什么导致的,怎样解决?
Rebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:4 load:0x3fff0034,len:6988 load:0x40078000,len:13664 load:0x40080400,len:4632 entry 0x400806f4 [0;32mI (29) boot: ESP-IDF v4.2-dirty 2nd stage bootloader[0m [0;32mI (29) boot: compile time 20:38:17[0m [0;32mI (29) boot: chip revision: 1[0m [0;32mI (32) boot_comm: chip revision: 1, min. bootloader chip revision: 0[0m [0;32mI (39) boot.esp32: SPI Speed : 40MHz[0m [0;32mI (44) boot.esp32: SPI Mode : DIO[0m [0;32mI (48) boot.esp32: SPI Flash Size : 4MB[0m [0;32mI (53) boot: Enabling RNG early entropy source...[0m [0;32mI (58) boot: Partition Table:[0m [0;32mI (62) boot: ## Label Usage Type ST Offset Length[0m [0;32mI (69) boot: 0 nvs WiFi data 01 02 00009000 00004000[0m [0;32mI (77) boot: 1 otadata OTA data 01 00 0000d000 00002000[0m [0;32mI (84) boot: 2 phy_init RF data 01 01 0000f000 00001000[0m [0;32mI (92) boot: 3 factory factory app 00 00 00010000 00150000[0m [0;32mI (99) boot: 4 ota_0 OTA app 00 10 00160000 00150000[0m [0;32mI (107) boot: 5 ota_1 OTA app 00 11 002b0000 00150000[0m [0;32mI (114) boot: End of partition table[0m [0;32mI (119) boot: Defaulting to factory image[0m [0;32mI (123) boot_comm: chip revision: 1, min. application chip revision: 0[0m [0;32mI (130) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x0bd34 ( 48436) map[0m [0;32mI (160) esp_image: segment 1: paddr=0x0001bd5c vaddr=0x3ffbdb60 size=0x0220c ( 8716) load[0m [0;32mI (164) esp_image: segment 2: paddr=0x0001df70 vaddr=0x40080000 size=0x00404 ( 1028) load[0m [0;32mI (167) esp_image: segment 3: paddr=0x0001e37c vaddr=0x40080404 size=0x01c9c ( 7324) load[0m [0;32mI (179) esp_image: segment 4: paddr=0x00020020 vaddr=0x400d0020 size=0x1abf0 (109552) map[0m [0;32mI (230) esp_image: segment 5: paddr=0x0003ac18 vaddr=0x400820a0 size=0x0c32c ( 49964) load[0m [0;32mI (262) boot: Loaded app from partition at offset 0x10000[0m [0;32mI (262) boot: Disabling RNG early entropy source...[0m [0;31mE (263) psram: Not a valid or known package id: 3[0m Re-enable cpu cache. abort() was called at PC 0x40083b03 on core 0 Backtrace:0x40087a5a:0x3ffe3b40 0x40088119:0x3ffe3b60 0x4008bd86:0x3ffe3b80 0x40083b03:0x3ffe3bf0 0x400d2973:0x3ffe3c20 0x40081b35:0x3ffe3c40 0x40079082:0x3ffe3c80 |<-CORRUPTED ELF file SHA256: e3b85ba01105aacf Rebooting... 补充: 以下是我自定义的分区表: # Name Type SubType Offset Size Flags # Note: if you have increased the bootloader size make sure to update the offsets to avoid overlap nvs data nvs 0x9000 0x4000 otadata data ota 0xd000 0x2000 phy_init data phy 0xf000 0x1000 factory app factory 0x10000 0x150000 ota_0 app ota_0 0x160000 0x150000 ota_1 app ota_1 0x2b0000 0x150000 我的应用程序同时开启了蓝牙、拍照、WIFI功能、NVS、i2s 在menuconfig里面已经开启了psram FreeRTOS的任务分配我用的是静态方式,使用calloc分配外部psram的内存给任务使用 程序之前是运行正常的,可能是由于我操作了nvs的时候导致以上错误,也可能是其他原因 我尝试过清除整个flash并且重新写入原来的代码,但还是不行,换了一块板子就好了 懂的小伙伴帮忙看看是咋回事,或者有没有好的想法或思路? |
只有小组成员才能发言,加入小组>>
470 浏览 0 评论
991 浏览 0 评论
1709 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1368 浏览 1 评论
1254 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1288浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2386浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2575浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-14 05:01 , Processed in 3.340049 second(s), Total 67, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1293
