电子发烧友论坛|
环境:vs code + wsl + esp-idf插件
硬件环境:ESP32-WROVER-E 程序:BLINK 终端信息: > Executing task: /home/mkkk/.espressif/python_env/idf4.3_py3.8_env/bin/python /home/mkkk/esp/esp-idf/components/esptool_py/esptool/esptool.py -p /dev/ttyS3 -b 460800 --before default_reset --after hard_reset --chip esp32 write_flash --flash_mode dio --flash_freq 40m --flash_size detect 0x10000 blink.bin 0x1000 bootloader/bootloader.bin 0x8000 partition_table/partition-table.bin < esptool.py v3.1-dev Serial port /dev/ttyS3 Connecting..... Chip is ESP32-D0WD-V3 (revision 3) Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None Crystal is 40MHz MAC: 78:e3:6d Uploading stub... Running stub... Stub running... Changing baud rate to 460800 Changed. Traceback (most recent call last): File "/home/mkkk/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 4535, in _main() File "/home/mkkk/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 4528, in _main main() File "/home/mkkk/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 4053, in main esp.change_baud(args.baud) File "/home/mkkk/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 149, in inner return func(*args, **kwargs) File "/home/mkkk/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 864, in change_baud self._set_port_baudrate(baud) File "/home/mkkk/esp/esp-idf/components/esptool_py/esptool/esptool.py", line 334, in _set_port_baudrate self._port.baudrate = baud File "/home/mkkk/.espressif/python_env/idf4.3_py3.8_env/lib/python3.8/site-packages/serial/serialutil.py", line 299, in baudrate self._reconfigure_port() File "/home/mkkk/.espressif/python_env/idf4.3_py3.8_env/lib/python3.8/site-packages/serial/serialposix.py", line 517, in _reconfigure_port termios.tcsetattr( termios.error: (5, 'Input/output error') 终端进程“bash '-c', '/home/mkkk/.espressif/python_env/idf4.3_py3.8_env/bin/python /home/mkkk/esp/esp-idf/components/esptool_py/esptool/esptool.py -p /dev/ttyS3 -b 460800 --before default_reset --after hard_reset --chip esp32 write_flash --flash_mode dio --flash_freq 40m --flash_size detect 0x10000 blink.bin 0x1000 bootloader/bootloader.bin 0x8000 partition_table/partition-table.bin'”已终止,退出代码: 1。 终端将被任务重用,按任意键关闭。 |
只有小组成员才能发言,加入小组>>
479 浏览 0 评论
1006 浏览 0 评论
1716 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1375 浏览 1 评论
1258 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1295浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
945浏览 3评论
2396浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2588浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1077浏览 2评论
/9
GMT+8, 2025-12-18 12:12 , Processed in 0.770143 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6218
