日志LOG:
entry 0x40080710 I (29) boot: ESP-IDF v4.2.1-dirty 2nd stage bootloader I (29) boot: compile time 16:54:50 I (29) boot: chip revision: 3 I (33) boot_comm: chip revision: 3, min. bootloader chip revision: 0 I (40) qio_mode: Enabling default flash chip QIO I (45) boot.esp32: SPI Speed : 80MHz I (50) boot.esp32: SPI Mode : QIO I (54) boot.esp32: SPI Flash Size : 4MB I (59) boot: Enabling RNG early entropy source... I (64) boot: Partition Table: I (68) boot: ## Label Usage Type ST Offset Length I (75) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (82) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (90) boot: 2 factory factory app 00 00 00010000 001f0000 I (97) boot: 3 storage Unknown data 01 81 00200000 00100000 I (105) boot: End of partition table I (109) boot_comm: chip revision: 3, min. application chip revision: 0 I (116) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x064c8 ( 25800) map I (133) esp_image: segment 1: paddr=0x000164f0 vaddr=0x3ffb0000 size=0x02100 ( 8448) load I (137) esp_image: segment 2: paddr=0x000185f8 vaddr=0x40080000 size=0x00404 ( 1028) load 0x40080000: _WindowOverflow4 at C:/msys64/home/wangs/esp/esp-idf/components/freertos/xtensa/xtensa_vectors.S:1730 I (143) esp_image: segment 3: paddr=0x00018a04 vaddr=0x40080404 size=0x07614 ( 30228) load I (163) esp_image: segment 4: paddr=0x00020020 vaddr=0x400d0020 size=0x1806c ( 98412) map 0x400d0020: _stext at ??:? I (192) esp_image: segment 5: paddr=0x00038094 vaddr=0x40087a18 size=0x02b28 ( 11048) load 0x40087a18: multi_heap_free_impl at C:/msys64/home/wangs/esp/esp-idf/components/heap/multi_heap.c:533 I (202) boot: Loaded app from partition at offset 0x10000 I (202) boot: Disabling RNG early entropy source... I (204) cpu_start: Pro cpu up. I (207) cpu_start: Application information: I (212) cpu_start: Project name: wear_levelling_example I (218) cpu_start: App version: v4.2.1-dirty I (224) cpu_start: Compile time: Sep 14 2021 16:26:27 I (230) cpu_start: ELF file SHA256: 008ba9c15efc846c... I (236) cpu_start: ESP-IDF: v4.2.1-dirty I (241) cpu_start: Starting app cpu, entry point is 0x40081650 0x40081650: call_start_cpu1 at C:/msys64/home/wangs/esp/esp-idf/components/esp32/cpu_start.c:287 I (0) cpu_start: App cpu up. I (252) heap_init: Initializing. RAM available for dynamic allocation: I (259) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (265) heap_init: At 3FFB2990 len 0002D670 (181 KiB): DRAM I (271) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (277) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (284) heap_init: At 4008A540 len 00015AC0 (86 KiB): IRAM I (290) cpu_start: Pro cpu start user code I (307) spi_flash: detected chip: generic I (307) spi_flash: flash io: qio W (307) spi_flash: Detected size(8192k) larger than the size in the binary image header(4096k). Using the size in the binary image header. I (319) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (334) example: Mounting FAT filesystem I (340) example: Opening file I (483) example: File written I (483) example: Reading file I (484) example: Read from file: '' I (484) example: Unmounting FAT filesystem I (585) example: Done 最近在想用SPI FLASH存参数,跑 wear_levelling 例程 读写出现写入不成功,读出来也不对的现象,不知道具体原因还多指教一下。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2336浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 04:47 , Processed in 0.740030 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
489
