我是按照官方教程一步步走的,但在执行idf.py set-target esp32时出现报错:
CMake Error at build/CMakeFiles/git-data/grabRef.cmake:48 (file): file failed to open for reading (No such file or directory): D:/Programs/esp-idf/examples/get-started/hello_world/build/CMakeFiles/git-data/head-ref 我打开git-data文件夹,确实没有找到head-ref文件,里面只有grabRef.cmake文件和HEAD文件。即使不管报错继续执行idf.py build也无法编译,出现几乎相同的报错。百度完全没有查询到相关信息,也请大家和审核大大帮帮我 以下是CMD内信息: D:Programsesp-idfexamplesget-startedhello_world>D:Programsesp-idfexport.bat Setting IDF_PATH: D:Programsesp-idf Adding ESP-IDF tools to PATH... fatal: No names found, cannot describe anything. WARNING: Git describe was unsuccessful: b'' D:Programsesp-toolstoolsxtensa-esp32s2-elfesp-2021r1-8.4.0xtensa-esp32s2-elfbin D:Programsesp-toolstoolsxtensa-esp32s3-elfesp-2021r1-8.4.0xtensa-esp32s3-elfbin D:Programsesp-toolstoolsriscv32-esp-elfesp-2021r1-8.4.0riscv32-esp-elfbin D:Programsesp-toolstoolsesp32ulp-elf2.28.51-esp-20191205esp32ulp-elf-binutilsbin D:Programsesp-toolstoolsesp32s2ulp-elf2.28.51-esp-20191205esp32s2ulp-elf-binutilsbin D:Programsesp-toolstoolsopenocd-esp32v0.10.0-esp32-20210902openocd-esp32bin D:Programsesp-toolstoolsninja1.10.2 D:Programsesp-toolstoolsidf-exe1.0.1 D:Programsesp-toolstoolsccache4.3ccache-4.3-windows-64 D:Programsesp-toolstoolsdfu-util .9dfu-util-0.9-win64 D:Programsesp-toolspython_envidf4.4_py3.6_envScripts D:Programsesp-idftools Checking if Python packages are up to date... Python requirements from D:Programsesp-idfrequirements.txt are satisfied. Done! You can now compile ESP-IDF projects. Go to the project directory and run: idf.py build D:Programsesp-idfexamplesget-startedhello_world>idf.py set-target esp32 Adding "set-target"'s dependency "fullclean" to list of commands with default set of options. Executing action: fullclean Directory 'd:programsesp-idfexamplesget-startedhello_worldbuild' doesn't seem to be a CMake build directory. Refusing to automatically delete files in this directory. Delete the directory manually to 'clean' it. D:Programsesp-idfexamplesget-startedhello_world>idf.py set-target esp32 Adding "set-target"'s dependency "fullclean" to list of commands with default set of options. Executing action: fullclean Build directory 'd:programsesp-idfexamplesget-startedhello_worldbuild' not found. Nothing to clean. Executing action: set-target Set Target to: esp32, new sdkconfig created. Existing sdkconfig renamed to sdkconfig.old. Running cmake in directory d:programsesp-idfexamplesget-startedhello_worldbuild Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 -DIDF_TARGET=esp32 -DCCACHE_ENABLE=1 d:programsesp-idfexamplesget-startedhello_world"... -- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.33.0.windows.2") CMake Error at build/CMakeFiles/git-data/grabRef.cmake:48 (file): file failed to open for reading (No such file or directory): D:/Programs/esp-idf/examples/get-started/hello_world/build/CMakeFiles/git-data/head-ref Call Stack (most recent call first): D:/Programs/esp-idf/tools/cmake/third_party/GetGitRevisionDescription.cmake:80 (include) D:/Programs/esp-idf/tools/cmake/third_party/GetGitRevisionDescription.cmake:90 (get_git_head_revision) D:/Programs/esp-idf/tools/cmake/build.cmake:67 (git_describe) D:/Programs/esp-idf/tools/cmake/build.cmake:174 (__build_get_idf_git_revision) D:/Programs/esp-idf/tools/cmake/idf.cmake:50 (__build_init) D:/Programs/esp-idf/tools/cmake/project.cmake:12 (include) CMakeLists.txt:5 (include) CMake Warning at D:/Programs/esp-idf/tools/cmake/git_submodules.cmake:52 (message): Git submodule is out of date. Run 'git submodule update --init --recursive' to fix. Call Stack (most recent call first): D:/Programs/esp-idf/tools/cmake/build.cmake:77 (git_submodule_check) D:/Programs/esp-idf/tools/cmake/build.cmake:174 (__build_get_idf_git_revision) D:/Programs/esp-idf/tools/cmake/idf.cmake:50 (__build_init) D:/Programs/esp-idf/tools/cmake/project.cmake:12 (include) CMakeLists.txt:5 (include) CMake Error at D:/Programs/esp-idf/tools/cmake/git_submodules.cmake:57 (get_filename_component): get_filename_component unknown component BASE_DIR Call Stack (most recent call first): D:/Programs/esp-idf/tools/cmake/build.cmake:77 (git_submodule_check) D:/Programs/esp-idf/tools/cmake/build.cmake:174 (__build_get_idf_git_revision) D:/Programs/esp-idf/tools/cmake/idf.cmake:50 (__build_init) D:/Programs/esp-idf/tools/cmake/project.cmake:12 (include) CMakeLists.txt:5 (include) -- Configuring incomplete, errors occurred! cmake failed with exit code 1 D:Programsesp-idfexamplesget-startedhello_world>git submodule update --init D:Programsesp-idfexamplesget-startedhello_world> |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2527浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 08:24 , Processed in 0.663292 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
479
