电子发烧友论坛|
1、根据文档提示下载espidf v4.4 的离线安装包,1.7G,下载了大半天,结果安装时里面没有V4.4的版本,只有V4.3的
2、下载在线安装包,可以选V4.4版本,每次都是安装到一半就提示安装失败,估计还是和github网络访问连接的问题 3、直接在git cmd模式下敲命令 git clone -b release/v4.4 https://github.com/espressif/esp-idf.git 也是下载到一大半,然后提示很多文件下载失败. Cloning into 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/asio/asio'... fatal: unable to access 'https://github.com/espressif/asio.git/': OpenSSL SSL_read: SSL_ERROR_SYSCALL, errno 10054 fatal: clone of 'https://github.com/espressif/asio.git' into submodule path 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/asio/asio' failed Failed to clone 'components/asio/asio'. Retry scheduled Cloning into 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/bootloader/subproject/components/micro-ecc/micro-ecc'... fatal: unable to access 'https://github.com/kmackay/micro-ecc.git/': Failed to connect to github.com port 443: timed out fatal: clone of 'https://github.com/kmackay/micro-ecc.git' into submodule path 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/bootloader/subproject/components/micro-ecc/micro-ecc' failed Failed to clone 'components/bootloader/subproject/components/micro-ecc/micro-ecc'. Retry scheduled Cloning into 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/bt/controller/lib_esp32'... fatal: unable to access 'https://github.com/espressif/esp32-bt-lib.git/': Failed to connect to github.com port 443: Timed out fatal: clone of 'https://github.com/espressif/esp32-bt-lib.git' into submodule path 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/bt/controller/lib_esp32' failed Failed to clone 'components/bt/controller/lib_esp32'. Retry scheduled Cloning into 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/bt/controller/lib_esp32c3_family'... fatal: unable to access 'https://github.com/espressif/esp32c3-bt-lib.git/': Failed to connect to github.com port 443: Timed out fatal: clone of 'https://github.com/espressif/esp32c3-bt-lib.git' into submodule path 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/bt/controller/lib_esp32c3_family' failed Failed to clone 'components/bt/controller/lib_esp32c3_family'. Retry scheduled Cloning into 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/bt/host/nimble/nimble'... fatal: unable to access 'https://github.com/espressif/esp-nimble.git/': Failed to connect to github.com port 443: Timed out fatal: clone of 'https://github.com/espressif/esp-nimble.git' into submodule path 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/bt/host/nimble/nimble' failed Failed to clone 'components/bt/host/nimble/nimble'. Retry scheduled Cloning into 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/cbor/tinycbor'... fatal: unable to access 'https://github.com/intel/tinycbor.git/': Failed to connect to github.com port 443: Timed out fatal: clone of 'https://github.com/intel/tinycbor.git' into submodule path 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/cbor/tinycbor' failed Failed to clone 'components/cbor/tinycbor'. Retry scheduled Cloning into 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/cmock/CMock'... fatal: unable to access 'https://github.com/ThrowTheSwitch/CMock.git/': Failed to connect to github.com port 443: Timed out fatal: clone of 'https://github.com/ThrowTheSwitch/CMock.git' into submodule path 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/cmock/CMock' failed Failed to clone 'components/cmock/CMock'. Retry scheduled fatal: not a git repository: F:/work/ESP32/esp-idf-v4.4/esp-idf/components/esp_wifi/lib/../../../.git/modules/components/esp_wifi/lib Failed to clone 'components/esp_wifi/lib'. Retry scheduled Cloning into 'F:/work/ESP32/esp-idf-v4.4/esp-idf/components/esptool_py/esptool'.. 国内访问国外网站github很不顺畅,而gitfee上的又没有同步更新到V4.4,很头疼,每次要更新新版本的时候都很麻烦,有没有什么更好的方式下载安装espidf呢? |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2334浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 01:13 , Processed in 0.522005 second(s), Total 42, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1591
