电子发烧友论坛|
在idf的例程中复制项目i2s_basic,我尝试修改采样率来提高i2s的频率,当我设置采样率到150000,使用逻辑分析仪测量bck_io的频率为9.7MHz,我接着往大的设置,尝试了250000,350000....625000。发现bck_io的频率最高只能到15MHZ,设置高了也没有效果。
Code: Select all /* I2S Example This example code will output 100Hz sine wave and triangle wave to 2-channel of I2S driver Every 5 seconds, it will change bits_per_sample [16, 24, 32] for i2s data This example code is in the Public Domain (or CC0 licensed, at your option.) Unless required by applicable law or agreed to in writing, this software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. */ #include #include "freertos/FreeRTOS.h" #include "freertos/task.h" #include "driver/i2s.h" #include "driver/gpio.h" #include "esp_system.h" #include "esp_log.h" #include #define SAMPLE_RATE (150000) #define I2S_NUM (0) #define WAVE_FREQ_HZ (100) #define PI (3.14159265) #define I2S_BCK_IO (GPIO_NUM_4) #define I2S_WS_IO (GPIO_NUM_5) #define I2S_DO_IO (-1) #define I2S_DI_IO (GPIO_NUM_18) #define SAMPLE_PER_CYCLE (SAMPLE_RATE/WAVE_FREQ_HZ) static const char* TAG = "i2s_example"; int16_t i2s_readraw_buff[400]; static void setup_triangle_sine_waves(int bits) { int *samples_data = malloc(((bits+8)/16)*SAMPLE_PER_CYCLE*4); unsigned int i, sample_val; double sin_float, triangle_float, triangle_step = (double) pow(2, bits) / SAMPLE_PER_CYCLE; size_t i2s_bytes_write = 0; printf("rnTest bits=%d free mem=%d, written data=%dn", bits, esp_get_free_heap_size(), ((bits+8)/16)*SAMPLE_PER_CYCLE*4); triangle_float = -(pow(2, bits)/2 - 1); for(i = 0; i < SAMPLE_PER_CYCLE; i++) { sin_float = sin(i * 2 * PI / SAMPLE_PER_CYCLE); if(sin_float >= 0) triangle_float += triangle_step; else triangle_float -= triangle_step; sin_float *= (pow(2, bits)/2 - 1); if (bits == 16) { sample_val = 0; sample_val += (short)triangle_float; sample_val = sample_val << 16; sample_val += (short) sin_float; samples_data = sample_val; } else if (bits == 24) { //1-bytes unused samples_data[i*2] = ((int) triangle_float) << 8; samples_data[i*2 + 1] = ((int) sin_float) << 8; } else { samples_data[i*2] = ((int) triangle_float); samples_data[i*2 + 1] = ((int) sin_float); } } ESP_LOGI(TAG, "set clock"); i2s_set_clk(I2S_NUM, SAMPLE_RATE, bits, 2); //Using push // for(i = 0; i < SAMPLE_PER_CYCLE; i++) { // if (bits == 16) // i2s_push_sample(0, &samples_data, 100); // else // i2s_push_sample(0, &samples_data[i*2], 100); // } // or write ESP_LOGI(TAG, "write data"); i2s_write(I2S_NUM, samples_data, ((bits+8)/16)*SAMPLE_PER_CYCLE*4, &i2s_bytes_write, 100); free(samples_data); } void app_main(void) { //for 36Khz sample rates, we create 100Hz sine wave, every cycle need 36000/100 = 360 samples (4-bytes or 8-bytes each sample) //depend on bits_per_sample //using 6 buffers, we need 60-samples per buffer //if 2-channels, 16-bit each channel, total buffer is 360*4 = 1440 bytes //if 2-channels, 24/32-bit each channel, total buffer is 360*8 = 2880 bytes i2s_config_t i2s_config = { .mode = I2S_MODE_MASTER | I2S_MODE_RX, .sample_rate = SAMPLE_RATE, .bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT, .channel_format = I2S_CHANNEL_FMT_ALL_LEFT, .communication_format = I2S_COMM_FORMAT_STAND_MSB, .dma_buf_count = 6, .dma_buf_len = 60, .use_apll = true, .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1 //Interrupt level 1 }; i2s_pin_config_t pin_config = { .bck_io_num = I2S_BCK_IO, .ws_io_num = I2S_WS_IO, .data_out_num = I2S_DO_IO, .data_in_num = I2S_DI_IO //Not used }; i2s_driver_install(I2S_NUM, &i2s_config, 0, NULL); i2s_set_pin(I2S_NUM, &pin_config); // i2s_set_clk(I2S_NUM, SAMPLE_RATE, I2S_BITS_PER_SAMPLE_16BIT, 2); size_t bytes_read; while (1) { // setup_triangle_sine_waves(test_bits); i2s_read(I2S_NUM, i2s_readraw_buff, 200, &bytes_read, portMAX_DELAY); printf("read i2s %d:",bytes_read); for(int i = 0;i < 200; i++) { printf("%x ",i2s_readraw_buff); } printf("n"); vTaskDelay(5000/portTICK_RATE_MS); } } |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2336浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 02:52 , Processed in 1.846073 second(s), Total 67, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
806
