电子发烧友论坛|
PS C:Usersxn551espidf2esp-idfexamplesget-startedhello_world> idf.py monitor
The following Python requirements are not satisfied: python-socketio<5 gdbgui==0.13.2.0 To install the missing packages, please run "install.bat" Diagnostic information: IDF_PYTHON_ENV_PATH: C:Usersxn551.espressifpython_envidf5.0_py3.9_env Python interpreter used: C:Usersxn551.espressifpython_envidf5.0_py3.9_envScriptspython.exe Skipping the download of C:Usersxn551.espressifespidf.constraints.v5.0.txt because it was downloaded recently. If you believe that this is causing you trouble then remove it manually and re-run your install script. Constraint file: C:Usersxn551.espressifespidf.constraints.v5.0.txt Requirement files: - C:Usersxn551espidf2esp-idfrequirements.core.txt Python being checked: C:Usersxn551.espressifpython_envidf5.0_py3.9_envScriptspython.exe ESP-IDF v5.0-dev-1389-g5dcd630444-dirty IDF master, 几天前还好好的,s3,32,c3正常编译烧写,今天编译突然报错,4.3.1也用不了,现在只有2.1能用,请问是什么原因,写文章要用,急,谢谢! |
相关推荐 |
只有小组成员才能发言,加入小组>>
472 浏览 0 评论
998 浏览 0 评论
1713 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1370 浏览 1 评论
1256 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1289浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2390浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2581浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-15 09:45 , Processed in 1.923396 second(s), Total 70, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3394
