电子发烧友论坛|
有人在esp32上成功跑过 TLS 1.3吗?
用的master esp-idf 5.0, 然后 mbedtls用的是branch mbedtls git:(mbedtls-3.1.0-idf) 我想测下MQTT over TLS 1.3 在menuconfig里面enable了tls 1.3 第一次 tls 1.3 的handshake没问题,ssl状态在WRAPUP后设置为 MBEDTLS_SSL_HANDSHAKE_OVER 然后在 ssl_handle_hs_message_post_handshake()函数里面报错, 我看了下是收到了NEW_SESSION_tiCKET 包裹。 原代码在这边就直接 return UNEXPECTED_MESSAGE了。 Code: Select all MBEDTLS_SSL_DEBUG_MSG( 1, ("hangmao debug: post ssl handshake '%d'", ssl->in_msg[0])); //if (ssl->in_msg[0] != MBEDTLS_SSL_HS_NEW_SESSION_TICKET) return( MBEDTLS_ERR_SSL_UNEXPECTED_MESSAGE ); mbedtls: ssl_msg.c:4976 hangmao debug: post ssl handshake '4' Code: Select all I (3606) mbedtls: ssl_tls13_client.c:1723 tls13 client state: MBEDTLS_SSL_HANDSHAKE_WRAPUP(15) W (3616) mbedtls: ssl_tls13_client.c:1705 Switch to application keys for inbound traffic W (3626) mbedtls: ssl_tls13_client.c:1708 Switch to application keys for outbound traffic I (3636) mbedtls: ssl_tls.c:5323 <= handshake I (3646) mbedtls: ssl_msg.c:5348 => write I (3646) mbedtls: ssl_msg.c:2369 => write record I (3656) mbedtls: ssl_msg.c:546 => encrypt buf I (3656) mbedtls: ssl_msg.c:990 <= encrypt buf I (3666) mbedtls: ssl_msg.c:1789 => flush output I (3666) mbedtls: ssl_msg.c:1809 message length: 53, out_left: 53 I (3676) mbedtls: ssl_msg.c:1814 ssl->f_send() returned 53 (-0xffffffcb) I (3686) mbedtls: ssl_msg.c:1842 <= flush output I (3686) mbedtls: ssl_msg.c:2514 <= write record I (3696) mbedtls: ssl_msg.c:5372 <= write I (3696) mbedtls: ssl_msg.c:5067 => read I (3706) mbedtls: ssl_msg.c:3546 => read record I (3706) mbedtls: ssl_msg.c:1573 => fetch input I (3716) mbedtls: ssl_msg.c:1730 in_left: 0, nb_want: 5 I (3716) mbedtls: ssl_msg.c:1755 in_left: 0, nb_want: 5 I (3726) mbedtls: ssl_msg.c:1756 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb) I (3736) mbedtls: ssl_msg.c:1776 <= fetch input I (3736) mbedtls: ssl_msg.c:1573 => fetch input I (3746) mbedtls: ssl_msg.c:1730 in_left: 5, nb_want: 255 I (3756) mbedtls: ssl_msg.c:1755 in_left: 5, nb_want: 255 I (3756) mbedtls: ssl_msg.c:1756 ssl->f_recv(_timeout)() returned 250 (-0xffffff06) I (3766) mbedtls: ssl_msg.c:1776 <= fetch input I (3776) mbedtls: ssl_msg.c:1014 => decrypt buf I (3776) mbedtls: ssl_msg.c:1539 <= decrypt buf I (3786) mbedtls: ssl_msg.c:3620 <= read record W (3786) mbedtls: ssl_msg.c:4967 handshake received (not HelloRequest) W (3796) mbedtls: ssl_msg.c:4976 hangmao debug: post ssl handshake '4' W (3806) mbedtls: ssl_msg.c:5004 hangmao debug: renegotiation: disable? '1' secure? '0' legacy? '0' |
只有小组成员才能发言,加入小组>>
468 浏览 0 评论
984 浏览 0 评论
1707 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1364 浏览 1 评论
1253 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1286浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2378浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2565浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-12 05:52 , Processed in 0.438680 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2113
