esptool.py v3.2-dev
Serial port COM27 Connecting..... Chip is ESP32-S2 Features: WiFi, No Embedded Flash, No Embedded PSRAM, ADC and temperature sensor calibration in BLK2 of efuse V1 Crystal is 40MHz MAC: 7c:df:a1:00:96:3a Uploading stub... Running stub... Stub running... Changing baud rate to 460800 Changed. Configuring flash size... Warning: Could not auto-detect Flash size (FlashID=0xffff01, SizeID=0xff), defaulting to 4MB Flash will be erased from 0x00001000 to 0x00006fff... Flash will be erased from 0x00010000 to 0x0004dfff... Flash will be erased from 0x00008000 to 0x00008fff... Compressed 21888 bytes to 13585... A fatal error occurred: Packet content transfer stopped (received 8 bytes) The terminal process "E:APP_software_InstallEspressifpython_envidf4.4_py3.8_envScriptspython.exe 'E:APP_software_InstallEspressifframeworksesp-idf-v4.4componentsesptool_pyesptoolesptool.py', '-p', 'COM27', '-b', '460800', '--before', 'default_reset', '--after', 'hard_reset', '--chip', 'esp32s2', 'write_flash', '--flash_mode', 'dio', '--flash_freq', '80m', '--flash_size', 'detect', '0x1000', 'bootloader/bootloader.bin', '0x10000', 'esp32-s2-hmi.bin', '0x8000', 'partition_table/partition-table.bin'" terminated with exit code: 2. |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2336浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 02:51 , Processed in 0.666094 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
633
