电子发烧友论坛|
windows,idf4.4版本
~/esp32/SDK/esp-idf$ idf.py --version ESP-IDF v4.4-dirty 调试OTA的时候发现调用restart,wifi会连不上,然后去掉OTA功能,直接在程序跑起来10秒后restart,也有同样的问题。直接按板子上的复位按键是没这个问题的。调用restart才有这个问题。然后会出现很多行 pll_cap_ext 10 这个日志 打印的log如下: ▒Code: Select all ESP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0xc (RTC_SW_CPU_RST),boot:0xb (SPI_FAST_FLASH_BOOT) Saved PC:0x403755d4 SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd0268,len:0x17e8 load:0x403b6000,len:0xb34 load:0x403ba000,len:0x2fa8 entry 0x403b6230 W (24) boot.esp32s3: eFuse virtual mode is enabled. If Secure boot or Flash encryption is enabled then it does not provide any security. FOR TESTING ONLY! W (31) efuse: Loading virtual efuse blocks from real efuses I (50) boot: ESP-IDF v4.4-dirty 2nd stage bootloader I (50) boot: compile time 14:44:32 I (50) boot: chip revision: 0 I (52) boot.esp32s3: Boot SPI Speed : 80MHz I (57) boot.esp32s3: SPI Mode : DIO I (61) boot.esp32s3: SPI Flash Size : 4MB I (66) boot: Enabling RNG early entropy source... I (72) boot: Partition Table: I (75) boot: ## Label Usage Type ST Offset Length I (82) boot: 0 nvs WiFi data 01 02 0000d000 00008000 I (90) boot: 1 fctry WiFi data 01 02 00015000 00004000 I (97) boot: 2 log_status WiFi data 01 02 00019000 00004000 I (105) boot: 3 otadata OTA data 01 00 0001d000 00002000 I (112) boot: 4 phy_init RF data 01 01 0001f000 00001000 I (120) boot: 5 ota_0 OTA app 00 10 00020000 001d0000 I (127) boot: 6 ota_1 OTA app 00 11 001f0000 001d0000 I (135) boot: 7 coredump Unknown data 01 03 003c0000 00010000 I (143) boot: 8 log_info Unknown data 01 fe 003d0000 00010000 I (150) boot: 9 reserved Unknown data 01 ff 003e0000 00020000 I (158) boot: End of partition table I (162) esp_image: segment 0: paddr=00020020 vaddr=3c0c0020 size=24fd0h (151504) map I (198) esp_image: segment 1: paddr=00044ff8 vaddr=3fc956b0 size=048d4h ( 18644) load I (202) esp_image: segment 2: paddr=000498d4 vaddr=40374000 size=06744h ( 26436) load I (209) esp_image: segment 3: paddr=00050020 vaddr=42000020 size=b0038h (720952) map I (341) esp_image: segment 4: paddr=00100060 vaddr=4037a744 size=0af68h ( 44904) load I (351) esp_image: segment 5: paddr=0010afd0 vaddr=50000000 size=00010h ( 16) load I (359) boot: Loaded app from partition at offset 0x20000 I (359) boot: Disabling RNG early entropy source... I (371) cpu_start: Pro cpu up. I (372) cpu_start: Single core mode I (381) cpu_start: Pro cpu start user code I (381) cpu_start: cpu freq: 240000000 I (381) cpu_start: Application information: I (383) cpu_start: Project name: topapp I (388) cpu_start: App version: v1.0.0-139-g0f08961-dirty I (395) cpu_start: Compile time: Oct 28 2022 15:38:30 I (401) cpu_start: ELF file SHA256: b4d5427d9a72369e... I (407) cpu_start: ESP-IDF: v4.4-dirty I (412) heap_init: Initializing. RAM available for dynamic allocation: I (419) heap_init: At 3FCA0990 len 0003F670 (253 KiB): D/IRAM I (426) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM I (432) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM I (439) heap_init: At 600FE000 len 00002000 (8 KiB): RTCRAM I (445) spi_flash: detected chip: gd I (449) spi_flash: flash io: dio W (453) spi_flash: Detected size(16384k) larger than the size in the binary image header(4096k). Using the size in the binary image header. W (466) cpu_start: eFuse virtual mode is enabled. If Secure boot or Flash encryption is enabled then it does not provide any security. FOR TESTING ONLY! W (481) efuse: Loading virtual efuse blocks from real efuses I (487) sleep: Configure to isolate all GPIO pins in sleep state I (494) sleep: Enable automatic switching of GPIO sleep configuration I (501) coexist: coexist rom version e7ae62f I (506) cpu_start: Starting scheduler on PRO CPU. E (521) main: TOPAPP START >>>>>>>>>>>> I (521) pp: pp rom version: e7ae62f I (524) net80211: net80211 rom version: e7ae62f I (531) wifi:wifi driver task: 3fce6394, prio:23, stack:6656, core=0 I (536) system_api: Base MAC address is not set I (541) system_api: read default base MAC address from EFUSE I (550) wifi:wifi firmware version: 7679c42 I (551) wifi:wifi certification version: v7.0 I (555) wifi:config NVS flash: enabled I (558) wifi:config nano formating: disabled I (562) wifi:Init data frame dynamic rx buffer num: 32 I (567) wifi:Init management frame dynamic rx buffer num: 32 I (573) wifi:Init management short buffer num: 32 I (577) wifi:Init dynamic tx buffer num: 32 I (581) wifi:Init static tx FG buffer num: 2 I (585) wifi:Init static rx buffer size: 1600 I (589) wifi:Init static rx buffer num: 10 I (593) wifi:Init dynamic rx buffer num: 32 I (597) wifi_init: rx ba win: 6 I (601) wifi_init: tcpip mbox: 32 I (605) wifi_init: udp mbox: 6 I (608) wifi_init: tcp mbox: 6 I (612) wifi_init: tcp tx win: 5744 I (616) wifi_init: tcp rx win: 5744 I (620) wifi_init: tcp mss: 1460 I (624) wifi_init: WiFi IRAM OP enabled I (629) wifi_init: WiFi RX IRAM OP enabled I (634) phy_init: phy_version 302,3ddfab3,Dec 3 2021,14:39:12 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 pll_cap_ext 10 //(上面这行日志重复了好多次才停下) 请问有遇到同样问题的吗?不知道这个问题出在哪里。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2336浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 04:17 , Processed in 0.581519 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
556
