电子发烧友论坛|
请问各位有没有碰到看门狗触发但无法再正常启动的现象?请各位大神帮忙看看
使用芯片:ESP32 使用SDK:ESP-IDF V4.2 程序使用WiFi和BLE,蓝牙搜索附近广播包,判断广播包数据有变化则通过WiFi上传数据到服务器。 看log是core0的btController引起的看门狗触发,通过menuconfig配置蓝牙任务栈空间加大512B还是会复现看门狗触发但起不来,死机。 15个设备挂机5天,出现3个死机现象,死机的log如下: Code: Select all E (711955) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time: E (711955) task_wdt: - IDLE0 (CPU 0) E (711955) task_wdt: Tasks currently running: E (711955) task_wdt: CPU 0: btController E (711955) task_wdt: CPU 1: IDLE1 E (711955) task_wdt: Print CPU 0 (current core) backtrace Backtrace:0x400D2148:0x3FFBFAC0 0x40085A09:0x3FFBFAE0 0x4019486C:0x3FFE7A90 0x40194E31:0x3FFE7AB0 0x400930B1:0x3FFE7AE0 E (711955) task_wdt: Print CPU 1 backtrace Backtrace:0x40081697:0x3FFC00C0 0x40085A09:0x3FFC00E0 0x4000BFED:0x3FFBC400 0x40093311:0x3FFBC410 0x400D238C:0x3FFBC430 0x400D2397:0x3FFBC460 0x400D2435:0x3FFBC480 0x40091431:0x3FFBC4A0 0x400930B1:0x3FFBC4C0 打印了以上信息后,不再有log输出,直接死机。 以下是backtrace: CORE0 root@H:/mnt/d/HXJ/Code/ESP32/for_crash_debug# xtensa-esp32-elf-addr2line -piaf -e build/ZB.elf 0x400D2148:0x3FFBFAC0 0x40085A09:0x3FFBFAE0 0x4019486C:0x3FFE7A90 0x40194E31:0x3FFE7AB0 0x400930B1:0x3FFE7AE0 0x400d2148: task_wdt_isr at /home/esp/esp-idf/components/esp_common/src/task_wdt.c:187 0x40085a09: _xt_lowint1 at /home/esp/esp-idf/components/freertos/xtensa/xtensa_vectors.S:1105 0x4019486c: btdm_controller_task at ??:? 0x40194e31: btdm_controller_disable at ??:? 0x400930b1: vPortTaskWrapper at /home/esp/esp-idf/components/freertos/xtensa/port.c:143 CORE1 root@H:/mnt/d/HXJ/Code/ESP32/for_crash_debug# xtensa-esp32-elf-addr2line -piaf -e build/ZB.elf 0x40081697:0x3FFC00C0 0x40085A09:0x3FFC00E0 0x4000BFED:0x3FFBC400 0x40093311:0x3FFBC410 0x400D238C:0x3FFBC430 0x400D2397:0x3FFBC460 0x400D2435:0x3FFBC480 0x40091431:0x3FFBC4A0 0x400930B1:0x3FFBC4C0 0x40081697: esp_crosscore_isr at /home/esp/esp-idf/components/esp32/crosscore_int.c:80 0x40085a09: _xt_lowint1 at /home/esp/esp-idf/components/freertos/xtensa/xtensa_vectors.S:1105 0x4000bfed: ?? ??:0 0x40093311: vPortExitCritical at /home/esp/esp-idf/components/freertos/xtensa/port.c:419 0x400d238c: esp_task_wdt_reset at /home/esp/esp-idf/components/esp_common/src/task_wdt.c:333 0x400d2397: idle_hook_cb at /home/esp/esp-idf/components/esp_common/src/task_wdt.c:88 0x400d2435: esp_vApplicationIdleHook at /home/esp/esp-idf/components/esp_common/src/freertos_hooks.c:51 (discriminator 1) 0x40091431: prvIdleTask at /home/esp/esp-idf/components/freertos/tasks.c:3386 (discriminator 1) 0x400930b1: vPortTaskWrapper at /home/esp/esp-idf/components/freertos/xtensa/port.c:143 |
相关推荐 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1253浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2336浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 04:49 , Processed in 0.634278 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1176
