我已将 SPI 配置为使用 DMA。微控制器正在发送但未读取。我已经检查了配置,但看不出问题所在。你能在我的代码中看到一些奇怪的东西吗?
我已经在 STM32F429-DISCO 板上测试了这段代码并且可以正常工作。
这是外设定义。
- #define SPI_BCC SPI1
- #define SPI_BCC_CLK RCC_APB2Periph_SPI1
- #define SPI_BCC_CLK_EN RCC_APB2PeriphClockCmd(SPI_BCC_CLK, ENABLE)
- #define SPI_BCC_SCK_PIN GPIO_Pin_3
- #define SPI_BCC_SCK_GPIO_PORT GPIOB
- #define SPI_BCC_SCK_GPIO_CLK RCC_AHB1Periph_GPIOB
- #define SPI_BCC_SCK_SOURCE GPIO_PinSource3
- #define SPI_BCC_SCK_AF GPIO_AF_SPI1
- #define SPI_BCC_MISO_PIN GPIO_Pin_4
- #define SPI_BCC_MISO_GPIO_PORT GPIOB
- #define SPI_BCC_MISO_GPIO_CLK RCC_AHB1Periph_GPIOB
- #define SPI_BCC_MISO_SOURCE GPIO_PinSource4
- #define SPI_BCC_MISO_AF GPIO_AF_SPI1
- #define SPI_BCC_MOSI_PIN GPIO_Pin_5
- #define SPI_BCC_MOSI_GPIO_PORT GPIOB
- #define SPI_BCC_MOSI_GPIO_CLK RCC_AHB1Periph_GPIOB
- #define SPI_BCC_MOSI_SOURCE GPIO_PinSource5
- #define SPI_BCC_MOSI_AF GPIO_AF_SPI1
- #define SPI_BCC_CS1_PIN GPIO_Pin_11
- #define SPI_BCC_CS1_GPIO_PORT GPIOB
- #define SPI_BCC_CS1_GPIO_CLK RCC_AHB1Periph_GPIOB
- #define SPI_BCC_CS2_PIN GPIO_Pin_12
- #define SPI_BCC_CS2_GPIO_PORT GPIOC
- #define SPI_BCC_CS2_GPIO_CLK RCC_AHB1Periph_GPIOC
- #define SPI_BCC_CS3_PIN GPIO_Pin_11
- #define SPI_BCC_CS3_GPIO_PORT GPIOC
- #define SPI_BCC_CS3_GPIO_CLK RCC_AHB1Periph_GPIOC
- #define SPI_BCC_CS4_PIN GPIO_Pin_10
- #define SPI_BCC_CS4_GPIO_PORT GPIOC
- #define SPI_BCC_CS4_GPIO_CLK RCC_AHB1Periph_GPIOC
- #define SPI_BCC_CS5_PIN GPIO_Pin_15
- #define SPI_BCC_CS5_GPIO_PORT GPIOA
- #define SPI_BCC_CS5_GPIO_CLK RCC_AHB1Periph_GPIOA
- #define SPI_BCC_CS6_PIN GPIO_Pin_15
- #define SPI_BCC_CS6_GPIO_PORT GPIOA
- #define SPI_BCC_CS6_GPIO_CLK RCC_AHB1Periph_GPIOA
- #define DMA_BUFFER_SIZE 6
- #define SPI1_DMA DMA2
- #define SPI1_DMA_CLK RCC_AHB1Periph_DMA2
- #define SPI1_TX_DMA_CHANNEL DMA_Channel_3
- #define SPI1_TX_DMA_STREAM DMA2_Stream3
- #define SPI1_TX_DMA_FLAG_TCIF DMA_FLAG_TCIF3
- #define SPI1_RX_DMA_CHANNEL DMA_Channel_3
- #define SPI1_RX_DMA_STREAM DMA2_Stream2
- #define SPI1_RX_DMA_FLAG_TCIF DMA_FLAG_TCIF3
这是配置:
- static void SPI_BCC_Config(void)
- /* Structure definition */
- GPIO_InitTypeDef GPIO_InitStructure;
- SPI_InitTypeDef SPI_InitStructure;
- DMA_InitTypeDef DMA_InitStructure;
- /* Peripheral Clock Enable -------------------------------------------------*/
- /* Enable the SPI clock */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
- /* Enable GPIO clocks */
- RCC_AHB1PeriphClockCmd(SPI_BCC_SCK_GPIO_CLK | SPI_BCC_MISO_GPIO_CLK | SPI_BCC_MOSI_GPIO_CLK, ENABLE);
- /* Enable DMA clock */
- RCC_AHB1PeriphClockCmd(SPI1_DMA_CLK, ENABLE);
- /* SPI GPIO Configuration --------------------------------------------------*/
- /* GPIO Deinitialisation */
- GPIO_DeInit(SPI_BCC_SCK_GPIO_PORT);
- GPIO_DeInit(SPI_BCC_MISO_GPIO_PORT);
- GPIO_DeInit(SPI_BCC_MOSI_GPIO_PORT);
- /* Connect SPI pins to AF1 */
- GPIO_PinAFConfig(SPI_BCC_SCK_GPIO_PORT, SPI_BCC_SCK_SOURCE, SPI_BCC_SCK_AF);
- GPIO_PinAFConfig(SPI_BCC_MISO_GPIO_PORT, SPI_BCC_MISO_SOURCE, SPI_BCC_MISO_AF);
- GPIO_PinAFConfig(SPI_BCC_MOSI_GPIO_PORT, SPI_BCC_MOSI_SOURCE, SPI_BCC_MOSI_AF);
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_25MHz;
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
- /* SPI SCK pin configuration */
- GPIO_InitStructure.GPIO_Pin = SPI_BCC_SCK_PIN;
- GPIO_Init(SPI_BCC_SCK_GPIO_PORT, &GPIO_InitStructure);
- /* SPI MOSI pin configuration */
- GPIO_InitStructure.GPIO_Pin = SPI_BCC_MOSI_PIN;
- GPIO_Init(SPI_BCC_MOSI_GPIO_PORT, &GPIO_InitStructure);
- /* SPI MISO pin configuration */
- //GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
- //GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
- GPIO_InitStructure.GPIO_Pin = SPI_BCC_MISO_PIN;
- GPIO_Init(SPI_BCC_MISO_GPIO_PORT, &GPIO_InitStructure);
- /* SPI configuration -------------------------------------------------------*/
- SPI_I2S_DeInit(SPI_BCC);
- SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
- SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
- SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
- SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
- SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
- SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128;
- SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
- SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
- SPI_InitStructure.SPI_CRCPolynomial = 7;
- /* Initializes the SPI configuration */
- SPI_Init(SPI_BCC, &SPI_InitStructure);
- /* DMA configuration -------------------------------------------------------*/
- /* Deinitialize DMA Streams */
- DMA_DeInit(SPI1_TX_DMA_STREAM);
- DMA_DeInit(SPI1_RX_DMA_STREAM);
- /* Configure DMA Initialization Structure */
- DMA_InitStructure.DMA_BufferSize = DMA_BUFFER_SIZE ;
- DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable ;
- DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_1QuarterFull ;
- DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single ;
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
- DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
- DMA_InitStructure.DMA_PeripheralBaseAddr =(uint32_t) (&(SPI1->DR)) ;
- DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- DMA_InitStructure.DMA_Priority = DMA_Priority_High;
- /* Configure TX DMA */
- DMA_InitStructure.DMA_Channel = SPI1_TX_DMA_CHANNEL ;
- DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral ;
- DMA_InitStructure.DMA_Memory0BaseAddr =(uint32_t)DMA_SPIBufferTx ;
- DMA_Init(SPI1_TX_DMA_STREAM, &DMA_InitStructure);
- /* Configure RX DMA */
- DMA_InitStructure.DMA_Channel = SPI1_RX_DMA_CHANNEL ;
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory ;
- DMA_InitStructure.DMA_Memory0BaseAddr =(uint32_t)DMA_SPIBufferRx ;
- DMA_Init(SPI1_RX_DMA_STREAM, &DMA_InitStructure);
- /* Enable the SPI peripheral */
- SPI_Cmd(SPI_BCC, ENABLE);
这就是处理传输和接收的:
- bcc_status_t BCC_MCU_TransferSpi(uint8_t dev, uint8_t transBuf[], uint8_t recvBuf[])
- /*Copy Frame to buffer*/
- for (SPI_Buf_idx = 0; SPI_Buf_idx < DMA_BUFFER_SIZE; SPI_Buf_idx++)
- DMA_SPIBufferTx[SPI_Buf_idx] = transBuf[SPI_Buf_idx];
- /*Set Chip select to LOW level*/
- BCC_MCU_WriteCsbPin(dev, 0);
- /*Enable DMA transfer*/
- DMA_Cmd(SPI1_TX_DMA_STREAM, ENABLE);
- DMA_Cmd(SPI1_RX_DMA_STREAM, ENABLE);
- /* Enable SPI DMA TX Request */
- SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Tx, ENABLE);
- /* Enable SPI DMA RX Request */
- SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Rx, ENABLE);
- /* Waiting the end of Data transfer */
- while (SPI1_TX_DMA_STREAM->NDTR==RESET)DONOTHING()
- while(SPI_GetFlagStatus(SPI_BCC,SPI_FLAG_BSY)== SET)DONOTHING()
- /* Clear DMA Transfer Complete Flags */
- DMA_ClearFlag(SPI1_TX_DMA_STREAM,SPI1_TX_DMA_FLAG_TCIF);
- DMA_ClearFlag(SPI1_RX_DMA_STREAM,SPI1_RX_DMA_FLAG_TCIF);
- /* Disable DMA SPI TX Stream */
- DMA_Cmd(SPI1_TX_DMA_STREAM,DISABLE);
- /* Disable DMA SPI RX Stream */
- DMA_Cmd(SPI1_RX_DMA_STREAM,DISABLE);
- /* Disable SPI DMA TX Requsts */
- SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Tx, DISABLE);
- /* Disable SPI DMA RX Requsts */
- SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Rx, DISABLE);
- /*Set Chip select to HIGH level*/
- BCC_MCU_WriteCsbPin(dev, 1);
- //Flush_RxBuffer();
- /* Store received data to recvBuf. */
- recvBuf[SPI_Buf_idx]= DMA_SPIBufferRx[SPI_Buf_idx];
- //printf("0x%x ",DMA_SPIBufferRx[SPI_Buf_idx]);
- //printf("nr");
- return BCC_STATUS_SUCCESS;
我看不出问题是什么。我怀疑这些旗帜,但我看不出有什么问题。
