嗨,大家好,
在使用“portYIELD_FROM_ISR(pxHigherPriorityTaskWoken)”后进行处理;程序被扔进了这个
端口:ARM_CM7
堆:HEAP4
- .section .text.Default_Handler,"ax",%progbits
- Default_Handler:
- Infinite_Loop:
- b Infinite_Loop
- .size Default_Handler, .-Default_Handler
我不知道这是什么原因,如果有任何提示或建议如何解决这个问题,我将不胜感激
freeRTOSConfig.h
- * FreeRTOS Kernel V10.2.1
- * Copyright (C) 2019 Amazon.com, Inc. or its affiliates. All Rights Reserved.
- * Permission is hereby granted, free of charge, to any person obtaining a copy of
- * this software and associated documentation files (the "Software"), to deal in
- * the Software without restriction, including without limitation the rights to
- * use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
- * the Software, and to permit persons to whom the Software is furnished to do so,
- * subject to the following conditions:
- * The above copyright notice and this permission notice shall be included in all
- * copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
- * FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
- * COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
- * IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
- * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
- * 1 tab == 4 spaces!
- #ifndef FREERTOS_CONFIG_H
- #define FREERTOS_CONFIG_H
- * this is a template configuration files
- * These definitions should be adjusted for your particular hardware and
- * application requirements.
- * These parameters and more are described within the 'configuration' section of the
- * FreeRTOS API documentation available on the FreeRTOS.org web site.
- * See
- /* Ensure stdint is only used by the compiler, and not the assembler. */
- #if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__)
- #include
- #include "projectConfigure.h"
- extern uint32_t SystemCoreClock;
- #endif
- /* CMSIS-RTOSv2 defines 56 levels of priorities. To be able to use them
- * all and avoid application misbehavior, configUSE_PORT_OPTIMISED_TASK_SELECTION
- * must be set to 0 and configMAX_PRIORITIES to 56
- /* #define configUSE_PORT_OPTIMISED_TASK_SELECTION 0*/
- /* #define configMAX_PRIORITIES ( 56 ) */
- #define configUSE_PREEMPTION 1
- #define configUSE_IDLE_HOOK 0
- #define configUSE_TICK_HOOK 0
- #define configMAX_PRIORITIES (7)
- #define configSUPPORT_STATIC_ALLOCATION 0
- #define configCPU_CLOCK_HZ (SystemFreq)
- #define configTICK_RATE_HZ ((TickType_t)1000)
- #define configMINIMAL_STACK_SIZE ((uint16_t)128)
- #define configTOTAL_HEAP_SIZE ((size_t)(15 * 1024))
- #define configMAX_TASK_NAME_LEN (16)
- #define configUSE_TRACE_FACILITY 1
- #define configUSE_16_BIT_TICKS 0
- #define configIDLE_SHOULD_YIELD 1
- #define configUSE_MUTEXES 1
- #define configQUEUE_REGISTRY_SIZE 8
- #define configCHECK_FOR_STACK_OVERFLOW 0
- #define configUSE_RECURSIVE_MUTEXES 1
- #define configUSE_MALLOC_FAILED_HOOK 0
- #define configUSE_APPLICATION_TASK_TAG 0
- #define configUSE_COUNTING_SEMAPHORES 1
- #define configGENERATE_RUN_TIME_STATS 0
- /* Co-routine definitions. */
- #define configUSE_CO_ROUTINES 0
- #define configMAX_CO_ROUTINE_PRIORITIES (2)
- /* Software timer definitions. */
- #define configUSE_TIMERS 0
- #define configTIMER_TASK_PRIORITY (2)
- #define configTIMER_QUEUE_LENGTH 10
- #define configTIMER_TASK_STACK_DEPTH (configMINIMAL_STACK_SIZE * 2)
- /* Set the following definitions to 1 to include the API function, or zero
- to exclude the API function. */
- #define INCLUDE_vTaskPrioritySet 1
- #define INCLUDE_uxTaskPriorityGet 1
- #define INCLUDE_vTaskDelete 1
- #define INCLUDE_vTaskCleanUpResources 0
- #define INCLUDE_vTaskSuspend 1
- #define INCLUDE_vTaskDelayUntil 0
- #define INCLUDE_vTaskDelay 1
- #define INCLUDE_xTaskGetSchedulerState 1
- /*------------- CMSIS-RTOS V2 specific defines -----------*/
- /* When using CMSIS-RTOSv2 set configSUPPORT_STATIC_ALLOCATION to 1
- * is mandatory to avoid compile errors.
- * CMSIS-RTOS V2 implmentation requires the following defines
- #define configSUPPORT_STATIC_ALLOCATION 1 <-- cmsis_os threads are created using xTaskCreateStatic() API
- #define configMAX_PRIORITIES (56) <-- Priority range in CMSIS-RTOS V2 is [0 .. 56]
- #define configUSE_PORT_OPTIMISED_TASK_SELECTION 0 <-- when set to 1, configMAX_PRIORITIES can't be more than 32 which is not suitable for the new CMSIS-RTOS v2 priority range
- /* the CMSIS-RTOS V2 FreeRTOS wrapper is dependent on the heap implementation used
- * by the application thus the correct define need to be enabled from the list
- * below
- //define USE_FreeRTOS_HEAP_1
- //define USE_FreeRTOS_HEAP_2
- //define USE_FreeRTOS_HEAP_3
- //define USE_FreeRTOS_HEAP_4
- //define USE_FreeRTOS_HEAP_5
- /* Cortex-M specific definitions. */
- #ifdef __NVIC_PRIO_BITS
- /* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
- #define configPRIO_BITS __NVIC_PRIO_BITS
- #else
- #define configPRIO_BITS 4 /* 15 priority levels */
- #endif
- /* The lowest interrupt priority that can be used in a call to a "set priority"
- function. */
- #define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 0xf
- /* The highest interrupt priority that can be used by any interrupt service
- routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
- INTERRUPT SAFE FREERTOS API FUNCTIONS FROM ANY INTERRUPT THAT HAS A HIGHER
- PRIORITY THAN THIS! (higher priorities are lower numeric values. */
- #define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
- /* Interrupt priorities used by the kernel port layer itself. These are generic
- to all Cortex-M ports, and do not rely on any particular library functions. */
- #define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
- /* !!!! configMAX_SYSCALL_INTERRUPT_PRIORITY must not be set to zero !!!!
- See */
- #define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
- /* Normal assert() semantics without relying on the provision of an assert.h
- header file. */
- #define configASSERT( x ) if( ( x ) == 0 ) { taskDISABLE_INTERRUPTS(); for( ;; ); }
- /* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
- standard names. */
- #define vPortSVCHandler SVC_Handler
- #define xPortPendSVHandler PendSV_Handler
- #define xPortSysTickHandler SysTick_Handler
- /* IMPORTANT: FreeRTOS is using the SysTick as internal time base, thus make sure the system and peripherials are
- using a different time base (TIM based for example).
- #endif /* FREERTOS_CONFIG_H */
有问题的 ISR:
- extern "C" void DMA1_Stream0_IRQHandler() {
- uint8_t temp = 1;
- BaseType_t pxHigherPriorityTaskWoken = pdFALSE;
- LL_DMA_ClearFlag_TC0(DMA1);
- xQueueSendFromISR(CLI::CLIQueue, &temp, &pxHigherPriorityTaskWoken);
- portYIELD_FROM_ISR(pxHigherPriorityTaskWoken);
1个回答
