本文主要分享在软通动力子公司扬帆系列“竞”OpenHarmony开发板上运行一个ets版本的应用权限申请并验证权限的案例。
1、新建工程
选择OpenHarmony中Empty Ability如图
输入Project name,Bundle Name 并选择Project type:Application,Compile SDK:9,Model:stage,Language:ets 如下图:
Bundle Name在后续的权限申请中会用到可以先记下。
ets新建工程指导可参考:https://gitee.com/openharmony/docs/blob/master/zh-cn/application-dev/quick-start/start-with-ets-stage.md
2、主要的代码修改说明
主要修改以下三个文件
src/main/ets/MainAbility/MainAbility.ts
src/main/ets/pages/index.ets
src/main/module.json5
详细说明如下
2.1 在module.json5中添加需要申请的权限
本文以申请MICROPHONE和READ_MEDIA为例,加入"requestPermissions"字段,修改后的src/main/module.json5文件如下:
"module": {
"name": "entry",
"type": "entry",
"srcEntrance": "./ets/Application/MyAbilityStage.ts",
"description": "$string:entry_desc",
"mainElement": "MainAbility",
"deviceTypes": [
"default",
"tablet"
"deliveryWithInstall": true,
"installationFree": false,
"pages": "$profile:main_pages",
"abilities": [
"name": "MainAbility",
"srcEntrance": "./ets/MainAbility/MainAbility.ts",
"description": "$string:MainAbility_desc",
"icon": "$media:icon",
"label": "$string:MainAbility_label",
"startWindowIcon": "$media:icon",
"startWindowBackground": "$color:white",
"visible": true,
"skills": [
"entities": [
"entity.system.home"
"actions": [
"action.system.home"
"requestPermissions": [
"name": "ohos.permission.MICROPHONE"
"name": "ohos.permission.READ_MEDIA"
2.2 在MainAbility.ts中保存ability的上下文context
src/main/ets/MainAbility/MainAbility.ts的 onWindowStageCreate 生命周期中添加globalThis.context = this.context以供在index.ets中调用,修改后的onWindowStageCreate如下:
onWindowStageCreate(windowStage: Window.WindowStage) {
// Main window is created, set main page for this ability
hilog.isLoggable(0x0000, 'testTag', hilog.LogLevel.INFO);
hilog.info(0x0000, 'testTag', '%{public}s', 'Ability onWindowStageCreate');
windowStage.loadContent('pages/index', (err, data) => {
if (err.code) {
hilog.isLoggable(0x0000, 'testTag', hilog.LogLevel.ERROR);
hilog.error(0x0000, 'testTag', 'Failed to load the content. Cause: %{public}s', JSON.stringify(err) ?? '');
return;
hilog.info(0x0000, 'testTag', 'Succeeded in loading the content. Data: %{public}s', JSON.stringify(data) ?? '');
globalThis.context = this.context;
这一步是比较关键的如果是在ets中通过featureAbility.getContext()是无法弹出权限申请框的。
2.3 在index.ets中申请并检查相关权限
在request的时候需要用到globalThis.context。在check中getApplicationInfo要填入应用的Bundle Name。src/main/ets/pages/index.ets完整内容如下:
import bundle from '@ohos.bundle'
import abilityAccessCtrl from '@ohos.abilityAccessCtrl'
import prompt from '@ohos.prompt'
@Entry
@Component
struct Index {
private permissions =
["ohos.permission.MICROPHONE",
"ohos.permission.READ_MEDIA",
private async check(permission) {
let bundleFlag = 0
let userId = 100
let appInfo = await bundle.getApplicationInfo('com.soon.testpermissions', bundleFlag, userId)
let tokenId = appInfo.accessTokenId
console.info(`soonpermissions grantPermission,tokenId=${tokenId}`)
let atManager = abilityAccessCtrl.createAtManager()
let result = await atManager.verifyAccessToken(tokenId, permission)
console.info(`soonpermissions grantPermission,verifyPermission,result=${result}`)
return result == abilityAccessCtrl.GrantStatus.PERMISSION_DENIED
private request(targetPermissionArray, callback) {
if (targetPermissionArray instanceof Array && targetPermissionArray.length > 0) {
console.info('soonpermissions SysPermissionUtils requestPermissionsFromUser start. length: ' + targetPermissionArray.length);
globalThis.context.requestPermissionsFromUser(targetPermissionArray, (result) => {
console.info('soonpermissions SysPermissionUtils featureAbility requestPermissionsFromUser successful. result: ' + JSON.stringify(result));
callback(result.code === 0)
aboutToAppear() {
this.check("ohos.permission.MICROPHONE").then((isNeedPermission) => {
if (isNeedPermission) {
this.request(this.permissions, (isAuth) => {
console.info('soonpermissions request ')
} else {
console.info('soonpermissions isNeedPermission false')
build() {
Row() {
Column() {
Button($r('app.string.microphone'))
.height('15%')
.fontSize(30)
.fontWeight(FontWeight.Bold)
.onClick(() => {
prompt.showToast({ message: $r('app.string.unauthorization')})
} else {
prompt.showToast({ message: $r('app.string.authorization')})
Button($r('app.string.readmedia'))
.margin('10pv')
.height('15%')
.fontSize(30)
.onClick(() => {
this.check("ohos.permission.READ_MEDIA").then((isNeedPermission) => {
} else {
.width('100%')
.height('100%')
以上有用到字符串资源另外需要在src/main/resources/base/element/string.json加入以下
"name": "authorization",
"value": "Permissions have been granted"
"name": "unauthorization",
"value": "Permissions were not granted"
"name": "microphone",
"value": "Detect MICROPHONE Permissions"
"name": "readmedia",
"value": "Detect READ_MEDIA Permissions"
预览效果如下:
至此代码修改完毕
3 运行测试
在软通动力子公司扬帆系列“竞”OpenHarmony开发板上进行测试,第一次运行hap的时候会弹出权限,申请对话框。
麦克风使用权限申请如下图:
访问媒体和文件权限申请如下图:
权限检查页面:
主要源码:*附件:TestPermissions.zip
演示视频见底部视频
