Python开发环境体验:2048游戏
前言
查看开发板部署了Python3.8.2的环境,可以使用python进行开发。支持python等脚本开发的话对应于很多轻量级开发场景会非常快速便捷,所以我们也简单测试下使用python 编写2048小游戏进行测试。
root@okg2l:~# python3 --version
Python 3.8.2
root@okg2l:~#
准备
参考https://bbs.elecfans.com/jishu_2299841_1_1.html开发环境搭建
基本的登录文件传输等操作。
2048小游戏代码
vi 2048.py
按键i进入编辑模式
复制黏贴如下代码
import random
import os, sys
v = [[0, 0, 0, 0],
[0, 0, 0, 0],
[0, 0, 0, 0],
[0, 0, 0, 0]]
def display(v, score):
print ("%4d %4d %4d %4d" % (v[0][0], v[0][1], v[0][2], v[0][3]))
print ("%4d %4d %4d %4d" % (v[1][0], v[1][1], v[1][2], v[1][3]))
print ("%4d %4d %4d %4d" % (v[2][0], v[2][1], v[2][2], v[2][3]))
print ("%4d %4d %4d %4d" % (v[3][0], v[3][1], v[3][2], v[3][3]))
print ("Total score: %d" % score)
def init(v):
for i in range(4):
v[i] = [random.choice([0, 0, 0, 2, 2, 4]) for x in range(4)]
def align(vList, direction):
for i in range(vList.count(0)):
vList.remove(0)
zeros = [0 for x in range(4 - len(vList))]
if direction == 'left':
vList.extend(zeros)
else:
vList[:0] = zeros
def addSame(vList, direction):
score = 0
for i in [0, 1, 2]:
if vList[i] == vList[i+1] != 0:
vList[i] *= 2
vList[i+1] = 0
score += vList[i]
return {'bool':True, 'score':score}
else:
for i in [3, 2, 1]:
if vList[i] == vList[i-1] != 0:
vList[i] *= 2
vList[i-1] = 0
score += vList[i]
return {'bool':False, 'score':score}
def handle(vList, direction):
totalScore = 0
result = addSame(vList, direction)
while result['bool'] == True:
totalScore += result['score']
return totalScore
def operation(v):
totalScore = 0
gameOver = False
direction = 'left'
op = input('operator:')
if op in ['a','A']:
direction = 'left'
for row in range(4):
totalScore += handle(v[row], direction)
elif op in ['d','D']:
direction = 'right'
elif op in ['w', 'W']:
direction = 'left'
for col in range(4):
vList = [v[row][col] for row in range(4)]
totalScore += handle(vList, direction)
v[row][col] = vList[row]
elif op in ['s', 'S']:
direction = 'right'
else:
print ("Invalid input,please enter a charactor in [W,S,A,D] or the lower")
gameOver = True
return {'gameOver':gameOver,'score':totalScore}
N = 0
for q in v:
N += q.count(0)
if N == 0:
gameOver = True
return {'gameover':gameOver,'score':totalScore}
num = random.choice([2,2,2,4])
k = random.randrange(1, N+1)
n = 0
for i in range(4):
for j in range(4):
if v[i][j] == 0:
n += 1
if n == k:
v[i][j] = num
break
return {'gameOver':gameOver, 'score':totalScore}
init(v)
score = 0
print ("Input:W(Up) S(Down) A(Left) D(Right), press <CR>.")
while True:
os.system("clear")
display(v, score)
result = operation(v)
print (result)
if result['gameOver'] == True:
print ("Game Over, You failed!")
print ("Your total score %d" % (score))
sys.exit(1)
else:
score += result['score']
if score >= 2048:
print ("Game Over, You Win!!!")
print ("Your total score: %d" % (score))
sys.exit(0)
按esc按键
按键shift+:进入命令模式
输入wq!保存
运行
python3 2048.py
按键w,s,a,d回车分别对应上下左右。
总结
以一个小的程序体验下python开发的便捷,开发板支持的python版本也比较新Python3.8.2,能较好满足开发需求。
