Microchip PIN-44 开发分线板 此设计适用于 PIC 44 引脚 SMD 控制器。我已经将此板设计为初始版本,一旦我们在项目中使用它就会得到增强。 这种板对于原型项目非常有用。我们计划在板上添加一些必要的外围 IC。我想听听您的意见,哪些是可以包括在内的有用的外围 IC。 这是完整的组件列表 1 cl - CPl_Small:Capacitor_SMD:CP_Elec_3x5.4 2 c2 - CPl_Small:电容器_SMD:CP_Elec_3x5.4 3 c3 - C:电容器_THT:C_Disc_D3.0mm_W2.0mm_P2.50mm 4 c4 - C:电容器_THT:C_Disc_D3.0mm_W2.0mm_P2.50mm 5 cs - C : Capacitor_SMD:C_1206_3216Metric_Padl.42x1.75mm_HandSolder 6 cé - C : Capacitor_SMD:C_1206_3216Metric_Padl.42x1.75mm_HandSolder 7 c7 - C:电容器_SMD:C_1206_3216Metric_Padl.42x1.75mm_HandSolder 8 cs - C : Capacitor_SMD:C_1206_3216Metric_Padl.42x1.75mm_HandSolder 9 Dl - LED : LED _SMD:LED 1206_321é¢Metric_Padl.42x1.7S5mm_HandSolder 10 D2 - LED : LED _SMD:LED 120€_321éMetric_Padl.42x1.7S5mm_HandSolder ll dl - Conn_01x02:Connector_PinHeader_2.54mm:PinHeader_1x02_P2.54mm_Vertical 12 J2 - Conn_01x05:Connector_PinHeader_2.54mm:PinHeader_1x05_P2.54mm_Vertical 13 J3 - Conn_01x20:Connector_PinHeader_2.54mm:PinHeader_1lx20_P2.54mm_Vertical 14 J4 - Conn_01x20:Connector_PinHeader_2.54mm:PinHeader_1x20_P2.54mm_Vertical 15 Js - Conn_01x02:Connector_PinHeader_2.54mm:PinHeader_1x02_P2.54mm_Vertical 16 Rl - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.7Smm_HandSolder 17 R2 - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.75mm_HandSolder 18 R3 - R:电阻器_SMD:R_120€_321¢Metric_Padl.42x1.75mm_HandSolder 15 RS - R:电阻器_SMD:R_1206_3216Metric_Padl.42x1.75mm_HandSolder 20 swl - SW_Push : Button_Switch_THT:SW_PUSH_émm_HSmm 2l sww3 - SW_Push : Button_Switch_THT:SW_PUSH_émm_HSmm 22 Ul - 1M1117-5.0:Package_TO_SOT_SMD:SOT-223-3_TabPin2 23 U2 - PIC16F877A-IPT:封装_QFP:TOQFP-44_10xl0mm_P0.Smm 24 Yl - 水晶:Crystal:Crystal_HC49-4H Vertical PCB
704 浏览 0 评论
943 浏览 0 评论
2035 浏览 1 评论
1356 浏览 1 评论
5V供电情况下JFET前级放大电路怎么实现,JFET能不能先将信号放大到2-3mv,然后在用单运放进行1000倍左右放大?
2518 浏览 1 评论
/9
GMT+8, 2025-12-11 05:09 , Processed in 0.755319 second(s), Total 70, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
