电子发烧友论坛扫一扫,分享给好友
您好,麻烦你截一张完整的指令和信息输出图,这边看一下,可将截图发至我的邮箱(lzs@wch.cn)。或者你尝试将BOOT0接VCC重新上电下载看一下,看能否下载烧录。
Open On-Chip Debugger 0.11.0+dev-02215-gcc0ecfb6d-dirty (2022-03-10-09:55)
Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : only one transport option; autoselect 'jtag' Ready for Remote Connections Started by GNU MCU Eclipse Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : WCH-Link version 2.3 Info : wlink_init ok Info : This adapter doesn't support configurable speed Info : JTAG tap: riscv.cpu tap/device found: 0x00000001 (mfg: 0x000 (), part: 0x0000, ver: 0x0) Warn : Bypassing JTAG setup events due to errors Info : [riscv.cpu.0] datacount=2 progbufsize=8 Info : Examined RISC-V core; found 1 harts Info : hart 0: XLEN=32, misa=0x40901125 [riscv.cpu.0] Target successfully examined. Info : starting gdb server for riscv.cpu.0 on 3333 Info : Listening on port 3333 for gdb connections Info : accepting 'gdb' connection on tcp/3333 Info : device id = 0x263e7847 Info : flash size = 256kbytes Warn : Prefer GDB command "target extended-remote :3333" instead of "target remote :3333" Info : JTAG tap: riscv.cpu tap/device found: 0x00000001 (mfg: 0x000 (), part: 0x0000, ver: 0x0) Warn : Bypassing JTAG setup events due to errors Error: error writing to flash at address 0x00000000 at offset 0x00000000 Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (7754 ms). Workaround: increase "set remotetimeout" in GDB Error: failed read at 0x11, status=10614148 Assertion failed: info, file src/target/riscv/riscv-013.c, line 252 |
这是我用OpenOCD+Telnet操作的情况: program指令运行时直接奔溃了 Open On-Chip Debugger > reset init JTAG tap: riscv.cpu tap/device found: 0x00000001 (mfg: 0x000 (), part: 0x0000, ver: 0x0) Bypassing JTAG setup events due to errors > flash erase_address 0x00000000 0x40000 device id = 0x263e7847 flash size = 256kbytes erased address 0x00000000 (length 262144) in 0.212762s (1203.222 KiB/s) > program C:/MRS_DATA/workspace/xx.bin 0x00000000 JTAG tap: riscv.cpu tap/device found: 0x00000001 (mfg: 0x000 (), part: 0x0000, ver: 0x0) Bypassing JTAG setup events due to errors ** Programming Started ** error writing to flash at address 0x00000000 at offset 0x00000000 embedded:startup.tcl:1136: Error: ** Programming Failed ** in procedure 'program' in procedure 'program_error' called at file "embedded:startup.tcl", line 1201 at file "embedded:startup.tcl", line 1136 failed read at 0x11, status=0 |
使用flash write_image指令一样的结果
> reset init JTAG tap: riscv.cpu tap/device found: 0x00000001 (mfg: 0x000 (), part: 0x0000, ver: 0x0) Bypassing JTAG setup events due to errors > flash erase_address 0x00000000 0x40000 device id = 0x263e7847 flash size = 256kbytes erased address 0x00000000 (length 262144) in 0.208332s (1228.808 KiB/s) > flash write_image xxx.bin 0x00000000 bin error writing to flash at address 0x00000000 at offset 0x00000000 failed read at 0x11, status=0 |
您好,建议你先用WCHISPTool工具通过串口方式解除读保护,重新下载程序试一下,注意不要勾选启用读保护。使用串口方式下载时:BOOT0接VCC,BOOT1接GND,使用的串口工具要注意防倒灌电。串口接串口1(PA9、PA10引脚)。
只有小组成员才能发言,加入小组>>
376 浏览 0 评论
CH582M HOST发送数到设备后,提交IN一直是2A是什么问题?
879 浏览 0 评论
1480 浏览 1 评论
CH579M+RT-Thread,RTC从Sleep模式唤醒失败是什么原因?
3431 浏览 2 评论
2836 浏览 1 评论
安卓手机支持外接otg扩展坞 然后使用ch340+ch9329控制电脑吗
1832浏览 1评论
1481浏览 1评论
376浏览 0评论
879浏览 0评论
484浏览 0评论
/9
GMT+8, 2025-12-11 02:39 , Processed in 0.836322 second(s), Total 85, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1972
