电子发烧友论坛|
大家好,
我使用下图官方3.1Release版本的固件烧录Hi3516DV300,烧录后启动不了。求救各位大神。 我尝试过在启动过程中输入下面的参数也启动不了 setenv bootargs 'mem=640M console=ttyAMA0,115200 mmz=anonymous,0,0xA8000000,384M clk_ignore_unused rootdelay=10 hardware=Hi3516DV300 init=/init root=/dev/ram0 rw blkdevparts=mmcblk0:1M(boot),15M(kernel),20M(updater),2M(misc),3307M(system),256M(vendor),-(userdata)'; setenv bootcmd 'mmc read 0x0 0x82000000 0x800 0x4800; bootm 0x82000000' saveenv reset 启动挂死的位置如下: [img]blob:https://bbs.elecfans.com/9def7ebe-a705-4e1e-b8e7-153cb92504a9[/img] System startup Uncompress Ok! U-Boot 2020.01 (Nov 29 2021 - 20:29:59 +0800)hi3516dv300 DRAM: MMC: EMMC/MMC/SD controller initialization. scan edges:2 p2f:6 f2p:1 mix set temp-phase 3 scan elemnts: startp:4 endp:115 Tuning SampleClock. mix set phase:[03/07] ele:[14d/15] MMC/SD Card: MID: 0x15 Read Block: 512 Bytes Write Block: 512 Bytes Chip Size: 7456M Bytes (High Capacity) Name: "8GTF4" Chip Type: MMC Version: 0.0 Speed: 100000000Hz Bus Width: 4bit EMMC/MMC/SD controller initialization. Card did not respond to voltage select! mmc_init failed! err:-95 No SD device found ! himci: 0 (eMMC), himci: 1 Loading Environment from MMC... OK In: serial Out: serial Err: serial @@@ 5 blocks read: OK @@@ g_isRecovery = 0 @@@ bootArgs from misc = mem=640M console=ttyAMA0,115200 mmz=anonymous,0,0xA8000000,384M clk_ignore_unused androidboot.selinux=permissive skip_initramfs rootdelay=10 hardware=Hi3516DV300 d) @@@ 1 blocks read: OK @@@ bootArgs final from emmc = mem=640M console=ttyAMA0,115200 mmz=anonymous,0,0xA8000000,384M clk_ignore_unused rootdelay=10 hardware=Hi3516DV300 init=/init root=/dev/ram0 rw blkdevparts=mmcblk) Unable to use mmc for fat Net: eth0 Error: eth0 address not set. Hit any key to stop autoboot: 0 MMC read: dev # 0, block # 2048, count 18432 ... 18432 blocks read: OK 45.31 MB/s ## Booting kernel from Legacy Image at 80000000 ... Image Name: Linux-5.10.79 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 6651170 Bytes = 6.3 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image Starting kernel ... Booting Linux on physical CPU 0x0 Linux version 5.10.79 (root@78f603d1208b) (OHOS () clang version 10.0.1.480513 (llvm-project b2cadc87d64786377748bdb6bc5e6949492f01ab), GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #1 SMP 2 CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d CPU: div instructions available: patching division code CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache OF: fdt: Machine model: Hisilicon HI3516DV300 DEMO Board Memory policy: Data cache writealloc cma: Reserved 64 MiB at 0xa4000000 Zone ranges: Normal [mem 0x0000000080000000-0x00000000a7ffffff] HighMem empty Movable zone start for each node Early memory node ranges node 0: [mem 0x0000000080000000-0x00000000a7ffffff] Initmem setup node 0 [mem 0x0000000080000000-0x00000000a7ffffff] percpu: Embedded 18 pages/cpu s45004 r8192 d20532 u73728 Built 1 zonelists, mobility grouping on. Total pages: 162560 Kernel command line: mem=640M console=ttyAMA0,115200 mmz=anonymous,0,0xA8000000,384M clk_ignore_unused rootdelay=10 hardware=Hi3516DV300 init=/init root=/dev/ram0 rw blkdevparts=mmcblk0:1M(boot)) Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) mem auto-init: stack:off, heap alloc:off, heap free:off Memory: 566520K/655360K available (11264K kernel code, 1270K rwdata, 2612K rodata, 1024K init, 398K bss, 23304K reserved, 65536K cma-reserved, 0K highmem) SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 rcu: Hierarchical RCU implementation. rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies. NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 Gic dist init... random: get_random_bytes called from start_kernel+0x1f8/0x3c4 with crng_init=0 arch_timer: CPU0: Trapping CNTVCT access arch_timer: cp15 timer(s) running at 50.00MHz (phys). clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb8812736b, max_idle_ns: 440795202655 ns sched_clock: 56 bits at 50MHz, resolution 20ns, wraps every 4398046511100ns Switching to timer-based delay loop, resolution 20ns Console: colour dummy device 80x30 Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=500000) pid_max: default: 32768 minimum: 301 LSM: Security Framework initializing SELinux: Initializing. Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) CPU: Testing write buffer coherency: ok CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 Setting up static identity map for 0x80100000 - 0x80100070 rcu: Hierarchical SRCU implementation. smp: Bringing up secondary CPUs ... arch_timer: CPU1: Trapping CNTVCT access CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 smp: Brought up 1 node, 2 CPUs SMP: Total of 2 processors activated (200.00 BogoMIPS). CPU: All CPU(s) started in SVC mode. devtmpfs: initialized VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns futex hash table entries: 512 (order: 3, 32768 bytes, linear) pinctrl core: initialized pinctrl subsystem bbox: info: wait for log part [/data/lost+found] begin! NET: Registered protocol family 16 DMA: preallocated 256 KiB pool for atomic coherent allocations bbox: info: [SYSTEM] is registered successfully! bbox: info: kernel_log: (ptrval) for blackbox! audit: initializing netlink subsys (disabled) audit: type=2000 audit(0.010:1): state=initialized audit_enabled=0 res=1 hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. hw-breakpoint: maximum watchpoint size is 8 bytes. Serial: AMBA PL011 UART driver 120a0000.uart: ttyAMA0 at MMIO 0x120a0000 (irq = 29, base_baud = 0) is a PL011 rev2 printk: console [ttyAMA0] enabled uart-pl011 120a1000.uart: aliased and non-aliased serial devices found in device tree. Serial port enumeration may be unpredictable. 120a1000.uart: ttyAMA1 at MMIO 0x120a1000 (irq = 30, base_baud = 0) is a PL011 rev2 SCSI subsystem initialized u***core: registered new interface driver u***fs u***core: registered new interface driver hub u***core: registered new device driver u*** mc: Linux media interface: v0.10 videodev: Linux video capture interface: v2.00 Advanced Linux Sound Architecture Driver Initialized. clocksource: Switched to clocksource arch_sys_counter NET: Registered protocol family 2 IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) TCP: Hash tables configured (established 8192 bind 8192) UDP hash table entries: 512 (order: 2, 16384 bytes, linear) UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. hw perfevents: no interrupt-affinity property for /soc/pmu, guessing. hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available workingset: timestamp_bits=30 max_order=18 bucket_order=0 hmdfs: hmdfs_init_configfs() init configfs NFS: Registering the id_resolver key type Key type id_resolver registered Key type id_legacy registered fuse: init (API version 7.32) Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250) io scheduler mq-deadline registered io scheduler kyber registered pl061_gpio 120d0000.gpio_chip: PL061 GPIO chip registered pl061_gpio 120d1000.gpio_chip: PL061 GPIO chip registered pl061_gpio 120d2000.gpio_chip: PL061 GPIO chip registered pl061_gpio 120d3000.gpio_chip: PL061 GPIO chip registered pl061_gpio 120d4000.gpio_chip: PL061 GPIO chip registered pl061_gpio 120d5000.gpio_chip: PL061 GPIO chip registered pl061_gpio 120d6000.gpio_chip: PL061 GPIO chip registered pl061_gpio 120d7000.gpio_chip: PL061 GPIO chip registered pl061_gpio 120d8000.gpio_chip: PL061 GPIO chip registered pl061_gpio 120d9000.gpio_chip: PL061 GPIO chip registered pl061_gpio 120da000.gpio_chip: PL061 GPIO chip registered pl061_gpio 120db000.gpio_chip: PL061 GPIO chip registered [drm] Initialized hisilicon 1.0.0 20200602 for hidrm on minor 0 brd: module loaded hisi_nand: Failed to locate of_node [id: 0] libphy: Fixed MDIO Bus: probed libphy: hisi_femac_mii_bus: probed hisi-femac 10010000.ethernet: using random MAC address 3a:48:3c:c4:f0:c0 Generic PHY 10011100.mdio:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=10011100.mdio:01, irq=POLL) phy_id=0x001cc816, phy_mode=rmii u***core: registered new interface driver r8152 xhci-hcd 100e0000.xhci_0: can't request region for resource [mem 0x100e0000-0x100effff] xhci-hcd: probe of 100e0000.xhci_0 failed with error -16 u***core: registered new interface driver u***-storage xhci-hcd xhci-hcd.0.auto: xHCI Host Controller mousedev: PS/2 mouse device common for all mice u***core: registered new interface driver xpad xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x0000000000010010 xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0x100e0000 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected xhci-hcd xhci-hcd.0.auto: xHCI Host Controller xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed u*** u***2: We don't know the algorithms for LPM for this host, disabling LPM. hub 2-0:1.0: USB hub found hub 2-0:1.0: hub can't support USB3.0 hibvt_rtc 12080000.rtc: registered as rtc0 hibvt_rtc 12080000.rtc: setting system clock to 1970-01-01T00:00:22 UTC (22) hibvt_rtc 12080000.rtc: RTC driver for hibvt enabled i2c /dev entries driver hibvt-i2c 120b0000.i2c: IRQ index 0 not found hibvt-i2c 120b0000.i2c: hibvt-i2c0@100000hz registered hibvt-i2c 120b1000.i2c: IRQ index 0 not found hibvt-i2c 120b1000.i2c: hibvt-i2c1@100000hz registered hibvt-i2c 120b2000.i2c: IRQ index 0 not found hibvt-i2c 120b2000.i2c: hibvt-i2c2@100000hz registered hibvt-i2c 120b3000.i2c: IRQ index 0 not found hibvt-i2c 120b3000.i2c: hibvt-i2c3@100000hz registered hibvt-i2c 120b4000.i2c: IRQ index 0 not found hibvt-i2c 120b4000.i2c: hibvt-i2c4@100000hz registered hibvt-i2c 120b5000.i2c: IRQ index 0 not found hibvt-i2c 120b5000.i2c: hibvt-i2c5@100000hz registered hibvt-i2c 120b6000.i2c: IRQ index 0 not found hibvt-i2c 120b6000.i2c: hibvt-i2c6@100000hz registered hibvt-i2c 120b7000.i2c: IRQ index 0 not found hibvt-i2c 120b7000.i2c: hibvt-i2c7@100000hz registered u***core: registered new interface driver uvcvideo USB Video Class driver (1.1.1) himci: mmc host probe himci: sdio_setup entry! himci: mmc host probe mmc0: new high speed MMC card at address 0001 mmcblk0: mmc0:0001 8GTF4R 7.28 GiB mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB himci: mmc host probe mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB, chardev (248:0) mmcblk0: p1(boot) p2(kernel) p3(updater) p4(misc) p5(system) p6(vendor) p7(userdata) u***core: registered new interface driver u***hid u***hid: USB HID core driver ashmem: initialized access_token_id: access_tokenid init success NET: Registered protocol family 10 Segment Routing with IPv6 NET: Registered protocol family 17 8021q: 802.1Q VLAN Support v1.8 Key type dns_resolver registered Registering SWP/SWPB emulation handler Key type ._fscrypt registered Key type .fscrypt registered Key type fscrypt-provisioning registered [I/osal_cdev] register hdf class success [I/osal_cdev] add cdev dev_mgr success [I/osal_cdev] add cdev devsvc_mgr success [I/devmgr_service] start svcmgr result 0 [I/hcs_blob_if] CheckHcsBlobLength: the blobLength: 48408, byteAlign: 1 [I/device_node] launch devnode [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:0, count:8) [I/gpio_manager] GpioManagerAdd: start:0 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:0, count:8) succeed [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:8, count:8) [I/gpio_manager] GpioManagerAdd: start:8 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:8, count:8) succeed [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:16, count:8) [I/gpio_manager] GpioManagerAdd: start:16 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:16, count:8) succeed [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:24, count:8) [I/gpio_manager] GpioManagerAdd: start:24 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:24, count:8) succeed [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:32, count:8) [I/gpio_manager] GpioManagerAdd: start:32 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:32, count:8) succeed [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:40, count:8) [I/gpio_manager] GpioManagerAdd: start:40 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:40, count:8) succeed [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:48, count:8) [I/gpio_manager] GpioManagerAdd: start:48 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:48, count:8) succeed [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:56, count:8) [I/gpio_manager] GpioManagerAdd: start:56 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:56, count:8) succeed [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:64, count:8) [I/gpio_manager] GpioManagerAdd: start:64 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:64, count:8) succeed [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:72, count:8) [I/gpio_manager] GpioManagerAdd: start:72 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:72, count:8) succeed [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:80, count:8) [I/gpio_manager] GpioManagerAdd: start:80 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:80, count:8) succeed [I/linux_gpio_adapter] LinuxGpioMatchProbe: find gpio chip(start:88, count:8) [I/gpio_manager] GpioManagerAdd: start:88 count:8 added success [I/linux_gpio_adapter] LinuxGpioMatchProbe: add gpio controller(start:88, count:8) succeed [I/linux_gpio_adapter] LinuxGpioInit: dev service: init done! [I/device_node] launch devnode HDF_PLATFORM_GPIO_MANAGER [I/gpio_service] GpioServiceBind: enter [I/gpio_service] GpioServiceBind: success [I/osal_cdev] add cdev HDF_PLATFORM_GPIO_MANAGER success [I/device_node] launch devnode HDF_PLATFORM_MMC_0 [I/osal_cdev] add cdev HDF_PLATFORM_MMC_0 success [I/device_node] launch devnode HDF_PLATFORM_WATCHDOG_0 [I/hdf_watchdog_adapter] HdfWdtBind: entry [I/hdf_watchdog_adapter] HdfWdtBind: dev service HDF_PLATFORM_WATCHDOG_0 init success! [I/device_node] launch devnode HDF_PLATFORM_RTC [I/RTC_ADAPTER] HiRtcInit: Hdf dev service:HDF_PLATFORM_RTC init success [I/device_node] launch devnode HDF_PLATFORM_UART_1 [I/hdf_uart_adapter] HdfUartBind: entry [I/hdf_uart_adapter] HdfUartInit: entry [I/osal_cdev] add cdev HDF_PLATFORM_UART_1 success [I/device_node] launch devnode HDF_PLATFORM_UART_0 [I/hdf_uart_adapter] HdfUartBind: entry [I/hdf_uart_adapter] HdfUartInit: entry [I/device_node] launch devnode HDF_PLATFORM_I2C_MANAGER [I/i2c_core] I2cManagerBind: Enter! [I/osal_cdev] add cdev HDF_PLATFORM_I2C_MANAGER success [I/device_node] launch devnode [I/i2c_linux_adapter] LinuxI2cInit: Enter [I/i2c_linux_adapter] LinuxI2cProbe: Enter [I/i2c_core] I2cCntlrAdd: use default lock methods! [I/i2c_linux_adapter] LinuxI2cProbe: i2c adapter 0 add success [I/i2c_linux_adapter] LinuxI2cProbe: Enter [I/i2c_core] I2cCntlrAdd: use default lock methods! [I/i2c_linux_adapter] LinuxI2cProbe: i2c adapter 1 add success [I/i2c_linux_adapter] LinuxI2cProbe: Enter [I/i2c_core] I2cCntlrAdd: use default lock methods! [I/i2c_linux_adapter] LinuxI2cProbe: i2c adapter 2 add success [I/i2c_linux_adapter] LinuxI2cProbe: Enter [I/i2c_core] I2cCntlrAdd: use default lock methods! [I/i2c_linux_adapter] LinuxI2cProbe: i2c adapter 3 add success [I/i2c_linux_adapter] LinuxI2cProbe: Enter [I/i2c_core] I2cCntlrAdd: use default lock methods! [I/i2c_linux_adapter] LinuxI2cProbe: i2c adapter 4 add success [I/i2c_linux_adapter] LinuxI2cProbe: Enter [I/i2c_core] I2cCntlrAdd: use default lock methods! [I/i2c_linux_adapter] LinuxI2cProbe: i2c adapter 5 add success [I/i2c_linux_adapter] LinuxI2cProbe: Enter [I/i2c_core] I2cCntlrAdd: use default lock methods! [I/i2c_linux_adapter] LinuxI2cProbe: i2c adapter 6 add success [I/i2c_linux_adapter] LinuxI2cProbe: Enter [I/i2c_core] I2cCntlrAdd: use default lock methods! [I/i2c_linux_adapter] LinuxI2cProbe: i2c adapter 7 add success [I/i2c_linux_adapter] LinuxI2cInit: done [I/device_node] launch devnode HDF_PLATFORM_SPI_2 [I/HDF_SPI_LINUX_ADAPTER] HdfSpiDeviceBind: entry [I/HDF_SPI_LINUX_ADAPTER] HdfSpiDeviceInit: entry [I/device_node] launch devnode HDF_PLATFORM_SPI_1 [I/HDF_SPI_LINUX_ADAPTER] HdfSpiDeviceBind: entry [I/HDF_SPI_LINUX_ADAPTER] HdfSpiDeviceInit: entry [I/device_node] launch devnode HDF_PLATFORM_SPI_0 [I/HDF_SPI_LINUX_ADAPTER] HdfSpiDeviceBind: entry [I/HDF_SPI_LINUX_ADAPTER] HdfSpiDeviceInit: entry [I/device_node] launch devnode HDF_PLATFORM_MMC_2 [I/device_node] launch devnode HDF_PLATFORM_PWM_1 [I/pwm_adapter] HdfPwmInit: entry [I/device_node] launch devnode HDF_PLATFORM_PWM_0 [I/pwm_adapter] HdfPwmInit: entry [I/device_node] launch devnode HDF_MIPI_TX [I/mipi_dsi_core] MipiDsiRegisterCntlr: success. mipi_dsi:create inode ok hi_mipi_tx 57 [I/mipi_tx_dev] RegisterDevice: success. [I/mipi_tx_dev] ProcRegister: success. [I/mipi_tx_dev] MipiDsiDevModuleInit: success! [I/mipi_tx_hi35xx] Hi35xxMipiTxInit: load mipi tx driver successfully! [I/device_node] launch devnode hdf_kevent [I/kevent] HdfKeventDriverInit:register pm notifier success [I/kevent] HdfKeventDriverInit:register fb notifier success [I/osal_cdev] add cdev hdf_kevent success [I/device_node] launch devnode dma_service_0 [I/audio_core] [AudioSocRegisterPlatform][line:63]: Register [dma_service_0] success. [I/hi3516_platform_adapter] [Hi3516DmaDriverInit][line:105]: success. [I/device_node] launch devnode dsp_service_0 [I/dsp_adapter] [DspDriverBind][line:39]: entry [I/dsp_adapter] [DspDriverBind][line:46]: success [I/dsp_adapter] [DspDriverInit][line:52]: entry [I/audio_core] [AudioSocRegisterDai][line:86]: Register [dsp_dai] success. [I/audio_core] [AudioRegisterDsp][line:189]: Register [dsp_service_0] success. [I/dsp_adapter] [DspDriverInit][line:74]: success [E/devnode_ext] device service interface is null [I/device_node] release devnode dsp_service_0 [I/dsp_adapter] [DspDriverRelease][line:81]: entry [E/dsp_adapter] [DspDriverRelease][line:89]: DspHost is NULL [E/devmgr_service] devmgr detach device 7000401 not found [E/devhost_service_clnt] failed to install driver dsp_service_0, ret = -205 [I/device_node] launch devnode codec_service_1 [I/"accessory"] [Tfa9879DriverBind][line:65]: success! [I/audio_core] [AudioSocRegisterDai][line:86]: Register [accessory_dai] success. [I/audio_core] [AudioRegisterAccessory][line:121]: Register [codec_service_1] success. [I/"accessory"] [Tfa9879DriverInit][line:94]: success! [E/devnode_ext] device service interface is null [I/device_node] release devnode codec_service_1 [E/devmgr_service] devmgr detach device 7000301 not found [E/devhost_service_clnt] failed to install driver codec_service_1, ret = -205 [I/device_node] launch devnode codec_service_0 [I/audio_core] [AudioSocRegisterDai][line:86]: Register [codec_dai] success. [I/audio_core] [AudioRegisterCodec][line:156]: Register [codec_service_0] success. [I/device_node] launch devnode dai_service [I/audio_core] [AudioSocRegisterDai][line:86]: Register [dai_service] success. [I/device_node] launch devnode hdf_audio_smartpa_dev0 [I/audio_host] [AudioDriverBind][line:354]: success. [I/audio_host] [AudioPlatformDevInit][line:134]: success. [I/audio_host] [AudioCpuDaiDevInit][line:255]: success. mmc2: new high speed SDIO card at address 0001 [I/audio_host] [AudioCodecDevInit][line:74]: success. [I/audio_host] [AudioCodecDaiDevInit][line:195]: success. hibvt-i2c 120b6000.i2c: wait idle abort!, RIS: 0x611 [E/"audio_accessory_base"] [AccessoryI2cReadWrite][line:140]: I2cTransfer err:-5 [E/"audio_accessory_base"] [AccessoryDeviceCtrlRegInit][line:367]: AccessoryI2cReadWrite(write) err, regAttr.regAddr: 0x0. [E/"tfa9879_codec"] [Tfa9879DeviceInit][line:131]: AccessoryDeviceRegInit failed. [E/audio_host] [AudioAccessoryDevInit][line:99]: accessory initialization fail ret=-1 [E/audio_host] [AudioInitDaiLink][line:307]: Accessory Device init fail. [I/dsp_ops] [DspSpiOpen][line:204]: DspSpiOpen success [I/audio_host] [AudioDspDevInit][line:165]: success. [I/audio_host] [AudioDspDaiDevInit][line:286]: success. [I/audio_host] [AudioDriverInit][line:417]: success. [I/osal_cdev] add cdev hdf_audio_smartpa_dev0 success [I/device_node] launch devnode hdf_audio_codec_dev0 [I/audio_host] [AudioDriverBind][line:354]: success. [I/audio_host] [AudioPlatformDevInit][line:134]: success. [I/audio_host] [AudioCpuDaiDevInit][line:255]: success. [I/audio_host] [AudioCodecDevInit][line:74]: success. [I/audio_host] [AudioCodecDaiDevInit][line:195]: success. [I/audio_host] [AudioAccessoryDevInit][line:104]: success. [I/audio_host] [AudioAccessoryDaiDevInit][line:225]: success. [I/dsp_ops] [DspSpiOpen][line:204]: DspSpiOpen success [I/audio_host] [AudioDspDevInit][line:165]: success. [I/audio_host] [AudioDspDaiDevInit][line:286]: success. [I/audio_host] [AudioDriverInit][line:417]: success. [I/osal_cdev] add cdev hdf_audio_codec_dev0 success [I/device_node] launch devnode hdf_audio_control [I/audio_control_dispatch] [AudioControlBind][line:296]: success. [I/audio_control_dispatch] [AudioControlInit][line:303]: success. [I/osal_cdev] add cdev hdf_audio_control success [I/device_node] launch devnode hdf_audio_capture [I/audio_stream_dispatch] [AudioStreamBind][line:1526]: success! [I/audio_stream_dispatch] [AudioStreamInit][line:1546]: Success! [I/osal_cdev] add cdev hdf_audio_capture success [I/device_node] launch devnode hdf_audio_render [I/audio_stream_dispatch] [AudioStreamBind][line:1526]: success! [I/audio_stream_dispatch] [AudioStreamInit][line:1546]: Success! [I/osal_cdev] add cdev hdf_audio_render success [I/device_node] launch devnode hdf_light [I/osal_cdev] add cdev hdf_light success [I/device_node] launch devnode hdf_dsoftbus [E/"hdf_dsoftbus"] softbus driver bind success [I/"wlan_param_monitor"] SoftbusWlanParamMonitorInit init [E/"hdf_dsoftbus"] init softbus module manager success [I/osal_cdev] add cdev hdf_dsoftbus success [I/device_node] launch devnode hdf_misc_vibrator [I/osal_cdev] add cdev hdf_misc_vibrator success [I/device_node] launch devnode hdf_misc_linear_vibrator [I/device_node] launch devnode hdf_u***_pnp_notify_service [I/USB_PNP_NOTIFY] U***PnpNotifyBind: Enter! [I/USB_PNP_NOTIFY] U***PnpNotifyInit: Enter! [I/osal_cdev] add cdev hdf_u***_pnp_notify_service success [I/device_node] launch devnode hdf_sensor_manager_ap [I/hdf_sensor_commom] InitSensorDevManager: init sensor manager successfully [I/osal_cdev] add cdev hdf_sensor_manager_ap success [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_PEDOMETER [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_PEDOMETER not found [E/devhost_service_clnt] failed to install driver hdf_sensor_pedometer, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_PROXIMITY [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_PROXIMITY not found [E/devhost_service_clnt] failed to install driver hdf_sensor_proximity, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_MAGNETIC [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_MAGNETIC not found [E/devhost_service_clnt] failed to install driver hdf_sensor_magnetic, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_BAROMETER [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_BAROMETER not found [E/devhost_service_clnt] failed to install driver hdf_sensor_barometer, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_GYRO [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_GYRO not found [E/devhost_service_clnt] failed to install driver hdf_sensor_gyro, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_ALS [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_ALS not found [E/devhost_service_clnt] failed to install driver hdf_sensor_als, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_ACCEL [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_ACCEL not found [E/devhost_service_clnt] failed to install driver hdf_sensor_accel, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_PEDOMETER_BMI160 [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_PEDOMETER_BMI160 not found [E/devhost_service_clnt] failed to install driver hdf_pedometer_bmi160, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_PROXIMITY_APDS9960 [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_PROXIMITY_APDS9960 not found [E/devhost_service_clnt] failed to install driver hdf_proximity_apds9960, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_MAGNETIC_LSM303 [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_MAGNETIC_LSM303 not found [E/devhost_service_clnt] failed to install driver hdf_magnetic_lsm303, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_BAROMETER_BMP180 [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_BAROMETER_BMP180 not found [E/devhost_service_clnt] failed to install driver hdf_barometer_bmp180, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_GYRO_BMI160 [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_GYRO_BMI160 not found [E/devhost_service_clnt] failed to install driver hdf_gyro_bmi160, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_ALS_BH1745 [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_ALS_BH1745 not found [E/devhost_service_clnt] failed to install driver hdf_als_bh1745, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_ACCEL_BMI160 [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_ACCEL_BMI160 not found [E/devhost_service_clnt] failed to install driver hdf_accel_bmi160, ret = -207 [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_SENSOR_GRAVITY [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_SENSOR_GRAVITY not found [E/devhost_service_clnt] failed to install driver hdf_sensor_gravity, ret = -207 [I/device_node] launch devnode hdfwifi [E/KMsgEngine] DoStartMessageRouter:Create local node ... [I/KMsgEngine] Creating local node... [I/KMsgEngine] Register default dispatcher... [I/HDF_WIFI_CORE] ParseWlanChipsCompsConfig: driverName=hisi [W/KMsgEngine] DoRegistService:Register service Node:0;Dispatcher:0;Service:1 [W/KMsgEngine] DoRegistService:Register service Node:0;Dispatcher:0;Service:2 [W/KMsgEngine] DoRegistService:Register service Node:0;Dispatcher:0;Service:3 [W/KMsgEngine] DoRegistService:Register service Node:0;Dispatcher:0;Service:4 [I/osal_cdev] add cdev hdfwifi success [I/device_node] launch devnode hdf_input_host [I/HDF_LOG_TAG] HdfInputManagerInit: enter [I/HDF_LOG_TAG] HdfInputManagerInit: exit succ [I/osal_cdev] add cdev hdf_input_host success [I/device_node] launch devnode hdf_input_event1 [I/HDF_LOG_TAG] HdfTouchDriverProbe: enter [I/HDF_LOG_TAG] HdfTouchDriverProbe: main_touch exit succ [I/osal_cdev] add cdev hdf_input_event1 success [I/device_node] launch devnode hdf_touch_gt911_service [I/HDF_INPUT_DRV] HdfGoodixChipInit: enter [I/HDF_LOG_TAG] ChipMatchCheck: boardNode's father name = touch0, chipNode's grandpa name = touch0 [I/HDF_INPUT_DRV] ChipDetect: IC FW version is 0x1060 [I/HDF_INPUT_DRV] Product_ID: 911_1060, x_sol = 960, y_sol = 480 [I/HDF_LOG_TAG] ChipDriverInit: chipDetect succ, ret = 0 [I/HDF_INPUT_DRV] UpdateFirmware: update firmware success [I/HDF_LOG_TAG] ChipDriverInit: update firmware success [I/gpio_core] GpioIrqRecordCreate: gpio(4) thread started [I/linux_gpio_adapter] LinuxGpioSetIrq: gona request normal irq:75(4) [I/HDF_LOG_TAG] RegisterInputDevice: enter [E/HDF_INPUT_DRV] PushOnePackage: parm is null [I/HDF_LOG_TAG] CreateDeviceNode: create node succ, devId is 1 [E/HDF_INPUT_DRV] PushOnePackage: parm is null [E/HDF_LOG_TAG] HotPlugNotify: send event failed [E/HDF_INPUT_DRV] PushOnePackage: parm is null [I/HDF_LOG_TAG] RegisterInputDevice: exit succ, devCount is 1 [E/HDF_INPUT_DRV] PushOnePackage: parm is null [I/HDF_INPUT_DRV] HdfGoodixChipInit: exit succ, chipName = gt911 [E/HDF_INPUT_DRV] InputI2cRead fail || ouchStatus is GT_EVENT_INVALID ChipDataHandle [I/HDF_LOG_TAG] HdfDriverManagerGetDriver:try to dynamic load driver HDF_ENCODER [E/HDF_LOG_TAG] EventHandle: DataHandle failed [E/HDF_LOG_TAG] HdfDriverManagerGetDriver:driver HDF_ENCODER not found [E/HDF_INPUT_DRV] InputI2cRead fail || ouchStatus is GT_EVENT_INVALID ChipDataHandle [E/devhost_service_clnt] failed to install driver , ret = -207 [E/HDF_LOG_TAG] EventHandle: DataHandle failed [I/device_node] launch devnode [I/HDF_LOG_TAG] LoadCachedHid: exit [I/device_node] launch devnode hdf_bl [I/HDF_DISP] BacklightInit success [I/osal_cdev] add cdev hdf_bl success [I/device_node] launch devnode [I/pwm_hi35xx_linux] Hi35xxGetState: get PwmConfig: number none, period 132867, duty 66267, polarity 0, enable 0. [I/pwm_adapter] HdfPwmSetConfig: set PwmConfig: number 0, period 100000, duty 1, polarity 0, enable 1. [I/pwm_hi35xx_linux] Hi35xxPwmApply: [HiPwmDisable] done. [I/pwm_hi35xx_linux] Hi35xxPwmApply: [HiPwmSetPeriod] done, period: 132867 -> 100000. [I/pwm_hi35xx_linux] Hi35xxPwmApply: [HiPwmSetDuty] done, duty: 66267 -> 1. [I/pwm_hi35xx_linux] Hi35xxPwmApply: [HiPwmAlwaysOutput] done, then enable. [I/pwm_hi35xx_linux] Hi35xxPwmApply: set PwmConfig done: number none, period 100000, duty 1, polarity 0, enable 1. [I/pwm_hi35xx_linux] Hi35xxPwmApply: success. [I/pwm_adapter] HdfPwmSetConfig: success. [E/HDF_DISP] RegisterBlDev: success [I/pwm_adapter] HdfPwmSetConfig: set PwmConfig: number 0, period 100000, duty 49803, polarity 0, enable 1. [I/pwm_hi35xx_linux] Hi35xxPwmApply: [HiPwmDisable] done. [I/pwm_hi35xx_linux] Hi35xxPwmApply: [HiPwmSetDuty] done, duty: 1 -> 49803. [I/pwm_hi35xx_linux] Hi35xxPwmApply: [HiPwmAlwaysOutput] done, then enable. [I/pwm_hi35xx_linux] Hi35xxPwmApply: set PwmConfig done: number none, period 100000, duty 49803, polarity 0, enable 1. [I/pwm_hi35xx_linux] Hi35xxPwmApply: success. [I/pwm_adapter] HdfPwmSetConfig: success. [I/pwm_if] PwmSetDuty: success. duty: 1 -> 49803. [E/pwm_core] PwmDeviceSetConfig: do not need to set config [I/pwm_if] PwmEnable: success. enable: 1 -> 1. [I/HDF_DISP] BlPwmEntryInit: success [I/device_node] launch devnode [I/HDF_DISP] RegisterPanel: register success [I/HDF_DISP] Icn9700EntryInit: exit succ [I/device_node] launch devnode [I/mipi_dsi_core] MipiDsiCntlrClose: success! [I/HDF_DISP] MipiDsiInit:pixelClk = 31546, phyDataRate = 379 [I/device_node] launch devnode hdf_disp [I/HDF_DISP] EsdCheckInit none of panels support esd [I/HDF_DISP] HdfDispEntryInit success [I/osal_cdev] add cdev hdf_disp success [I/device_node] launch devnode pm_test_service [I/pm_driver_test] HdfPmDriverBind enter [I/pm_driver_test] HdfPmDriverInit enter! [I/pm_driver_test] HdfPmDriverInit register power listener, ret = 0 [I/osal_cdev] add cdev pm_test_service success [I/device_node] launch devnode sample_service [I/sample_driver_test] HdfSampleDriverInit::enter! [I/sample_driver_test] HdfSampleDriverInit:register power listener, ret = 0 [I/osal_cdev] add cdev sample_service success [I/device_node] launch devnode HDF_TEST [I/osal_cdev] add cdev HDF_TEST success [I/device_node] launch devnode [I/hdf_sensor_commom] AddSensorDevice: register sensor name[sensor_test] success [I/hdf_sensor_test_c] InitSensorDriverTest: init sensor test driver success [I/device_node] launch devnode UART_TEST [I/device_node] launch devnode PLATFORM_MIPI_DSI_TEST [I/device_node] launch devnode SDIO_TEST [E/sdio_test_c] SdioTestBind: Sdio_TEST service init success! [E/sdio_test_c] SdioTestFillConfig: busNum:2, funcNum:1, vendorId:0x296, deviceId:0x5347. [E/sdio_test_c] SdioTestInit: success [I/device_node] launch devnode EMMC_TEST [E/emmc_test_c] EmmcTestBind: EMMC_TEST service init success! [E/emmc_test_c] EmmcTestFillConfig: busNum:0, hostId:0. [E/emmc_test_c] EmmcTestInit: success [I/device_node] launch devnode SPI_TEST [I/device_node] launch devnode I2C_TEST [I/osal_cdev] add cdev I2C_TEST success [I/device_node] launch devnode GPIO_TEST [E/hcs_tree_if] HcsGetUint16 failed, the attr of testUserApi is NULL, or the value is NULL, the value is default value [W/HDF_LOG_TAG] GpioTestReadConfig: read gpioIrq fail, using 0 as default [I/device_node] launch devnode WATCHDOG_TEST [E/watchdog_driver_test_c] WatchdogTestBind: device or config is null! [E/device_node] bind driver PLATFORM_WATCHDOG_TEST failed [I/device_node] release devnode WATCHDOG_TEST [I/watchdog_driver_test_c] WatchdogTestRelease: Done! [E/devmgr_service] devmgr detach device b000207 not found [E/devhost_service_clnt] failed to install driver WATCHDOG_TEST, ret = -204 [I/device_node] launch devnode PWM_TEST [I/hdf_power_manager] HdfPmTaskQueueInit HdfTaskQueueCreate success clk: Not disabling unused clocks ALSA device list: No soundcards found. Waiting 10 sec before mounting root device... exFAT-fs (ram0): invalid boot record signature exFAT-fs (ram0): failed to read boot sector exFAT-fs (ram0): failed to recognize exfat type F2FS-fs (ram0): Magic Mismatch, valid(0xf2f52010) - read(0x0) F2FS-fs (ram0): Can't find valid F2FS filesystem in 1th superblock F2FS-fs (ram0): Magic Mismatch, valid(0xf2f52010) - read(0x0) F2FS-fs (ram0): Can't find valid F2FS filesystem in 2th superblock exFAT-fs (ram0): invalid boot record signature exFAT-fs (ram0): failed to read boot sector exFAT-fs (ram0): failed to recognize exfat type F2FS-fs (ram0): Magic Mismatch, valid(0xf2f52010) - read(0x0) F2FS-fs (ram0): Can't find valid F2FS filesystem in 1th superblock F2FS-fs (ram0): Magic Mismatch, valid(0xf2f52010) - read(0x0) F2FS-fs (ram0): Can't find valid F2FS filesystem in 2th superblock List of all partitions: 0100 65536 ram0 (driver?) 0101 65536 ram1 (driver?) 0102 65536 ram2 (driver?) 0103 65536 ram3 (driver?) 0104 65536 ram4 (driver?) 0105 65536 ram5 (driver?) 0106 65536 ram6 (driver?) 0107 65536 ram7 (driver?) 0108 65536 ram8 (driver?) 0109 65536 ram9 (driver?) 010a 65536 ram10 (driver?) 010b 65536 ram11 (driver?) 010c 65536 ram12 (driver?) 010d 65536 ram13 (driver?) 010e 65536 ram14 (driver?) 010f 65536 ram15 (driver?) b300 7634944 mmcblk0 driver: mmcblk b301 1024 mmcblk0p1 b302 15360 mmcblk0p2 b303 20480 mmcblk0p3 b304 2048 mmcblk0p4 b305 3386368 mmcblk0p5 b306 262144 mmcblk0p6 b307 3947520 mmcblk0p7 No filesystem could mount root, tried: ext3 ext2 ext4 cramfs vfat msdos exfat fuseblk f2fs Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(1,0) CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.79 #1 Hardware name: Generic DT based system [ [ [ [ [ [ [ [ Exception stack(0xc18ddfb0 to 0xc18ddff8) dfa0: 00000000 00000000 00000000 00000000 dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 CPU0: stopping CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.10.79 #1 Hardware name: Generic DT based system [ [ [ [ [ ------------[ cut here ]------------ WARNING: CPU: 1 PID: 14 at kernel/sched/core.c:2035 set_task_cpu+0x26c/0x270 Modules linked in: CPU: 1 PID: 14 Comm: migration/1 Not tainted 5.10.79 #1 Hardware name: Generic DT based system [ [ [ [ [ [ [ [ [ [ Exception stack(0xc1919fb0 to 0xc1919ff8) 9fa0: 00000000 00000000 00000000 00000000 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 ---[ end trace 68bb3d8c4ec13d58 ]--- |
只有小组成员才能发言,加入小组>>
2334个成员聚集在这个小组
加入小组【DAYU200开发板原理图】DAYU200板开发板没有完整原理图吗?MIPI DSI双屏同显怎么配置?
2605 浏览 0 评论
1863 浏览 1 评论
HiSpark IPC AI摄像头(Hi3518E)串口能输入输出吗?
1862 浏览 1 评论
【星闪派物联网开发套件体验连载】使用Dockerfile搭建润和WS63E的开发环境
3078 浏览 1 评论
【星闪派物联网开发套件体验连载】用HiHope星闪server端BearPi星闪client端互相发代码控制对方板载灯
3011 浏览 0 评论
13955浏览 10评论
2688浏览 2评论
2589浏览 2评论
2900浏览 2评论
DAYU200 rk3568板子烧写OpenHarmony镜像resource.img误烧写成ramdisk.img,烧写成功后无法开机无法进入loader模式,求助!!!
3933浏览 1评论
/9
GMT+8, 2025-12-14 08:17 , Processed in 0.782439 second(s), Total 76, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2549
