扫一扫,分享给好友
2个回答
上一篇文章中,描述了在用户态下通过“ioctl”接口访问24系列i2c接口的EEPROM,本文描述调用EEPROM驱动接口实现访问。linux内核提供了完整的24系列EEPROM驱动,位于“kernel/drivers/misc”目录下(at24.c),可以直接使用。
编译系统:Ubuntu16.04 ARM硬件:firefly RK3399 ARM系统:firefly Ubuntu16.04(SDK) 连接i2c:i2c4 EEPROM:AT24C02 1. EEPROM驱动分析 24系列EEPROM是以i2c为接口的,不同厂家的芯片是可以相互兼容的,如atmel、st、microchip以及一些小众品牌。内核提供的源码是基于atmel的EEPROM(at24cxx)。 1.1 私有数据 struct at24_data { struct at24_platform_data chip; /* 芯片信息 */ struct memory_accessor macc; int use_smbus; /* 如果使用smbus */ int use_smbus_write; /* * Lock protects against activities from other Linux tasks, * but not from changes by other I2C masters. */ struct mutex lock; /* 读写互斥锁 */ struct bin_attribute bin; /* 驱动匹配后生成sys目录信息 */ u8 *writebuf; /* 写缓冲区 */ unsigned write_max; /* 写限制最大空间 */ unsigned num_addresses; /* * Some chips tie up multiple I2C addresses; dummy devices reserve * them for us, and we'll use them with SMBus calls. */ struct i2c_client *client[];/* i2c总线,这里是数组形式,表示会占用“多个”i2c总线,因为24系列EEPROM小于16Mbit时是八位寻址,超过256字节地址后采用i2c从地址进行“翻页”寻址*/ }; “at24_platform_data”在“kernel/include/linux/platform_data/at24.h”中声明。 struct at24_platform_data { u32 byte_len; /* size (sum of all addr) */ u16 page_size; /* for writes */ u8 flags; #define AT24_FLAG_ADDR16 0x80 /* address pointer is 16 bit */ #define AT24_FLAG_READONLY 0x40 /* sysfs-entry will be read-only */ #define AT24_FLAG_IRUGO 0x20 /* sysfs-entry will be world-readable */ #define AT24_FLAG_TAKE8ADDR 0x10 /* take always 8 addresses (24c00) */ void (*setup)(struct memory_accessor *, void *context); void *context; }; 1.2 常用型号匹配表 源码已经实现常用器件型号描述表,“struct i2c_device_id ”属性中,第一个是器件型号,第二个是器件i2c地址,描述表中器件的A0—A2地址选择脚默认是接地(0)。使用设备树描述时,“.compatible”属性必须与第一个属性一致(器件型号)。 static const struct i2c_device_id at24_ids[] = { /* needs 8 addresses as A0-A2 are ignored */ { "24c00", AT24_DEVICE_MAGIC(128 / 8, AT24_FLAG_TAKE8ADDR) }, /* old variants can't be handled with this generic entry! */ { "24c01", AT24_DEVICE_MAGIC(1024 / 8, 0) }, { "24c02", AT24_DEVICE_MAGIC(2048 / 8, 0) }, /* spd is a 24c02 in memory DIMMs */ { "spd", AT24_DEVICE_MAGIC(2048 / 8, AT24_FLAG_READONLY | AT24_FLAG_IRUGO) }, { "24c04", AT24_DEVICE_MAGIC(4096 / 8, 0) }, /* 24rf08 quirk is handled at i2c-core */ { "24c08", AT24_DEVICE_MAGIC(8192 / 8, 0) }, { "24c16", AT24_DEVICE_MAGIC(16384 / 8, 0) }, { "24c32", AT24_DEVICE_MAGIC(32768 / 8, AT24_FLAG_ADDR16) }, { "24c64", AT24_DEVICE_MAGIC(65536 / 8, AT24_FLAG_ADDR16) }, { "24c128", AT24_DEVICE_MAGIC(131072 / 8, AT24_FLAG_ADDR16) }, { "24c256", AT24_DEVICE_MAGIC(262144 / 8, AT24_FLAG_ADDR16) }, { "24c512", AT24_DEVICE_MAGIC(524288 / 8, AT24_FLAG_ADDR16) }, { "24c1024", AT24_DEVICE_MAGIC(1048576 / 8, AT24_FLAG_ADDR16) }, { "at24", 0 }, { /* END OF LIST */ } }; 1.3 读函数 static ssize_t at24_eeprom_read(struct at24_data *at24, char *buf, unsigned offset, size_t count) { struct i2c_msg msg[2]; /* i2c总线消息 */ u8 msgbuf[2]; struct i2c_client *client; unsigned long timeout, read_time; int status, i; memset(msg, 0, sizeof(msg)); /* * REVISIT some multi-address chips don't rollover page reads to * the next slave address, so we may need to truncate the count. * Those chips might need another quirk flag. * * If the real hardware used four adjacent 24c02 chips and that * were misconfigured as one 24c08, that would be a similar effect: * one "eeprom" file not four, but larger reads would fail when * they crossed certain pages. */ /* * Slave address and byte offset derive from the offset. Always * set the byte address; on a multi-master board, another master * may have changed the chip's "current" address pointer. */ client = at24_translate_offset(at24, &offset);/* 获取翻页偏移地址(总线)0x50/0x51/0x52等 */ if (count > io_limit) count = io_limit; if (at24->use_smbus) { /* Smaller eeproms can work given some SMBus extension calls */ if (count > I2C_SMBUS_BLOCK_MAX) count = I2C_SMBUS_BLOCK_MAX; } else { /* * When we have a better choice than SMBus calls, use a * combined I2C message. Write address; then read up to * io_limit data bytes. Note that read page rollover helps us * here (unlike writes). msgbuf is u8 and will cast to our * needs. */ i = 0; if (at24->chip.flags & AT24_FLAG_ADDR16) /* 16bit寻址时处理,先传输高8bit地址 */ msgbuf[i++] = offset >> 8; msgbuf[i++] = offset; msg[0].addr = client->addr; msg[0].buf = msgbuf; msg[0].len = i; msg[1].addr = client->addr; /* i2c从地址 */ msg[1].flags = I2C_M_RD; /* 读标识 */ msg[1].buf = buf; msg[1].len = count; } /* * Reads fail if the previous write didn't complete yet. We may * loop a few times until this one succeeds, waiting at least * long enough for one entire page write to work. */ timeout = jiffies + msecs_to_jiffies(write_timeout); do { read_time = jiffies; if (at24->use_smbus) { /* 使用smbus总线 */ status = i2c_smbus_read_i2c_block_data_or_emulated(client, offset, count, buf); } else { status = i2c_transfer(client->adapter, msg, 2); /* 使用i2c总线(默认)*/ if (status == 2) status = count; } dev_dbg(&client->dev, "read %zu@%d --> %d (%ld)n", count, offset, status, jiffies); if (status == count) return count; /* REVISIT: at HZ=100, this is sloooow */ msleep(1); } while (time_before(read_time, timeout)); /* 读超时处理 */ return -ETIMEDOUT; } 1.4 写函数 static ssize_t at24_eeprom_write(struct at24_data *at24, const char *buf, unsigned offset, size_t count) { struct i2c_client *client; struct i2c_msg msg; /* i2c总线消息 */ ssize_t status = 0; unsigned long timeout, write_time; unsigned next_page; if (offset + count > at24->chip.byte_len) return -EINVAL; /* Get corresponding I2C address and adjust offset */ client = at24_translate_offset(at24, &offset); /* 获取翻页偏移地址(总线)0x50/0x51/0x52等 */ /* write_max is at most a page */ if (count > at24->write_max) /* 限制范围 */ count = at24->write_max; /* Never roll over backwards, to the start of this page */ next_page = roundup(offset + 1, at24->chip.page_size);/* 取整数下一块地址 */ if (offset + count > next_page) /* 计算非对块地址 */ count = next_page - offset; /* If we'll use I2C calls for I/O, set up the message */ if (!at24->use_smbus) { int i = 0; msg.addr = client->addr; msg.flags = 0; /* 写标识 */ /* msg.buf is u8 and casts will mask the values */ msg.buf = at24->writebuf; if (at24->chip.flags & AT24_FLAG_ADDR16) /* 16bit 寻址处理,先传输高8bit地址 */ msg.buf[i++] = offset >> 8; msg.buf[i++] = offset; memcpy(&msg.buf, buf, count); msg.len = i + count; } /* * Writes fail if the previous one didn't complete yet. We may * loop a few times until this one succeeds, waiting at least * long enough for one entire page write to work. */ timeout = jiffies + msecs_to_jiffies(write_timeout); do { write_time = jiffies; if (at24->use_smbus_write) { /* 使用sembus总线 */ switch (at24->use_smbus_write) { case I2C_SMBUS_I2C_BLOCK_DATA: status = i2c_smbus_write_i2c_block_data(client, offset, count, buf); break; case I2C_SMBUS_BYTE_DATA: status = i2c_smbus_write_byte_data(client, offset, buf[0]); break; } if (status == 0) status = count; } else { /* 使用i2c总线(默认)*/ status = i2c_transfer(client->adapter, &msg, 1); if (status == 1) status = count; } dev_dbg(&client->dev, "write %zu@%d --> %zd (%ld)n", count, offset, status, jiffies); if (status == count) return count; /* REVISIT: at HZ=100, this is sloooow */ msleep(1); } while (time_before(write_time, timeout));/* 写超时处理 */ return -ETIMEDOUT; } |
1.5 匹配函数
static int at24_probe(struct i2c_client *client, const struct i2c_device_id *id) { struct at24_platform_data chip; kernel_ulong_t magic = 0; bool writable; int use_smbus = 0; int use_smbus_write = 0; struct at24_data *at24; int err; unsigned i, num_addresses; if (client->dev.platform_data) { /* 如果存在,优先使用platform(设备树)描述信息 */ chip = *(struct at24_platform_data *)client->dev.platform_data; } else { if (id) { magic = id->driver_data; /* 使用at24_ids描述表 */ } else { const struct acpi_device_id *aid; aid = acpi_match_device(at24_acpi_ids, &client->dev); /* acpi表在嵌入式中比较少用 */ if (aid) magic = aid->driver_data; } if (!magic) return -ENODEV; chip.byte_len = BIT(magic & AT24_BITMASK(AT24_SIZE_BYTELEN)); magic >>= AT24_SIZE_BYTELEN; chip.flags = magic & AT24_BITMASK(AT24_SIZE_FLAGS); /* * This is slow, but we can't know all eeproms, so we better * play safe. Specifying custom eeprom-types via platform_data * is recommended anyhow. */ chip.page_size = 1; /* update chipdata if OF is present */ at24_get_ofdata(client, &chip); chip.setup = NULL; chip.context = NULL; } if (!is_power_of_2(chip.byte_len)) dev_warn(&client->dev, "byte_len looks suspicious (no power of 2)!n"); if (!chip.page_size) { dev_err(&client->dev, "page_size must not be 0!n"); return -EINVAL; } if (!is_power_of_2(chip.page_size)) dev_warn(&client->dev, "page_size looks suspicious (no power of 2)!n"); ......... if (chip.flags & AT24_FLAG_TAKE8ADDR) /* 寻址类型选择 */ num_addresses = 8; else num_addresses = DIV_ROUND_UP(chip.byte_len, (chip.flags & AT24_FLAG_ADDR16) ? 65536 : 256); at24 = devm_kzalloc(&client->dev, sizeof(struct at24_data) + num_addresses * sizeof(struct i2c_client *), GFP_KERNEL); if (!at24) return -ENOMEM; mutex_init(&at24->lock); at24->use_smbus = use_smbus; at24->use_smbus_write = use_smbus_write; at24->chip = chip; at24->num_addresses = num_addresses; /* * Export the EEPROM bytes through sysfs, since that's convenient. * By default, only root should see the data (maybe passwords etc) */ sysfs_bin_attr_init(&at24->bin); /* 初始化生成文件目录信息 */ at24->bin.attr.name = "eeprom"; /* 文件名称,匹配成功,在“/sys/bus/i2c/device/4-0050”目录下生成 */ at24->bin.attr.mode = chip.flags & AT24_FLAG_IRUGO ? S_IRUGO : S_IRUSR; at24->bin.read = at24_bin_read; at24->bin.size = chip.byte_len; at24->macc.read = at24_macc_read; writable = !(chip.flags & AT24_FLAG_READONLY); if (writable) { if (!use_smbus || use_smbus_write) { unsigned write_max = chip.page_size; at24->macc.write = at24_macc_write; at24->bin.write = at24_bin_write; at24->bin.attr.mode |= S_IWUSR; if (write_max > io_limit) write_max = io_limit; if (use_smbus && write_max > I2C_SMBUS_BLOCK_MAX) write_max = I2C_SMBUS_BLOCK_MAX; at24->write_max = write_max; /* buffer (data + address at the beginning) */ at24->writebuf = devm_kzalloc(&client->dev, write_max + 2, GFP_KERNEL); if (!at24->writebuf) return -ENOMEM; } else { dev_warn(&client->dev, "cannot write due to controller restrictions."); } } at24->client[0] = client; /* 至少使用一根i2c总线 */ /* use dummy devices for multiple-address chips */ for (i = 1; i < num_addresses; i++) { /* 超过256地址后,分配一个i2c总线(地址)作“翻页”功能 */ at24->client = i2c_new_dummy(client->adapter, client->addr + i); if (!at24->client) { dev_err(&client->dev, "address 0x%02x unavailablen", client->addr + i); err = -EADDRINUSE; goto err_clients; } } err = sysfs_create_bin_file(&client->dev.kobj, &at24->bin); /* 创建sys文件,支持echo/cat等脚本访问 */ if (err) goto err_clients; i2c_set_clientdata(client, at24); dev_info(&client->dev, "%zu byte %s EEPROM, %s, %u bytes/writen", at24->bin.size, client->name, writable ? "writable" : "read-only", at24->write_max); if (use_smbus == I2C_SMBUS_WORD_DATA || use_smbus == I2C_SMBUS_BYTE_DATA) { dev_notice(&client->dev, "Falling back to %s reads, " "performance will suffern", use_smbus == I2C_SMBUS_WORD_DATA ? "word" : "byte"); } /* export data to kernel code */ if (chip.setup) chip.setup(&at24->macc, chip.context); return 0; err_clients: for (i = 1; i < num_addresses; i++) if (at24->client) i2c_unregister_device(at24->client); return err; } 2. 使用驱动 2.1 添加设备树 AT24C02连接在i2c4上,在“kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-core.dtsi”中的i2c4节点加入EEPROM节点。 eeprom: eeprom@50{ compatible = "atmel,24c02"; /* 型号名称与驱动描述表一致,厂商名称可省 */ reg = <0x50>; /* 器件地址 */ pagesize = <8>; /* 连续写页大小,24c02为8字节 */ status = "okay"; }; 2.2 内核配置 方式【1】 进入kernel目录执行“make menuconfig”,选择如下条目,将EERPOM编译到内核(“*”),“M”表示编译成单独模块(.ko)。 Device Drivers ---> Misc devices ---> EEPROM support ---> <*> I2C EEPROMs / RAMs / ROMs from most vendors 方式【2】 调用firefly的编译脚本编译内核时,会首先将“firefly_linux_defconfig”默认配置写入内核配置文件“.config”中,会覆盖方式【1】中的部分配置,但如果去掉脚本中的内核配置后导致编译失败(为什么每次编译都需写入默认配置?)。 因此,在firefly的默认配置内核配置文件“kernel/arc/arm64/configs/firefly_linux_defconfig” EEPROM编译能够使脚本。暂时推荐使用不同的执行方式。 CONFIG_EEPROM_AT24= 2.3 编译内核 在sdk目录下“./ build.sh kernel”编译内核。编译成功在“kernel”目录下生成内核和设备树打包文件“boot.img”,烧录替换板子内核和设备树。 3.测试 【1】查看驱动,加载成功,在“/sys/bus/i2c/drivers”目录生成i2c驱动名称 【2】查看驱动的sys文件,位于“/sys/busi2c/device/4-0050”中 【3】访问EEPROM sys文件支持“echo” 、“cat”访问。 也可以使用“i2ctools”工具进行验证。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 15:49 , Processed in 0.668611 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1545
