1个回答
CPU:RK32888
系统:Android 5.1 R3288 ddr当前频率的一种查看方法有K,第一个是通过adb查看,那是一个在打印中通过指令查看 1、 adb shell root@rk3288 :/ # cd sys/kernel /debugclk cd sys/kernel/debug/clk root@rk3288:/sys/kernel/debug/clk # clk_summary cat |grep ddr cat clk_summary |grep ddr clk_ddr 2、但是在打印中通过指令当前ddr频率可以,adb中 shell@firefly:/ $ cd sys/dvfs shell @firefly:/sys/dvfs $ ls cpu_temp_enable cpu_temp_target dvfs_tree shell@firefly:/sys/dvfs $ cat dvfs_tree /system/bin/sh: cat: dvfs_tree : Permission denied // 没有权限 |shell@firefly:/sys/dvfs $ su // 获取root权限 shell@firefly:/sys/dvfs # cat dvfs_tree [107.795152] -------------DVFS树----------- [107.795152] [107.795152] [107.795205] DVFS树: [107.795220] | [107.795220]|-电压域:vd_gpu [107.795239]|-当前电压: [107.795252]|-电流调节模式:未知 [107.795269]| | [107.795269] | |- 电源域:pd_gpu,状态 = 关闭,电流电压 = ,电流 regu_mode = 未知 [107.795295] | | | [107.795295] | | |- 时钟:clk_gpu 电流:速度,伏特 =,enable_dvfs = ENABLE [107.795321] | | |-时钟限制(最后):]; [设置的限制= [ 107.795336] | | | |- 频率 = , 伏特 = [ 107.795350] | | | |- 频率 = , 伏特 = [ 107.795363] | | | |- 频率 = , 伏特 = [107.795377] | | | |- 频率 = , 伏特 = [ 107.795392] | | |- 时钟:clk_gpu 当前: 加速,regu_mode = UNKNOWN,regu_mode_en = [107.795407] | [107.795407]|-电压域:vd_logic [107.795425]|-电流电压: [107.795437]|-电流调节模式:未知 [107.795452]| | [107.795452] | |- 电源电压域:pd_vio,状态 = 关闭,电流 = ,电流 regu_mode = 未知 [107.795476] | | | [107.795476] | | |- 时钟:aclk_vio1 电流:速度,伏特 =,enable_dvfs = ENABLE [107.795501] | | |-时钟限制(最后一次):]; [设置的限制= [ 107.795516] | | | |- 频率 = , 伏特 = [107.795530] | | | |- 频率 = , 伏特 = [107.795545] | | |- 时钟:aclk_vio1 当前:调速,regu_mode = 未知,regu_mode = [107.795563] | | [107.795563] | |- 电源域:pd_ddr,状态 = 关闭,电流电压 = ,电流 regu_mode = 未知 [107.795587] | | | [107.795587] | | |- clock: clk_ddr current: rate , volt = , enable_dvfs = ENABLE // 45600为ddr频率,单位为KHz [ 107.795612] | | |- 时钟限制(最后):]; [设置的限制= [ 107.795626] | | | |- 频率 = , 伏特 = [ 107.795640] | | | |- 频率 = , 伏特 = [ 107.795653] | | | |- 频率 = , 伏特 = [ 107.795666] | | | |- 频率 = , 伏特 = [ 107.795682] | | |- 时钟:clk_ddr 当前:节拍,regu_mode = UNKNOWN,regu_mode_en = [107.795696] | [107.795696]|-电压域:vd_arm [107.795714]|-电流电压: [107.795726]|-电流调节模式:未知 [107.795740]| | [107.795740] | |- 电源电压域:pd_core,状态 = 关闭,电流 = ,电流 regu_mode = 未知 [107.795765] | | | [107.795765] | | |- 时钟:clk_core 电流:速度,伏特 =,enable_dvfs = ENABLE [107.795789] | | |-时钟限制(最后):]; [设置的限制= [ 107.795804] | | | |- 频率 = , 伏特 = [ 107.795817] | | | |- 频率 = , 伏特 = [ 107.795830] | | | |- 频率 = , 伏特 = [ 107.795843] | | | |- 频率 = , 伏特 = [ 107.795856] | | | |- 频率 = , 伏特 = [ 107.795869] | | | |- 频率 = , 伏特 = [107.795882] | | | |- 频率 = , 伏特 = [ 107.795895] | | | |- 频率 = , 伏特 = [ 107.795909] | | | |- 频率 = , 伏特 = [ 107.795922] | | | |- 频率 = , 伏特 = [ 107.795936] | | | |- 频率 = , 伏特 = [ 107.795949] | | | |- 频率 = , 伏特 = [ 107.795962] | | | |- 频率 = , 伏特 = [ 107.795975] | | | |- 频率 = , 伏特 = [ 107.795990] | | |- 修改时钟:clk_core 当前:调速,regu_mode = UNKNOWN,regu_mode_en = [ 107.796004] -------------DVFS 树 ddr 频率 END------------ RK3288 ddr END------------查看转载处。 CPU:RK3288 系统:Android 5.1 1.ddr驱动版本号。容量。.. 查看DDR的频率【学习笔记】 SDM439平台如何查看DDR的频率通过访问成为节点查询:cat /sys/kernel/debug/clk/b imc_clk/measure 681.6MHz and higher frequency 。.. linux下查看内存频率,内核函数,cpu频率 CPU: cat /proc/cpuinfo #总核数 = 每个物理 CPU 的个数核数 X 每颗物理 CPU 的个核数数 # 总逻辑 CPU X = 每颗物理 CPU 数 X 物理 CPU 核数 X 线程数 #查看物理 。.. 查看内存频率 查看: wmic memorychip 任务器:任务管理器- 查看_时钟 性能-速度-速度 # cat d/clk/ clk_summary cat d/clk/ clk_summary clock enablecnt 。.. 查看嵌入式设备的CPU频率对于有多个内核 的CPU,查看CPU频率的方法是:cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freqSDK 这个查看内核0的cpu的。.. RK30开发板驱动分析(二):DDR频率配置 在内核配置界面界面,我们可以很容易配置DDR的频率,300M OR 600M,这么简单!这是如何处理的?开发回想RK30SDK分析驱动(一)是C644446 内核_内核分析 关于达芬DM6446,里面有呢内核部分,一个是ARM92内核的两个内核,还有一个是ARM92+DSP处理js的视频,而我需要关注的重点是arm926的内核(bootload和linux运输内核)从boo 。..计划 推荐 BZOJ -4326-4326分树上分+二分 4326:IP2015计划时限:30 Sec Memory Limit: 128 MBSubmit: 703 Solved: 461[Submit][Status] 。.. viewport html5 viewport antim over:01 02宽度控制视口的特大大小,可以指定一个或的值,例如设备宽度 为 - cnblogs.com/mengdd/archive/2013/01/11/2856374.htmlFragment 和 Activity 中问题的 文字的发现的非界面使用界面的实 。.. canvas.d 。..js加载中 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
770 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4588 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1823 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2378 浏览 0 评论
2381 浏览 0 评论
/9
GMT+8, 2025-12-2 18:55 , Processed in 0.609750 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2581
