1.dts:
dts代码加了两组hs_clk,和disp_mipi_init_cmds,并要打开uboot logo rockchip,il9881c,dsi_hs_clk = <1000>; //il9881c rockchip,jd9365,dsi_hs_clk = <434>; //jd9365 disp_mipi_init_cmds1: il9881c-screen-on-cmds { disp_mipi_init_cmds2: jd9365-screen-on-cmds { &fb { rockchip,disp-mode = - rockchip,uboot-logo-on = <0>; + rockchip,uboot-logo-on = <1>; rockchip,disp-policy = }; 2.uboot 1)定义一个rk32_mipi_read_id函数,去读取MIPI寄存器的值,注意读取前需要先写入开屏指令:dcs_set_display_on,读取完后写入关屏指令:dcs_set_display_off 2)读取完后,将寄存器值接入到cmdline里 3)修改of_property_read_u32(childnode, "rockchip,dsi_hs_clk", &value)函数为:(名字要与dts里相匹配) of_property_read_u32(childnode, "rockchip,jd9365,dsi_hs_clk", &value); of_property_read_u32(childnode, "rockchip,il9881c,dsi_hs_clk", &value); 用于区分不同屏的hs_clk加载 4) 添加COMPAT_ROCKCHIP_MIPI_INIT,为:(名字要与dts里相匹配) COMPAT_ROCKCHIP_IL9881C_MIPI_SONCMDS ,COMPAT(ROCKCHIP_IL9881C_MIPI_SONCMDS, "rockchip,il9881c-screen-on-cmds"), COMPAT_ROCKCHIP_JD9365_MIPI_SONCMDS , COMPAT(ROCKCHIP_JD9365_MIPI_SONCMDS, "rockchip,jd9365-screen-on-cmds"), 用于区分不同的screen-on-cmds的加载 diff --git a/u-boot/common/cmd_bootrk.c b/u-boot/common/cmd_bootrk.c old mode 100755 new mode 100644 index 87b1a85066..b3e6eb8125 --- a/u-boot/common/cmd_bootrk.c +++ b/u-boot/common/cmd_bootrk.c @@ -19,6 +19,10 @@ DECLARE_GLOBAL_DATA_PTR; extern int g_logo_on_state; #endif +#ifdef CONFIG_RK32_DSI +extern int g_mipi_id; +#endif + #if defined(CONFIG_RK_HDMI) extern int g_hdmi_vic; #endif @@ -457,6 +461,7 @@ static void rk_commandline_setenv(const char *boot_name, rk_boot_img_hdr *hdr, b if (g_logo_on_state != 0) { snprintf(command_line, sizeof(command_line), "%s uboot_logo=0x%08x@0x%08lx", command_line, CONFIG_RK_LCD_SIZE, gd->fb_base); + #if defined(CONFIG_KERNEL_LOGO) if (g_rk_fb_size != -1) snprintf(command_line, sizeof(command_line), @@ -465,6 +470,10 @@ static void rk_commandline_setenv(const char *boot_name, rk_boot_img_hdr *hdr, b } #endif /* CONFIG_RK_FB_DDREND */ + snprintf(command_line, sizeof(command_line), + "%s mipi.id=%d", command_line, g_mipi_id); + + snprintf(command_line, sizeof(command_line), "%s loader.timestamp=%s", command_line, U_BOOT_TIMESTAMP); diff --git a/u-boot/drivers/video/screen/lcd_mipi.c b/u-boot/drivers/video/screen/lcd_mipi.c old mode 100755 new mode 100644 index b9e513cd81..3593694d3a --- a/u-boot/drivers/video/screen/lcd_mipi.c +++ b/u-boot/drivers/video/screen/lcd_mipi.c @@ -34,6 +34,7 @@ #else #define MIPI_SCREEN_DBG(x...) #endif + #ifdef CONFIG_RK32_DSI DECLARE_GLOBAL_DATA_PTR; #define msleep(a) udelay(a * 1000) @@ -41,6 +42,7 @@ DECLARE_GLOBAL_DATA_PTR; #endif static struct mipi_screen *gmipi_screen; +int g_mipi_id = -2; static void rk_mipi_screen_pwr_disable(struct mipi_screen *screen) { if(screen->lcd_en_gpio != INVALID_GPIO){ @@ -171,6 +173,20 @@ static void rk_mipi_screen_cmd_init(struct mipi_screen *screen) } +int rockchip_dsi_read_panel_id(int num,int count) +{ + int id; + unsigned char buf[2] = {0}; + + buf[0] = 0xdb; + dsi_read_dcs_packet(0, buf, count); + + printf("LOUHN: in rockchip_dsi_read_panel_id--%s:%d, buf[0]=0x%x,buf[1]=0x%xn", __func__, __LINE__, buf[0],buf[1]); + id = ( buf[0] << 8) + buf[1]; + return id; +} + + int rk_mipi_screen(void) { u8 dcs[16] = {0}, rk_dsi_num; @@ -255,6 +271,52 @@ int rk_mipi_screen(void) return 0; } +int read_panel_id(){ + + u8 dcs[16] = {0}, rk_dsi_num; + rk_dsi_num = gmipi_screen->mipi_dsi_num; + //rk_mipi_screen_pwr_enable(gmipi_screen); + printf("LOUHN in read_panel_id()n"); + dsi_enable_hs_clk(0,1); + dsi_enable_video_mode(0,0); + dsi_enable_command_mode(0, 1); + + dcs[0] = LPDT; + dcs[1] = DTYPE_DCS_SWRITE_0P; + dcs[2] = dcs_exit_sleep_mode; + dsi_send_packet(0, dcs, 3); + if(rk_dsi_num ==2) + dsi_send_packet(1, dcs, 3); + + msleep(20); + dcs[0] = LPDT; + dcs[1] = DTYPE_DCS_SWRITE_0P; + dcs[2] = dcs_set_display_on; + dsi_send_packet(0, dcs, 3); + if(rk_dsi_num ==2) + dsi_send_packet(1, dcs, 3); + + msleep(100); + + g_mipi_id = rockchip_dsi_read_panel_id(1,2); + dcs[0] = LPDT; + dcs[1] = DTYPE_DCS_SWRITE_0P; + dcs[2] = dcs_set_display_off; + dsi_send_packet(0, dcs, 3); + if(rk_dsi_num ==2) + dsi_send_packet(1, dcs, 3); + + msleep(20); + dcs[0] = LPDT; + dcs[1] = DTYPE_DCS_SWRITE_0P; + dcs[2] = dcs_enter_sleep_mode; + dsi_send_packet(0, dcs, 3); + if(rk_dsi_num ==2) + dsi_send_packet(1, dcs, 3); + + msleep(20); + return g_mipi_id; +} int rk_mipi_screen_standby(u8 enable) { u8 dcs[16] = {0}, rk_dsi_num; @@ -307,7 +369,7 @@ static int rk_mipi_screen_init_dt(struct mipi_screen *screen) memset(screen, 0, sizeof(*screen)); INIT_LIST_HEAD(&screen->cmdlist_head); - + printf("LOUHN --> in rk_mipi_screen_init_dtn"); childnode = of_find_node_by_name(NULL, "mipi_dsi_init"); if(!childnode ){ MIPI_SCREEN_DBG("%s: Can not get child => mipi_init.n", __func__); @@ -334,8 +396,23 @@ static int rk_mipi_screen_init_dt(struct mipi_screen *screen) screen->dsi_lane = value; MIPI_SCREEN_DBG("%s: mipi_lcd->dsi_lane = %d.n", __func__, screen->dsi_lane ); } - - ret = of_property_read_u32(childnode, "rockchip,dsi_hs_clk", &value); + + if(g_mipi_id == 25957)//0x65 + { + ret = of_property_read_u32(childnode, "rockchip,jd9365,dsi_hs_clk", &value); + printk("LOUHN: read1 jd9365 mipi ic,value=%d ?n",value); + } + else if(g_mipi_id == 0)//0x00 + { + ret = of_property_read_u32(childnode, "rockchip,il9881c,dsi_hs_clk", &value); + printf("LOUHN: read il9881c mipi ic,value=%d ?n ",value); + } + else + { + ret = of_property_read_u32(childnode, "rockchip,dsi_hs_clk", &value); + printf("LOUHN:Read mipi reg err,is a new mipi screen ?n "); + } + if (ret) { MIPI_SCREEN_DBG("%s: Can not read property: dsi_hs_clk.n", __func__); } else { @@ -434,8 +511,23 @@ static int rk_mipi_screen_init_dt(struct mipi_screen *screen) MIPI_SCREEN_DBG("dsi->lcd_en_gpio=%d, dsi->screen.lcd_en_atv_val=%dn",screen->lcd_en_gpio,screen->lcd_en_atv_val); } } + - root= of_find_node_by_name(NULL,"screen-on-cmds"); + if(g_mipi_id == 25957)//0x65 + { + root = of_find_node_by_name(NULL, "jd9365-screen-on-cmds"); + printf("LOUHN: read jd9365 mipi icn"); + } + else if(g_mipi_id == 0)//0x00 + { + root = of_find_node_by_name(NULL, "il9881c-screen-on-cmds"); + printf("LOUHN: read il9881c mipi icn"); + } + else + { + root = of_find_node_by_name(NULL, "screen-on-cmds"); + printf("LOUHN: in read screen-on-cmds, is a new mipi screen ?n "); + } if (!root) { MIPI_SCREEN_DBG("can't find screen-on-cmds noden"); } @@ -563,7 +655,8 @@ static int rk_mipi_screen_init_dt(struct mipi_screen *screen) u32 i,cmds[20]; int length; int err; - int node; + int id; + int node,subnode,rootnode; const void *blob; struct fdt_gpio_state gpio_val; int noffset; @@ -574,8 +667,26 @@ static int rk_mipi_screen_init_dt(struct mipi_screen *screen) blob = gd->fdt_blob;//getenv_hex("fdtaddr", 0); node = fdtdec_next_compatible(blob, 0, COMPAT_ROCKCHIP_MIPI_INIT); + /* + rootnode = fdt_path_offset(blob, "/disp_mipi"); + if (node < 0) { + MIPI_SCREEN_DBG("Can not get node of disp_mipin"); + } + fdt_for_each_subnode(blob,subnode,rootnode){ + node = fdtdec_next_compatible(blob, subnode, COMPAT_ROCKCHIP_MIPI_INIT); + */ if (node < 0) { MIPI_SCREEN_DBG("Can not get node of COMPAT_ROCKCHIP_MIPI_INITn"); +/* + } + id = fdtdec_get_int(blob, node, "rockchip,mipi_id", -1); + if (id < 0) { + MIPI_SCREEN_DBG("Can not get screen idn"); + } + printf("read mipi para id = %d,lcd_id=%dn",id,screen->lcd_id); + if(id != screen->lcd_id){ + continue; +*/ } screen->screen_init = fdtdec_get_int(blob, node, "rockchip,screen_init", -1); if (screen->screen_init < 0) { @@ -585,7 +696,22 @@ static int rk_mipi_screen_init_dt(struct mipi_screen *screen) if (screen->dsi_lane < 0) { MIPI_SCREEN_DBG("Can not get dsi_lanen"); } - screen->hs_tx_clk= fdtdec_get_int(blob, node, "rockchip,dsi_hs_clk", -1); + + if(g_mipi_id == 25957)//0x65 + { + screen->hs_tx_clk= fdtdec_get_int(blob, node, "rockchip,jd9365,dsi_hs_clk", -1); + printf("LOUHN: read jd9365 mipi ic,value=%d ?n ",screen->hs_tx_clk); + } + else if(g_mipi_id == 0)//0x00 + { + screen->hs_tx_clk= fdtdec_get_int(blob, node, "rockchip,il9881c,dsi_hs_clk", -1); + printf("LOUHN: read il9881c mipi ic,value=%d ?n ",screen->hs_tx_clk); + } + else + { + screen->hs_tx_clk= fdtdec_get_int(blob, node, "rockchip,dsi_hs_clk", -1); + printf("LOUHN:Read mipi reg err,is a new mipi screen ?n "); + } if (screen->hs_tx_clk < 0) { MIPI_SCREEN_DBG("Can not get dsi_hs_clkn"); } else { @@ -598,6 +724,7 @@ static int rk_mipi_screen_init_dt(struct mipi_screen *screen) /* get the lcd rst & en status */ node = fdtdec_next_compatible(blob, 0, COMPAT_ROCKCHIP_MIPI_PWR); +// node = fdtdec_next_compatible(blob, subnode, COMPAT_ROCKCHIP_MIPI_PWR); if (node < 0) { MIPI_SCREEN_DBG("Can not get node of COMPAT_ROCKCHIP_MIPI_PWRn"); } else { @@ -637,10 +764,27 @@ static int rk_mipi_screen_init_dt(struct mipi_screen *screen) } } /*get the initial command list*/ - node = fdtdec_next_compatible(blob, 0, COMPAT_ROCKCHIP_MIPI_SONCMDS); + if(g_mipi_id == 25957)//0x65 + { + node = fdtdec_next_compatible(blob, 0, COMPAT_ROCKCHIP_JD9365_MIPI_SONCMDS); + printf("LOUHN: read jd9365 mipi cmdsn"); + } + else if(g_mipi_id == 0)//0x00 + { + node = fdtdec_next_compatible(blob, 0, COMPAT_ROCKCHIP_IL9881C_MIPI_SONCMDS); + printf("LOUHN: read il9881c mipi cmdsn"); + } + else + { + node = fdtdec_next_compatible(blob, 0, COMPAT_ROCKCHIP_MIPI_SONCMDS); + printf("LOUHN: in read screen-on-cmds, is a new mipi screen ?n "); + } + if (node < 0) { + printf("LOUHN :read COMPAT_ROCKCHIP_MIPI_SONCMDS errn"); MIPI_SCREEN_DBG("Can not get node of COMPAT_ROCKCHIP_MIPI_SONCMDSn"); } else { + printf("LOUHN :read COMPAT_ROCKCHIP_MIPI_SONCMDS okn"); for (noffset = fdt_first_subnode(blob,node); noffset >= 0; noffset = fdt_next_subnode(blob, noffset)) { @@ -676,7 +820,7 @@ static int rk_mipi_screen_init_dt(struct mipi_screen *screen) } #endif /* CONFIG_OF_LIBFDT */ -int rk_mipi_screen_probe(void) +int rk_mipi_screen_probe(int id) { int ret = 0; gmipi_screen = calloc(1, sizeof(struct mipi_screen)); @@ -684,6 +828,7 @@ int rk_mipi_screen_probe(void) printf("request struct screen fail!n"); return -ENOMEM; } + gmipi_screen->lcd_id = id; #ifdef CONFIG_OF_LIBFDT ret = rk_mipi_screen_init_dt(gmipi_screen); if(ret < 0){ diff --git a/u-boot/drivers/video/transmitter/mipi_dsi.h b/u-boot/drivers/video/transmitter/mipi_dsi.h old mode 100755 new mode 100644 index f4d77a0db8..b5a7558d6b --- a/u-boot/drivers/video/transmitter/mipi_dsi.h +++ b/u-boot/drivers/video/transmitter/mipi_dsi.h @@ -34,6 +34,9 @@ #define DTYPE_GEN_SWRITE_1P 0x13 #define DTYPE_GEN_SWRITE_0P 0x03 +#define DTYPE_DCS_READ_OP 0x06 +#define DTYPE_GEN_READ_OP 0x04 +#define SET_MAX_RETURN_SIZE 0x37 //command transmit mode #define HSDT 0x00 #define LPDT 0x01 @@ -283,6 +286,7 @@ struct mipi_screen u32 lcd_en_delay; u32 lcd_rst_gpio; u32 lcd_rst_delay; + u32 lcd_id; struct list_head cmdlist_head; }; diff --git a/u-boot/drivers/video/transmitter/rk32_mipi_dsi.c b/u-boot/drivers/video/transmitter/rk32_mipi_dsi.c old mode 100755 new mode 100644 index 375dfdb87f..2a5c0ff521 --- a/u-boot/drivers/video/transmitter/rk32_mipi_dsi.c +++ b/u-boot/drivers/video/transmitter/rk32_mipi_dsi.c @@ -76,7 +76,7 @@ static int rk32_mipi_dsi_is_enable(void *arg, u32 enable); int rk_mipi_screen_standby(u8 enable); DECLARE_GLOBAL_DATA_PTR; -extern int rk_mipi_screen_probe(void); +extern int rk_mipi_screen_probe(int); static void inline writel_relaxed(uint32 val, uint32 addr) { @@ -347,7 +347,6 @@ static int rk312x_phy_power_up(struct dsi *dsi) udelay(10); rk32_dsi_set_bits(dsi, 0xe4, DPHY_REGISTER1); - printf("lane = %dn", dsi->host.lane); switch (dsi->host.lane) { case 4: @@ -1301,6 +1300,7 @@ static int rk32_mipi_dsi_send_packet(void *arg, unsigned char cmds[], u32 length return 0; } +#if 0 static int rk32_mipi_dsi_read_dcs_packet(void *arg, unsigned char *data1, u32 n) { struct dsi *dsi = arg; @@ -1343,6 +1343,60 @@ static int rk32_mipi_dsi_read_dcs_packet(void *arg, unsigned char *data1, u32 n) msleep(100); return 0; } +#else +static int rk32_mipi_dsi_read_dcs_packet(void *arg, u8 *buf, u32 size) +{ + int i; + u32 data; + u32 reg_val = 0; + u32 gen_empty = 0; + u32 rd_busy = 0; + u8 rd_reg; + struct dsi *dsi = arg; + + if ((buf == NULL) || (size == 0)) + return -1; + + if (rk32_dsi_get_bits(dsi, gen_cmd_full) == 1) { + MIPI_DBG("%s: gen_cmd_fulln", __func__); + return -1; + } + /* set bit on max read packet size*/ + rk32_dsi_set_bits(dsi, LPDT, max_rd_pkt_size); + //max read packet size is set 3 btye,customer can modify this value,the max value known is 4*/ + data = (size << 8 )|SET_MAX_RETURN_SIZE; + rk32_dsi_set_bits(dsi, data, GEN_HDR); + udelay(20); + + /* send read command */ + rk32_dsi_set_bits(dsi, LPDT, dcs_sr_0p_tx); + + /* set back turn-around */ + rk32_dsi_set_bits(dsi, 1, bta_en); + + rd_reg = buf[0]; + data = (rd_reg << 8) | DTYPE_DCS_READ_OP; + rk32_dsi_set_bits(dsi, data, GEN_HDR); + + udelay(20); + + /* wait command fifo empty and read command fifo is not busy */ + i = 10; + gen_empty = rk32_dsi_get_bits(dsi, gen_cmd_empty); + rd_busy = rk32_dsi_get_bits(dsi, gen_rd_cmd_busy); + while (!gen_empty && rd_busy && i--) { + printf("*"); + udelay(10); + } + + /* get read data from GEN_PLD_DATA */ + reg_val = rk32_dsi_get_bits(dsi, GEN_PLD_DATA); + buf[0] = reg_val & 0xff; + buf[1] = (reg_val >> 8) & 0xff; + + return 0; +} +#endif static int rk32_mipi_dsi_power_up(void *arg) { @@ -1874,6 +1928,94 @@ int rk_dsi_host_parse_dt(const void *blob, struct dsi *dsi) } #endif /* #ifdef CONFIG_OF_LIBFDT */ |
+int rk32_mipi_read_id(vidinfo_t *vid){
+ + int ret = 0; + struct dsi *dsi; + struct mipi_dsi_ops *ops; + struct rk_screen *screen; + struct mipi_dsi_screen *dsi_screen; + int id = 0; + int i = 3,result = 0; + printf("LOUHN in rk32_mipi_read_id n"); + dsi = calloc(1, sizeof(struct dsi)); + if(!dsi) { + MIPI_DBG("request struct dsi.%d fail!n",id); + return -ENOMEM; + } + + dsi->dsi_id = id++; +#ifdef CONFIG_OF_LIBFDT + rk_dsi_host_parse_dt(gd->fdt_blob,dsi); +#endif /* #ifdef CONFIG_OF_LIBFDT */ + screen = calloc(1, sizeof(struct rk_screen)); + if(!screen) { + MIPI_DBG("request struct rk_screen fail!n"); + } + + ops = &dsi->ops; + ops->dsi = dsi; + if (cpu_is_rk3288()) + ops->id = DWC_DSI_VERSION; + else if (cpu_is_rk312x()) + ops->id = DWC_DSI_VERSION_RK312x; + else if (cpu_is_rk3368()) + ops->id = DWC_DSI_VERSION_RK3368; + else + ops->id = DWC_DSI_VERSION_ERR; + + ops->get_id = rk32_mipi_dsi_get_id, + ops->dsi_send_packet = rk32_mipi_dsi_send_packet; + ops->dsi_read_dcs_packet = rk32_mipi_dsi_read_dcs_packet, + ops->dsi_enable_video_mode = rk32_mipi_dsi_enable_video_mode, + ops->dsi_enable_command_mode = rk32_mipi_dsi_enable_command_mode, + ops->dsi_enable_hs_clk = rk32_mipi_dsi_enable_hs_clk, + ops->dsi_is_active = rk32_mipi_dsi_is_active, + ops->dsi_is_enable= rk32_mipi_dsi_is_enable, + ops->power_up = rk32_mipi_dsi_power_up, + ops->power_down = rk32_mipi_dsi_power_down, + ops->dsi_init = rk_mipi_dsi_init, + + dsi_screen = &dsi->screen; + dsi_screen->type = screen->type = vid->screen_type; + dsi_screen->face = screen->face = vid->lcd_face; + dsi_screen->pixclock = screen->mode.pixclock = vid->vl_freq; + dsi_screen->left_margin = screen->mode.left_margin = vid->vl_hbpd; + dsi_screen->right_margin = screen->mode.right_margin = vid->vl_hfpd; + dsi_screen->hsync_len = screen->mode.hsync_len = vid->vl_hspw; + dsi_screen->upper_margin = screen->mode.upper_margin = vid->vl_vbpd; + dsi_screen->lower_margin = screen->mode.lower_margin = vid->vl_vfpd; + dsi_screen->vsync_len = screen->mode.vsync_len = vid->vl_vspw; + dsi_screen->x_res = screen->mode.xres = vid->vl_width; + dsi_screen->y_res = screen->mode.yres = vid->vl_height; + dsi_screen->pin_hsync = screen->pin_hsync = vid->vl_hsp; + dsi_screen->pin_vsync = screen->pin_vsync = vid->vl_vsp; + dsi_screen->pin_den = screen->pin_den = vid->vl_oep; + dsi_screen->lcdc_id = 1; + dsi_screen->dsi_lane = 4; + dsi_screen->hs_tx_clk = 550000000; + dsi->dsi_id = 0; + sprintf(ops->name, "rk_mipi_dsi.%d", dsi->dsi_id); + ret = rk_mipi_dsi_probe(dsi); + if(ret) { + MIPI_DBG("rk mipi_dsi probe fail!n"); + MIPI_DBG("%sn", RK_MIPI_DSI_VERSION_AND_TIME); + } + + if(id == 1){ + rk_init_phy_mode(vid->lcdc_id); + dsi0 = dsi; + }else{ + dsi1 = dsi; + } + + rk_mipi_dsi_init(dsi,0); + //while((i-- > 0) && (result == 0)) + result = read_panel_id(); + + return result; +} + int rk32_mipi_enable(vidinfo_t *vid) { int ret = 0; @@ -1883,8 +2025,7 @@ int rk32_mipi_enable(vidinfo_t *vid) struct mipi_dsi_screen *dsi_screen; static int id = 0; u8 dsi_number = 0; - - rk_mipi_screen_probe(); + rk_mipi_screen_probe(vid->lcd_id); dsi_number = rk_mipi_get_dsi_num(); MIPI_DBG("dsi number is %dn", dsi_number); diff --git a/u-boot/include/fdtdec.h b/u-boot/include/fdtdec.h index 45e3e63809..b126bf9c71 100755 --- a/u-boot/include/fdtdec.h +++ b/u-boot/include/fdtdec.h @@ -114,7 +114,9 @@ enum fdt_compat_id { COMPAT_ROCKCHIP_DSIHOST, /*RockChip DSI host Controller*/ COMPAT_ROCKCHIP_MIPI_INIT, /*RockChip MIPI init*/ COMPAT_ROCKCHIP_MIPI_PWR, /*RockChip MIPI pwr*/ - COMPAT_ROCKCHIP_MIPI_SONCMDS, /*RockChip MIPI screen on cmds*/ + COMPAT_ROCKCHIP_MIPI_SONCMDS, /*RockChip MIPI screen on cmds*/ + COMPAT_ROCKCHIP_IL9881C_MIPI_SONCMDS, /*RockChip MIPI screen on cmds*/ + COMPAT_ROCKCHIP_JD9365_MIPI_SONCMDS, /*RockChip MIPI screen on cmds*/ COMPAT_ROCKCHIP_MIPI_ONCMDS, /*RockChip MIPI screen on cmd*/ COMPAT_ROCKCHIP_MIPI_LCD_DT, /*RockChip MIPI screen display timing */ COMPAT_ROCKCHIP_MIPI_LCD_RST, /*RockChip MIPI screen rst pin */ diff --git a/u-boot/include/lcd.h b/u-boot/include/lcd.h old mode 100755 new mode 100644 index 32e6b73ab3..172884129f --- a/u-boot/include/lcd.h +++ b/u-boot/include/lcd.h @@ -340,7 +340,7 @@ typedef struct vidinfo { unsigned int sclk_div; unsigned int dual_lcd_enabled; - + int lcd_id; u_char screen_type; u_char lvds_ch_nr; diff --git a/u-boot/lib/fdtdec.c b/u-boot/lib/fdtdec.c index 4ed39232d4..f04a27d675 100755 --- a/u-boot/lib/fdtdec.c +++ b/u-boot/lib/fdtdec.c @@ -74,6 +74,8 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(ROCKCHIP_MIPI_INIT, "rockchip,mipi_dsi_init"), COMPAT(ROCKCHIP_MIPI_PWR, "rockchip,mipi_power_ctr"), COMPAT(ROCKCHIP_MIPI_SONCMDS, "rockchip,screen-on-cmds"), + COMPAT(ROCKCHIP_IL9881C_MIPI_SONCMDS, "rockchip,il9881c-screen-on-cmds"), + COMPAT(ROCKCHIP_JD9365_MIPI_SONCMDS, "rockchip,jd9365-screen-on-cmds"), COMPAT(ROCKCHIP_MIPI_ONCMDS, "rockchip,on-cmds"), COMPAT(ROCKCHIP_MIPI_LCD_DT, "rockchip,display-timings"), COMPAT(ROCKCHIP_MIPI_LCD_RST, "rockchip,lcd_rst"), 3.kernel 1)读取cmdline里保存的寄存器值 2)修改of_property_read_u32(childnode, "rockchip,dsi_hs_clk", &value)函数为:(名字要与dts里相匹配) of_property_read_u32(childnode, "rockchip,jd9365,dsi_hs_clk", &value); of_property_read_u32(childnode, "rockchip,il9881c,dsi_hs_clk", &value); 用于区分不同屏的hs_clk加载 3)修改of_find_node_by_name(NULL, "screen-on-cmds");函数为:(名字要与dts里相匹配) of_find_node_by_name(NULL, "jd9365-screen-on-cmds"); of_find_node_by_name(NULL, "il9881c-screen-on-cmds"); 用于区分不同屏的screen-on-cmds加载 @@ -323,8 +353,22 @@ static int rk_mipi_screen_init_dt(struct device *dev, screen->dsi_lane = value; MIPI_SCREEN_DBG("%s: mipi_lcd->dsi_lane = %d.n", __func__, screen->dsi_lane); } - - ret = of_property_read_u32(childnode, "rockchip,dsi_hs_clk", &value); + + if(mipi_id_int == 25957)//0x65 + { + ret = of_property_read_u32(childnode, "rockchip,jd9365,dsi_hs_clk", &value); + printk("LOUHN: read jd9365 mipi ic,value=%d ?n ",value); + } + else if(mipi_id_int == 0)//0x00 + { + ret = of_property_read_u32(childnode, "rockchip,il9881c,dsi_hs_clk", &value); + printk("LOUHN: read il9881c mipi ic,value=%d ?n ",value); + } + else + { + ret = of_property_read_u32(childnode, "rockchip,dsi_hs_clk", &value); + printk("LOUHN:Read mipi reg err,is a new mipi screen ?n "); + } if (ret) { MIPI_SCREEN_DBG("%s: Can not read property: dsi_hs_clk.n", __func__); } else { @@ -419,8 +463,22 @@ static int rk_mipi_screen_init_dt(struct device *dev, MIPI_SCREEN_DBG("dsi->lcd_en_gpio=%d, dsi->screen.lcd_en_atv_val=%dn", screen->lcd_en_gpio, screen->lcd_en_atv_val); } } + if(mipi_id_int == 25957)//0x65 + { + root = of_find_node_by_name(NULL, "jd9365-screen-on-cmds"); + printk("LOUHN: read jd9365 mipi icn"); + } + else if(mipi_id_int == 0)//0x00 + { + root = of_find_node_by_name(NULL, "il9881c-screen-on-cmds"); + printk("LOUHN: read il9881c mipi icn"); + } + else + { + root = of_find_node_by_name(NULL, "screen-on-cmds"); + printk("LOUHN: in read screen-on-cmds, is a new mipi screen ?n "); + } - root = of_find_node_by_name(NULL, "screen-on-cmds"); if (!root) { MIPI_SCREEN_DBG("can't find screen-on-cmds noden"); } else { @@ -567,7 +625,22 @@ static int rk_mipi_screen_init_dt(struct mipi_screen *screen) if (screen->dsi_lane < 0) { MIPI_SCREEN_DBG("Can not get dsi_lanen"); } - screen->hs_tx_clk = fdtdec_get_int(blob, node, "rockchip,dsi_hs_clk", -1); + if(mipi_id_int == 25957)//0x65 + { + screen->hs_tx_clk = fdtdec_get_int(blob, node, "rockchip,jd9365,dsi_hs_clk", -1); + printk("LOUHN:Read jd9365,dsi_hs_clkn "); + } + else if(mipi_id_int == 0)//0x00 + { + screen->hs_tx_clk = fdtdec_get_int(blob, node, "rockchip,il9881c,dsi_hs_clk", -1); + printk("LOUHN:Read il9881c,dsi_hs_clkn "); + } + else + { + screen->hs_tx_clk = fdtdec_get_int(blob, node, "rockchip,dsi_hs_clk", -1); + printk("LOUHN:Read mipi reg err,is a new mipi screen ?n "); + } + if (screen->hs_tx_clk < 0) { MIPI_SCREEN_DBG("Can not get dsi_hs_clkn"); } else { @@ -717,6 +790,7 @@ int rk_mipi_screen_probe(void) { int ret = 0; gmipi_screen = calloc(1, sizeof(struct mipi_screen)); + if (!gmipi_screen) { printf("request struct screen fail!n"); return -ENOMEM; @@ -738,7 +812,11 @@ int rk_mipi_screen_probe(void) static int __init rk_mipi_screen_probe(struct platform_device *pdev) { static int ret; - + + get_cmdline_str(saved_command_line,"mipi.id=",mipi_id_string); //获取mipi.id值,保存到mipi_id_string + kstrtoint(mipi_id_string, 0, &mipi_id_int); + printk("LOUHN in rk_mipi_screen_probe,mipi.id=%dn",mipi_id_int); + printk("LOUHN:cmdline=%sn",saved_command_line); gmipi_screen = devm_kzalloc(&pdev->dev, sizeof(struct mipi_screen), GFP_KERNEL); if (!gmipi_screen) { dev_err(&pdev->dev, "request struct screen fail!n"); |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1423 浏览 1 评论
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
1534 浏览 1 评论
RK3588 GStreamer调试四路鱼眼摄像头四宫格显示报错
3465 浏览 1 评论
【飞凌嵌入式OK3576-C开发板体验】RKNN神经网络-YOLO图像识别
254 浏览 0 评论
【飞凌嵌入式OK3576-C开发板体验】SSH远程登录网络配置及CAN通讯
1336 浏览 0 评论
GMT+8, 2024-11-5 23:22 , Processed in 0.705662 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
