1. 在调试imx307 效果的时候,预览图像的时候始终有些轻微抖动,后面发现是camera是时钟不对。 imx307要求是时钟是37.125M,设置的时钟也是37.125M,而平台分出来是时钟确只有35.5M,没有37.125M,需要打补丁。 PLL_NPLL分频cif clk out 37.125M补丁如下: diff --git a/kernel/arch/arm/boot/dts/rk3288.dtsi b/kernel/arch/arm/boot/dts/rk3288.dtsi index 38cda53..ffaf5c3 100755 --- a/kernel/arch/arm/boot/dts/rk3288.dtsi +++ b/kernel/arch/arm/boot/dts/rk3288.dtsi @@ -1195,6 +1195,10 @@ compatible = "rockchip,rk3288-isp", "rockchip,isp"; reg = <0x0 0xff910000 0x0 0x4000>; interrupts = + //start for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add + assigned-clocks = <&cru PLL_NPLL>, <&cru SCLK_VIP_SRC>, <&cru SCLK_VIP_OUT>; + assigned-clock-rates = <594000000>, <594000000>, <37125000>; + //end for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add power-domains = <&power RK3288_PD_VIO>; clocks = <&cru ACLK_ISP>, <&cru HCLK_ISP>, <&cru SCLK_ISP>, diff --git a/kernel/drivers/clk/rockchip/clk-rk3288.c b/kernel/drivers/clk/rockchip/clk-rk3288.c index b0168c7..4763030 100755 --- a/kernel/drivers/clk/rockchip/clk-rk3288.c +++ b/kernel/drivers/clk/rockchip/clk-rk3288.c @@ -469,7 +469,10 @@ static struct rockchip_clk_branch rk3288_clk_branches[] __initdata = { RK3288_CLKSEL_CON(42), 14, 2, MFLAGS, 8, 5, DFLAGS, RK3288_CLKGATE_CON(13), 15, GFLAGS), - COMPOSITE_NODIV(0, "vip_src", mux_pll_src_cpll_gpll_p, 0, + //start for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add + //COMPOSITE_NODIV(0, "vip_src", mux_pll_src_cpll_gpll_p, 0, + COMPOSITE_NODIV(SCLK_VIP_SRC, "vip_src", mux_pll_src_cpll_gpll_p, 0, + //end for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add RK3288_CLKSEL_CON(26), 8, 1, MFLAGS, RK3288_CLKGATE_CON(3), 7, GFLAGS), COMPOSITE_NOGATE(SCLK_VIP_OUT, "sclk_vip_out", mux_vip_out_p, 0, diff --git a/kernel/drivers/media/video/rk_camsys/camsys_cif.c b/kernel/drivers/media/video/rk_camsys/camsys_cif.c old mode 100644 new mode 100755 index fce0784..a597ea6 --- a/kernel/drivers/media/video/rk_camsys/camsys_cif.c +++ b/kernel/drivers/media/video/rk_camsys/camsys_cif.c @@ -148,7 +148,9 @@ static int camsys_cif_clkout_cb(void *ptr, unsigned int on, unsigned int clkin) spin_lock(&clk->lock); if (on && (clk->out_on != on)) { clk_prepare_enable(clk->cif_clk_out); - clk_set_rate(clk->cif_clk_out, clkin); + //start for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add + //clk_set_rate(clk->cif_clk_out, clkin); + //end for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add clk->out_on = on; camsys_trace(1, "%s clock out(rate: %dHz) turn on", diff --git a/kernel/drivers/media/video/rk_camsys/camsys_marvin.c b/kernel/drivers/media/video/rk_camsys/camsys_marvin.c old mode 100644 new mode 100755 index bef1dc1..cfe2974 --- a/kernel/drivers/media/video/rk_camsys/camsys_marvin.c +++ b/kernel/drivers/media/video/rk_camsys/camsys_marvin.c @@ -683,7 +683,9 @@ static int camsys_mrv_clkout_cb(void *ptr, unsigned int on, unsigned int inclk) mutex_lock(&clk->lock); if (on && (clk->out_on != on)) { - clk_set_rate(clk->cif_clk_out, inclk); + //start for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add + //clk_set_rate(clk->cif_clk_out, inclk); + //end for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add clk_prepare_enable(clk->cif_clk_out); clk->out_on = on; camsys_trace(1, "%s clock out(rate: %dHz) turn on", diff --git a/kernel/include/dt-bindings/clock/rk3288-cru.h b/kernel/include/dt-bindings/clock/rk3288-cru.h old mode 100644 new mode 100755 index 6cb872f..c4d55f0 --- a/kernel/include/dt-bindings/clock/rk3288-cru.h +++ b/kernel/include/dt-bindings/clock/rk3288-cru.h @@ -91,6 +91,7 @@ #define SCLK_VIP_OUT 127 #define SCLK_DDRCLK 128 #define SCLK_I2S_SRC 129 +#define SCLK_VIP_SRC 135 #define SCLK_MAC_PLL 150 #define SCLK_MAC 151 (END) 打上补丁后imx307的mclk 37.125M正常了,预览界面也不会有抖动了,显示效果也得到了改善; 可以通过adb 查看clk是否正确: cat ./sys/kernel/debug/clk/clk_summary |grep vip vip_src 1 1 594000000 0 0 sclk_vip_out 1 3 37125000 0 0 2. 但又出现了新的问题,打上补丁后,导致100M以太网无法使用了。我们用100M以太网是由rk3288提供分频50M, 以太网50M是由PLL_NPLL分出来了,PLL_NPLL默认是500M,是可以正常分出50M的。 但是打上cif clk 37.125M补丁后,NPLL改成594M后,无法分出50M了,导致100M以太网无法使用了。 问题找到了,但两个问题是冲突的,二者只能取其一,母时钟还是不能乱动的,一动其他孩子可能就要断奶了。 只能找其他方法了,把整个时钟树列出来发现GPLL默认时钟就是594M,于是我们可以选着GPLL作为sclk_vip_out的母时钟, 既能分出37.125M,又不用改母时钟频率,这样camera IMX307和以太网都可以正常使用了, 补丁如下: diff --git a/kernel/arch/arm/boot/dts/rk3288.dtsi b/kernel/arch/arm/boot/dts/rk3288.dtsi index ffaf5c3..a025a91 100755 --- a/kernel/arch/arm/boot/dts/rk3288.dtsi +++ b/kernel/arch/arm/boot/dts/rk3288.dtsi @@ -1196,7 +1196,7 @@ reg = <0x0 0xff910000 0x0 0x4000>; interrupts = //start for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add - assigned-clocks = <&cru PLL_NPLL>, <&cru SCLK_VIP_SRC>, <&cru SCLK_VIP_OUT>; + assigned-clocks = <&cru PLL_GPLL>, <&cru SCLK_VIP_SRC>, <&cru SCLK_VIP_OUT>; assigned-clock-rates = <594000000>, <594000000>, <37125000>; //end for camera IMX307 mclk "sclk_vip_out" set 37.125M by lpz add power-domains = <&power RK3288_PD_VIO>; |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 13:20 , Processed in 0.675664 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
13820
