Platform: RK3288
OS: Android 7.1.2 Kernel: v4.4.143 需求: Android系统项目定制开机动画,自定义的开机动画需保存在/system/media/bootanimation.zip,终端在横竖屏状态加载不同的bootanimation.zip,以实现在横竖屏的LOGO都能正常显示不拉伸。 解决: 1、制作横屏和竖屏的bootanimation.zip 方法1: 路径:/device/rockchip/rk3288/bootanimation 在源码里添加放置两个bootanimation.zip,举例命名为bootanimation_h.zip和bootanimation_v.zip分别代表横屏的LOGO和竖屏的LOGO; 路径:/device/rockchip/rk3288/rk3288.mk 编译时会将/device/rockchip/rk3288/bootanimation/的两个压缩包拷贝到system/media/目录下 PRODUCT_COPY_FILES += device/rockchip/rk3288/bootanimation/bootanimation_v.zip:system/media/bootanimation_v.zip PRODUCT_COPY_FILES += device/rockchip/rk3288/bootanimation/bootanimation_h.zip:system/media/bootanimation_h.zip 方法2: 路径:out/target/product/rk3288/system/media 直接在此路径放置压缩包,打包时会自动存到系统/system/media/目录下 2、通过判断横竖屏执行不同的bootanimation diff --git a/cmds/bootanimation/BootAnimation.cpp b/cmds/bootanimation/BootAnimation.cpp index 24c8fa4..86bb671 100755 --- a/cmds/bootanimation/BootAnimation.cpp +++ b/cmds/bootanimation/BootAnimation.cpp @@ -64,13 +64,17 @@ namespace android { +#define CONFIG_DATA_FILES_PLAYING static const char OEM_BOOTANIMATION_FILE[] = "/oem/media/bootanimation.zip"; -static const char SYSTEM_BOOTANIMATION_FILE[] = "/system/media/bootanimation.zip"; +static const char SYSTEM_BOOTANIMATION_ROTATION_HENG_FILE[] = "/system/media/bootanimation_h.zip"; +static const char SYSTEM_BOOTANIMATION_ROTATION_SHU_FILE[] = "/system/media/bootanimation_v.zip"; static const char SYSTEM_SHUTDOWNANIMATION_FILE[] = "/system/media/shutdownanimation.zip"; static const char SYSTEM_ENCRYPTED_BOOTANIMATION_FILE[] = "/system/media/bootanimation-encrypted.zip"; //support boot video static const char DATA_BOOTVIDEO_FILE[] = "/data/local/bootanimation.ts"; -static const char SYSTEM_BOOTVIDEO_FILE[] = "/system/media/bootanimation.ts"; +//static const char SYSTEM_BOOTVIDEO_FILE[] = "/system/media/bootanimation.ts"; + +static const char SYSTEM_BOOTVIDEO_FILE[] = "/system/media/bootanimation.mp4"; static const char SYSTEM_DATA_DIR_PATH[] = "/data/system"; static const char SYSTEM_TIME_DIR_NAME[] = "time"; static const char SYSTEM_TIME_DIR_PATH[] = "/data/system/time"; @@ -97,6 +101,8 @@ static const int ANIM_ENTRY_NAME_MAX = 256; static constexpr size_t TEXT_POS_LEN_MAX = 16; static const char BOOT_COMPLETED_PROP_NAME[] = "sys.boot_completed"; static const char BOOTREASON_PROP_NAME[] = "ro.boot.bootreason"; +static int mBootLogoMode = 0; +String8 systemBootanimationFile; // bootreasons list in "system/core/bootstat/bootstat.cpp". static const std::vector "kernel_panic", @@ -116,6 +122,11 @@ BootAnimation::BootAnimation(bool shutdown) : Thread(false), mClockEnabled(true) mReverseAxis = false; mVideoFile = NULL; mVideoAnimation = false; + char property[PROPERTY_VALUE_MAX]; + if (property_get("ro.sf.hwrotation", property, "0") > 0) { + mBootLogoMode = atoi(property); + } if(mShutdown){ sp ISurfaceComposer::eDisplayIdMain)); // primary_display_token @@ -343,11 +354,23 @@ status_t BootAnimation::readyToRun() { mFlingerSurfaceControl = control; mFlingerSurface = s; + mDataZipAnimtaion = false; + // If the device has encryption turned on or is in process // of being encrypted we show the encrypted boot animation. char decrypt[PROPERTY_VALUE_MAX]; property_get("vold.decrypt", decrypt, ""); bool encryptedAnimation = atoi(decrypt) != 0 || !strcmp("trigger_restart_min_framework", decrypt); + if (mBootLogoMode == 0||mBootLogoMode == 180) { + ALOGE("SYSTEM_BOOTANIMATION_ROTATION_HENG_FILE"); + systemBootanimationFile = SYSTEM_BOOTANIMATION_ROTATION_HENG_FILE; + }else if(mBootLogoMode == 90||mBootLogoMode == 270){ + ALOGE("GCC SYSTEM_BOOTANIMATION_ROTATION_SHU_FILE"); + systemBootanimationFile = SYSTEM_BOOTANIMATION_ROTATION_SHU_FILE; + }else { + ALOGE("SYSTEM_BOOTANIMATION_ROTATION_HENG_FILE"); + systemBootanimationFile = SYSTEM_BOOTANIMATION_ROTATION_HENG_FILE; + } if (!mShutdown) { if (encryptedAnimation && (access(SYSTEM_ENCRYPTED_BOOTANIMATION_FILE, R_OK) == 0)) { mZipFileName = SYSTEM_ENCRYPTED_BOOTANIMATION_FILE; @@ -355,8 +378,8 @@ status_t BootAnimation::readyToRun() { else if (access(OEM_BOOTANIMATION_FILE, R_OK) == 0) { mZipFileName = OEM_BOOTANIMATION_FILE; } - else if (access(SYSTEM_BOOTANIMATION_FILE, R_OK) == 0) { - mZipFileName = SYSTEM_BOOTANIMATION_FILE; + else if (access(systemBootanimationFile, R_OK) == 0) { + mZipFileName = systemBootanimationFile; } //add for boot video @@ -747,7 +770,7 @@ bool BootAnimation::parseAnimationDesc(Animation& animation) part.count = 1; part.pause = 0; part.audioData = NULL; - part.animation = loadAnimation(String8(SYSTEM_BOOTANIMATION_FILE)); + part.animation = loadAnimation(String8(systemBootanimationFile)); if (part.animation != NULL) animation.parts.add(part); } diff --git a/cmds/bootanimation/BootAnimation.h b/cmds/bootanimation/BootAnimation.h index cc043bb..4f263bb 100755 --- a/cmds/bootanimation/BootAnimation.h +++ b/cmds/bootanimation/BootAnimation.h @@ -160,6 +160,7 @@ private: bool mSystemBoot; String8 mZipFileName; bool mVideoAnimation; + bool mDataZipAnimtaion; char* mVideoFile; nsecs_t mStartbootanimaTime; int mBootVideoTime; |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 18:13 , Processed in 0.559861 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1012
