RK3399添加8822cs模块驱动
WIFI调试: 1.修改WIFI配置的dts: rk3399-xxxx.dtsi wireless-wlan {undefined compatible = "wlan-platdata"; rockchip,grf = <&grf>; wifi_chip_type = "rtl8822cs"; sdio_vref = <1800>; WIFI,host_wake_irq = <&gpio0 3 GPIO_ACTIVE_HIGH>; /* GPIO0_a3 */ status = "okay"; }; 2.添加驱动 将供应商提供的驱动放在目录:kerneldriversnetwirelessrockchip_wlan 修改当前目录下makefile: obj-$(CONFIG_RTL8822CS) += rtl8822cs/ 修改kconfig: source "drivers/net/wireless/rockchip_wlan/rtl8822cs/Kconfig" 修改rtl8822cs/makefile: CONFIG_PLATFORM_I386_PC=n CONFIG_PLATFORM_ARM_RK3188=y make ARCH=arm64 menuconfig 添加勾选 Device Drivers ---> 3.添加芯片类型枚举: kernel/net/rfkill/rfkill-wlan.c 在int get_wifi_chip_type(void)添加 } else if (strcmp(wifi_chip_type_string, "rtl8822cs") == 0) {undefined type = WIFI_RTL8822CS; kernel/include/linux/rfkill-wlan.h 添加芯片枚举: enum {undefined WIFI_RK901, WIFI_RK903, WIFI_AP6181, WIFI_AP6210, WIFI_AP6XXX_SERIES, WIFI_RTL8188EU, WIFI_RTL8192DU, WIFI_RTL8723AS, WIFI_RTL8723BS, WIFI_RTL8822CS, WIFI_RTL8812AU, WIFI_RTL8822CS, WIFI_RTL_SERIES, WIFI_ESP8089, TYPE_MAX, }; 4. 然后编译内核 编译出8822cs.ko 5.上层VID PID加进去,命令查看后调整正确。 cat /sys/bus/sdio/devices/mmc2:0001:1/uevent DRIVER=rtl88x2cs SDIO_CLASS=07 SDIO_ID=024C:C822 MODALIAS=sdio:c07v024CdC822 这一步如果devices目录下没有节点 可以检查下硬件。 添加: hardwarelibhardware_legacywifirk_wifi_ctrl.c static wifi_device supported_wifi_devices[] = {undefined + {"RTL8822CS", "024c:c822"}, {"RTL8188FU", "0bda:f179"}, {"RTL8822BU", "0bda:b82c"}, {"RTL8189ES", "024c:8179"}, ALOGD("PCIE WIFI identify sucess"); else {undefined ALOGD("maybe there is no u*** wifi or sdio or pcie wifi,set default wifi module Brocom APXXX"); - strcpy(recoginze_wifi_chip, "APXXX"); + strcpy(recoginze_wifi_chip, "RTL8822CS"); identify_sucess = 1 ; } } diff --git a/wifi/wifi.c b/wifi/wifi.c index 04da01c..73d0f5d 100755 --- a/wifi/wifi.c +++ b/wifi/wifi.c @@ -95,6 +95,7 @@ extern int ifc_down(const char *name); #define RTL8192DU_DRIVER_MODULE_PATH "/system/lib/modules/8192du.ko" #define RTL8812AU_DRIVER_MODULE_PATH "/system/lib/modules/8812au.ko" #define RTL8822BE_DRIVER_MODULE_PATH "/system/lib/modules/8822be.ko" +#define RTL8822CS_DRIVER_MODULE_PATH "/system/lib/modules/8822cs.ko" #define SSV6051_DRIVER_MODULE_PATH "/system/lib/modules/ssv6051.ko" #define ESP8089_DRIVER_MODULE_PATH "/system/lib/modules/esp8089.ko" #define BCM_DRIVER_MODULE_PATH "/system/lib/modules/bcmdhd.ko" @@ -112,6 +113,7 @@ extern int ifc_down(const char *name); #define RTL8189FS_DRIVER_MODULE_NAME "8189fs" #define RTL8192DU_DRIVER_MODULE_NAME "8192du" #define RTL8812AU_DRIVER_MODULE_NAME "8812au" +#define RTL8812AU_DRIVER_MODULE_NAME "8822cs" #define SSV6051_DRIVER_MODULE_NAME "ssv6051" #define ESP8089_DRIVER_MODULE_NAME "esp8089" #define BCM_DRIVER_MODULE_NAME "bcmdhd" @@ -206,6 +208,7 @@ wifi_ko_file_name module_list[] = {"RTL8189ES", RTL8189ES_DRIVER_MODULE_PATH, UNKKOWN_DRIVER_MODULE_ARG}, {"RTL8723BS", RTL8723BS_DRIVER_MODULE_PATH, UNKKOWN_DRIVER_MODULE_ARG}, {"RTL8723CS", RTL8723CS_DRIVER_MODULE_PATH, UNKKOWN_DRIVER_MODULE_ARG}, + {"RTL8822CS", RTL8822CS_DRIVER_MODULE_PATH, UNKKOWN_DRIVER_MODULE_ARG}, {"RTL8723DS", RTL8723DS_DRIVER_MODULE_PATH, UNKKOWN_DRIVER_MODULE_ARG}, {"RTL8812AU", RTL8812AU_DRIVER_MODULE_PATH, UNKKOWN_DRIVER_MODULE_ARG}, {"RTL8189FS", RTL8189FS_DRIVER_MODULE_PATH, UNKKOWN_DRIVER_MODULE_ARG}, 蓝牙调试: 替换供应商给的./hardware/realtek/rtkbt目录 在替换:rtl8822cs_config rtl8822cs_fw 两个文件 整体make 编译一下烧录 调试命令: cat /sys/bus/sdio/devices/mmc2:0001:1/uevent //可查看SDIO设备ID cat /sys/kernel/debug/mmcx/ios //可查看WIFI_sdio 相关信息 logcat | grep WifiHW //查看WIFI加载信息 WIFI 芯片识别流程 1. 开机对 wifi 模块上电,并自动进行扫描 sdio 操作。 2. 系统启动打开 wifi 操作时, 分别对系统 sys/bus/sdio(sdio wifi), sys/bus/u***(u*** wifi), sys/bus/pic (pcie wifi )文件系统下的 uevent 进行读取。 3. 获取到 wifi 芯片 vid pid 加载相应的 wifi ko 驱动。 4. 识别到 wifi 类型后加载不同的 wpa_supplicant 参数启动 wifi。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1988 浏览 1 评论
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
2490 浏览 1 评论
RK3588 GStreamer调试四路鱼眼摄像头四宫格显示报错
5272 浏览 1 评论
【飞凌嵌入式OK3576-C开发板体验】RKNN神经网络-YOLO图像识别
254 浏览 0 评论
【飞凌嵌入式OK3576-C开发板体验】SSH远程登录网络配置及CAN通讯
1336 浏览 0 评论
浏览过的版块 |
GMT+8, 2024-11-25 09:26 , Processed in 0.618763 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
