运行环境: X86, Linux16.04, python3.6
下载rknn_toolkit: https://eyun.baidu.com/s/3nwnPxsX#sharelink/path=%2F 运行下列commands: sudo apt-get install python3.6 sudo apt-get install python3-pip cd package/ pip3 install tensorflow (>1.11, <2.0) pip3 install opencv-python (> 3.4.1) sudo pip3 install rknn_toolkit-1.2.1-cp36-cp36m-linux_x86_64.whl 检测rknn是否安装成功: rk@rk:~/rknn-toolkit-v1.2.1/package$ python3 from rknn.api import RKNN 在rk3399pro上部署环境 参考官网: http://wiki.t-firefly.com/zh_CN/3399pro_npu/npu_rknn_toolkit.html#cheng-xu-an-zhuang 在3399Pro中安装 Ubuntu 18.04 基础依赖安装: sudo apt-get update sudo apt-get install -y cmake python3 python3-pip python3-opencvpython3-numpypython3-h5py python3-lmdb libhdf5-serial-dev libgfortran5-dbg protobuf-compiler pip3 install cython pip3 install --user scipy-1.2.0-cp36-cp36m-linux_aarch64.whl pip3 install --user onnx -i https://mirrors.aliyun.com/pypi/simple/ --trusted-host=mirrors.aliyun.com (不要用whl) pip3 install --user tensorflow-1.10.1-cp36-cp36m-linux_aarch64.whl -i https://mirrors.aliyun.com/pypi/simple/ -trusted-host=mirrors.aliyun.com pip3 install --user rknn_toolkit-1.0.0-cp36-cp36m-linux_aarch64.whl -i https://mirrors.aliyun.com/pypi/simple/ -trusted-host=mirrors.aliyun.com 完成后运行python3 multi-person-openpose_rknn-cam.py ERRORS: 1.wrong numpy version: Solution: run following command repeatedly until none is found pip3 uninstall numpy 2.Fixing numpy.distutils.system_info.NotFoundError: No lapack/blas resources found on Ubuntu Solution: sudo apt-get -y install liblapack-dev libblas-dev sudo apt-get install -y gfortran 3.No usable temporary directory found in [’/tmp’, ‘/var/tmp’, ‘/usr/tmp’, '/home/firefly/rknnlib’] Solution:sudo reboot 重启电脑 4.在运行pip3 install --user rknn_toolkit-1.0.0-cp36-cp36m-linux_aarch64.whl时出现以下Error: Command “/usr/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-build-sv3jji_d/scipy/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’rn’, ‘n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-0syk3d4r-record/install-record.txt --single-version-externally-managed --compile --user --prefix=” failed with error code 1 in /tmp/pip-build-sv3jji_d/scipy/ Solution: 加sudo。 注意使用pip时尽量不要加sudo,除非没有其他解决方法 5.raise DistutilsOptionError("can’t combine user with prefix, " distutils.errors.DistutilsOptionError: can’t combine user with prefix, exec_prefix/home, or install_(plat)base Solution: 手动输入命令,不要用复制黏贴,可能复制时复制了不可识别的字符。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
431 浏览 0 评论
524 浏览 1 评论
1789 浏览 1 评论
3043 浏览 1 评论
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
3771 浏览 1 评论
GMT+8, 2024-12-19 13:09 , Processed in 0.657725 second(s), Total 70, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
