1个回答
一、ITStatus USART_GetITStatus(USART_TypeDef* USARTx, uint16_t USART_IT)在判断相应位是否置1(读SR寄存器)前会先判断相应位的中断是否使能(读CR寄存器)。
所以若使用 while(USART_GetITStatus(USART1,USART_IT_TC) != SET); 来进行判断数据是否发送完成, 注意需使能TC中断 USART_ITConfig(USART1, USART_IT_TC, ENABLE); 否则会一直返回0导致死在while里。 /** * @brief Checks whether the specified USART interrupt has occurred or not. * @param USARTx: Select the USART or the UART peripheral. * This parameter can be one of the following values: * USART1, USART2, USART3, UART4 or UART5. * @param USART_IT: specifies the USART interrupt source to check. * This parameter can be one of the following values: * @arg USART_IT_CTS: CTS change interrupt (not available for UART4 and UART5) * @arg USART_IT_LBD: LIN Break detection interrupt * @arg USART_IT_TXE: Tansmit Data Register empty interrupt * @arg USART_IT_TC: Transmission complete interrupt * @arg USART_IT_RXNE: Receive Data register not empty interrupt * @arg USART_IT_IDLE: Idle line detection interrupt * @arg USART_IT_ORE: OverRun Error interrupt * @arg USART_IT_NE: Noise Error interrupt * @arg USART_IT_FE: Framing Error interrupt * @arg USART_IT_PE: Parity Error interrupt * @retval The new state of USART_IT (SET or RESET). */ ITStatus USART_GetITStatus(USART_TypeDef* USARTx, uint16_t USART_IT) { uint32_t bitpos = 0x00, itmask = 0x00, usartreg = 0x00; ITStatus bitstatus = RESET; /* Check the parameters */ assert_param(IS_USART_ALL_PERIPH(USARTx)); assert_param(IS_USART_GET_IT(USART_IT)); /* The CTS interrupt is not available for UART4 and UART5 */ if (USART_IT == USART_IT_CTS) { assert_param(IS_USART_123_PERIPH(USARTx)); } /* Get the USART register index */ usartreg = (((uint8_t)USART_IT) >> 0x05); /* Get the interrupt position */ itmask = USART_IT & IT_Mask; itmask = (uint32_t)0x01 << itmask; if (usartreg == 0x01) /* The IT is in CR1 register */ { itmask &= USARTx->CR1; } else if (usartreg == 0x02) /* The IT is in CR2 register */ { itmask &= USARTx->CR2; } else /* The IT is in CR3 register */ { itmask &= USARTx->CR3; } bitpos = USART_IT >> 0x08; bitpos = (uint32_t)0x01 << bitpos; bitpos &= USARTx->SR; if ((itmask != (uint16_t)RESET)&&(bitpos != (uint16_t)RESET)) { bitstatus = SET; } else { bitstatus = RESET; } return bitstatus; } 二、FlagStatus USART_GetFlagStatus(USART_TypeDef* USARTx, uint16_t USART_FLAG)直接判断相应位是否置1(读SR寄存器),而不会判断相应中断是否开启,通常可用于没开启相应中断时进行判断,比如只使用了串口接收到数据进入中断时,只需使能 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); 无需再使能多余的中断。 void USART1_IRQHandler(void) { u8 res; if(USART_GetITStatus(USART1,USART_IT_RXNE) != RESET)//Receive Data register not empty interrupt { res = USART_ReceiveData(USART1); while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) != SET);//判断发送缓冲区是否空 USART_SendData(USART1,res); while(USART_GetFlagStatus(USART1,USART_FLAG_TC) != SET); //while(USART_GetITStatus(USART1,USART_IT_TC) != SET);//需使能TC中断 } USART_ClearFlag(USART1,USART_FLAG_TC); //USART_ClearITPendingBit(USART1,USART_IT_TC); //与USART_ClearFlag同种效果 } /** * @brief Checks whether the specified USART flag is set or not. * @param USARTx: Select the USART or the UART peripheral. * This parameter can be one of the following values: * USART1, USART2, USART3, UART4 or UART5. * @param USART_FLAG: specifies the flag to check. * This parameter can be one of the following values: * @arg USART_FLAG_CTS: CTS Change flag (not available for UART4 and UART5) * @arg USART_FLAG_LBD: LIN Break detection flag * @arg USART_FLAG_TXE: Transmit data register empty flag * @arg USART_FLAG_TC: Transmission Complete flag * @arg USART_FLAG_RXNE: Receive data register not empty flag * @arg USART_FLAG_IDLE: Idle Line detection flag * @arg USART_FLAG_ORE: OverRun Error flag * @arg USART_FLAG_NE: Noise Error flag * @arg USART_FLAG_FE: Framing Error flag * @arg USART_FLAG_PE: Parity Error flag * @retval The new state of USART_FLAG (SET or RESET). */ FlagStatus USART_GetFlagStatus(USART_TypeDef* USARTx, uint16_t USART_FLAG) { FlagStatus bitstatus = RESET; /* Check the parameters */ assert_param(IS_USART_ALL_PERIPH(USARTx)); assert_param(IS_USART_FLAG(USART_FLAG)); /* The CTS flag is not available for UART4 and UART5 */ if (USART_FLAG == USART_FLAG_CTS) { assert_param(IS_USART_123_PERIPH(USARTx)); } if ((USARTx->SR & USART_FLAG) != (uint16_t)RESET) { bitstatus = SET; } else { bitstatus = RESET; } return bitstatus; } 总结:我认为在GetITStatus和GetFlagStatus不仅在串口中是这种区别,在其他地方比如外部中断中使用也是类似道理。 |
只有小组成员才能发言,加入小组>>
3210 浏览 9 评论
2896 浏览 16 评论
3404 浏览 1 评论
8848 浏览 16 评论
3998 浏览 18 评论
9629浏览 3评论
1010浏览 3评论
523浏览 2评论
const uint16_t Tab[10]={0}; const uint16_t *p; p = Tab;//报错是怎么回事?
524浏览 2评论
用NUC131单片机UART3作为打印口,但printf没有输出东西是什么原因?
2251浏览 2评论
GMT+8, 2024-10-4 09:52 , Processed in 0.927498 second(s), Total 79, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
