按键后没有反应,不知道哪里的问题,急啊!!!那位大神帮帮忙,不胜感激!!!
// Crystal: 8.0000Mhz #include #include void port_init(void) { PORTA = 0x00; DDRA = 0x00; PORTB = 0x00; DDRB = 0x00; PORTC = 0x00; //m103 output only DDRC = 0x00; PORTD = 0x00; DDRD = 0x00; } void time0_init(void) { TCCR0=0x0D; TCNT0=0x00; OCR0=0x4E; TIMSK |=0x02; TIFR |=0x02; } //call this routine to initialize all peripherals void init_devices(void) { //stop errant interrupts until set up CLI(); //disable all interrupts port_init(); time0_init(); SEI(); //re-enable interrupts //all peripherals are now initialized } /************************************************************************* 用 途:LCD1602显示 Taget :mega8 crystal :8M 介 绍:用PB做端口, PC0-D0 PC7-D7 ------ PA4-6 PA3-5 PA2-4----456为控制引脚 入口参数: 出口参数: *************************************/ //延时程序 void delay(unsigned int ms) { unsigned int i,j; for(i=0;i } //送指令子程序 void com_lcd(unsigned char com) { PORTA&=~(1< PORTA|=(1< PORTA&=~(1< //送数据子程序 void data_lcd(unsigned char data) { PORTA&=~(1< PORTA|=(1< PORTA&=~(1< //初始化 void LCD1602_init() { DDRC=0XFF; DDRA|=0X1C; PORTA&=~(1< delay(15); com_lcd(0x38); delay(5); com_lcd(0x38); delay(5); com_lcd(0x38); delay(5); com_lcd(0x38);//5*7,2行显示 delay(5); com_lcd(0x08); //清屏 delay(5); com_lcd(0x01); //清屏 delay(5); com_lcd(0x06);//文字不动,光标自动右移 delay(5); com_lcd(0x0C);//开显示 delay(5); } //定位x,y(x-列,y-行) void LCD1602_goxy(unsigned char line,unsigned char row) { if (row==0) line+=0x80; else line+=0xc0; com_lcd(line);//第二行首地址 delay(5); } //显示字符串 LCD1602_print(char *str) { while(*str) { data_lcd(*str); delay(10); str++; } } //************************************************************************** /************************************************ 按键初始化 *******************************/ unsigned char get_key0(void) { static unsigned char key_flag = 0; if (key_flag == 0) { if((PINA & 0x20)==0x00 ) { key_flag = 1; } } else if (key_flag == 1) { if((PINA & 0x20) == 0x20 ) { key_flag = 0; return (1); } } return (0); } unsigned char key0_flag =0; unsigned char nokey_flag =0; #pragma interrupt_handler timer0_comp_isr:20 void timer0_comp_isr() { static unsigned int key_count = 0;//compare occured TCNT0=OCR0 TIFR |=0x02; TCNT0=0x00; if (get_key0()==1) { key_count = 0; key0_flag = 1; } } /********************************************************* 主函数 **************************************************/ void main() { unsigned char i=23; init_devices(); LCD1602_init(); LCD1602_goxy(0,0); LCD1602_print("nokey is pressed"); while(1) { if (key0_flag == 1) { LCD1602_print("key0 is pressed"); key0_flag = 0; } } } |
1个回答
谢谢分享。。。。。。。。。。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
4327 浏览 0 评论
5845 浏览 0 评论
PROTUES仿真no model specified for adc0809,谁有ADC0809的model?
18106 浏览 1 评论
单片机应用技术的ISIS professional电路设置仿真老是报错怎么办
18348 浏览 0 评论
21674 浏览 3 评论
/9
GMT+8, 2025-12-11 05:10 , Processed in 0.678979 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2556
