编译到最后一步,无法成功。源码是不完整的
LD [M] drivers/net/wireless/intel/iwlwifi/mvm/iwlmvm.o AR driver/ net/wireless/built-in.o AR 驱动程序/net/built-in.o make[3]: *** [/media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel /Makefile :1040: 驱动程序] 错误 2 make[3]: 离开目录 '/media/OK10xx-linux-fs/flexbuild/build/linux/linux/arm64/output' make[2]: *** [Makefile:146 : sub-make] 错误 2 make[2]: 离开目录 '/media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel' make[1]: *** [Makefile:25: build - linux] 错误 2 make[1]: 离开目录 '/media/OK10xx-linux-fs/flexbuild/packages/linux' make: *** [Makefile:24: linux] 错误 2 make:离开目录'/media/OK10xx -linux-fs/flexbuild' 往上看有下面错误 /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/include/linux/fsl_qman.h :415:1: :'struct qm_eqcr_entry'错误1 小于8 [-Werror=packed-not-aligned] 415 | __打包; | ^ /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/include/linux/fsl_qman.h:469:3: 错误:'struct 469 | __packed ern; | ^ /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/include/linux/fsl_qman.h:468:17:错误:'struct 468 |结构 qm_fd fd; | ^~ /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/include/linux/fsl_qman.h:486:3: :错误:'struct 486 | __packed dcern; | ^ /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/include/linux/fsl_qman.h:485:17:错误:'struct 485 |结构 qm_fd fd; | ^~ /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/include/linux/fsl_qman.h:1679:1: 错误:'struct qm_mcr_ceetm_cq_peek_pop_xsfdrread' 1 小于 8 [-Werror=包装-不aligne ] 1679 | __打包; | ^ /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/include/linux/fsl_qman.h:1677:15:错误:'struct qm_mcr_ceetm_cq_peek_pop_xsfdrread'中的'fd'插入14'不是'到 8 [-Werror=packed-not-aligned] 1677 | struct qm_fd fd; 打完0001-To-fix-build-error-for-gcc8.patch打打补丁后,重编译还是加工值[-Werror=address-of-packed-member] 965 | &mcr->querycongestion.state, &p->cgrs[0]); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~ CC 驱动程序 /u***/core/message.o 包含在 /media/OK10xx-linux-fs/文件中flexbuild/packages/linux/OK10xx-linux-kernel/include/linux/byteorder/little_endian.h:5, 来自/media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/arch/ arm64/include/uapi/asm/byteorder.h:23, 来自/media/OK10xx-linux-fs/flexbuild/包/linux/OK10xx-linux-kernel/include/asm-generic/bitops/le.h:6, 来自/media/OK10xx-linux-fs/flexbuild/packages/ linux/OK10xx-linux-kernel/arch/arm64/include/asm/bitops.h:50, 来自/media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/include/linux/bitops. h:38, 来自/media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/include/linux/kernel.h:11, 来自/media/OK10xx-linux-fs/flexbuild/packages/ linux/OK10xx-linux-kernel/drivers/staging/fsl_qbman/dpa_sys.h:35, 来自/media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/drivers/staging/fsl_qbman/qman_private。小时:32, 来自/media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/drivers/staging/fsl_qbman/qman_low.h:32, 来自/media/OK10xx-linux-fs/flexbuild/packages/linux/ OK10xx-linux-kernel/drivers/staging/fsl_qbman/qman_high.c: 32: /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/drivers/staging/fsl_qbman/qman_high.c:在函数'qman_query_cgr'中: /media/OK10xx-linux-fs/flexbuild/包/linux/OK10xx-linux-kernel/drivers/staging/fsl_qbman/qman_high.c:2255:17: 错误:获取“struct qm_mcr_querycgr”的打包[-Werror=address-of -打包成员] 2255 | be32_to_cpus(&cgrd->cscn_targ_swp ); /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/include/uapi/linux/byteorder/little_endian.h:101:38: 注意:在宏 '__be32_to_cpus' 101 的定义中| #define __be32_to_cpus(x) __swab32s((x)) | ^ /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/drivers/staging/fsl_qbman/qman_high.c:2255:4:注意:宏'be32_to_cpus' 2255的扩展| be32_to_cpus(&cgrd->cscn_targ_swp ); | ^~~~~~~~~~~~ /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/drivers/staging/fsl_qbman/qman_high.c:在函数“qman_query_congestion”中: /media/OK10xx-linux-fs/flexbuild/packages/linux/OK10xx-linux-kernel/drivers/staging/fsl_qbman/qman_high.c:2287:17: 错误:获取“struct qm_mcr_querycongestion”的打包成员的地址可能会导致未对齐的指针值 [-Werror=address-of-packed-member] 2287 | be32_to_cpus(&congestion->state.__state ); 编译脚本: #!/bin/bash current_path=$PWD work_path=$PWD/flexbuild cd $work_path && . setup.env && #flex-builder -i clean-apps && flex-builder clean && #flex-builder -c linux -a arm6 #flex-builder -c linux: 操作系统:UBUNTU20.4 in windows10细胞 原始文件包OK10xx-linux-fs.tar.bz2 时间比较着急,没时间慢慢debug |
1个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 09:26 , Processed in 0.597998 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
620
