扫一扫,分享给好友
移植AP6181wifi模块驱动打印如下:wlan0,无法配置,wifi无法使用,谁能指导一下a40-p1:/# insmod /system/vendor/modules/bcmdhd.ko
[ 798.670459] dhd_module_init: in [ 798.674101] ==== ==== bcm_wlan_set_plat_data ====== [798.679640] host_oob_irq:165 [798.683259] host_oob_irq_flags = 0x4084 [798.687292] dhd_wifi_platform_set ' 091 dhd_wifi_platform_set ' 861电源适配器= 798 dhd_wifi 9 7 9 6 8 6 1 6 8 1 6 8 1 6 1 6 1 6 1 6 8 1 6 8 1 6 8 1 6 8 6 1 6 1 6 8 1 6 8 6 8 3 259 798.683259 798.702727] ======拉高WL_REG_ON!=== ===== [798.711029] sunxi-wlan wlan.23:检查 wlan wlan_power 电压:3300000 [798.720586] sunxi-wlan wlan.23:检查 wlan io_regulator 电压:3300000 [7989.0400000000] [799.046340] sunxi-wlan wlan.23: bus_index: 1 [ 799.051277] ========卡检测检测SDIO卡!======== [799.750679] sunxi-mmc0.sd0mmc 1c1sd :vqmmc,检查组是否有调节器 [799.80899]mmc2元85:没有未知的未知CIS组0x80(2字节) [799.817218000000000000000000未知CIS元组](3字节) [799.820000 CIS组0x820827000000000000000000000000000000000000000000000000000 CIS 组0x82082700000000000000000000000000000000000 CIS 组0x8208270000节) [ 799.8378831 ] mmc2客户端客户端CIS 元组 0x80(7 字节) [ 79.8479 ] mmc2:705909 mmc2:8705900 mmc2 注册未知高速数据 :地址为 0001 [ 79驱动程序 SD 0x80(7 字节)8479 字节程序 [ 799.912835] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter [799.918690] bcmsdh_sdmmc:bcmsdh_sdmmc_probe [799.924419]线程数(主机IDX.5'9)[799.924419]线程数 (主机IDX) [9]HD7'799.918690]HD [799.936051] sdioh_attach:组sd_f2_blocksize 128 [799.941967] dhdsdio_probe:没有互斥锁。组锁 [799.947821] F1签名读@ 0x18000000 = 0x1591a962 [799.955544] dhd_conf_set_hw_oob_intr:启用HW OOB为43362 [799.964885] F1签名行,socitype:为为0x1芯片:0xa962启:为为0x1 PKG:0x9 [799.973471] DHD:加密狗RAM大小是设置为245760(原稿245760)在为0x0 [799.982023] dhd_conf_set_chiprev:芯片= 0xa962,chiprev = 1 [799.987913] dhd_conf_set_conf_path_by_nv_config /系统/模块/模块 [800.001838] wl_create_event_handler():螺纹:wl_event_handler:61D1开始 [800.001866] TSK输入,啧= 0xe16a14a0 [800.018977] dhd_attach():螺纹:dhd_watchdog_thread:61d4开始 [800.026333] dhd_attach():螺纹:dhd_dpc:61d5开始 [800.026349 ] dhd_dpc_thread:组从config.txt的dpc_cpucore 0 [80.038780] dhd_attach():螺纹:dhd_rxf:61d7开始 [800.044705] dhd_deferred_work_init: 驱动工作初始化800.066710] 加密狗主机驱动程序,版本1.201.59.6(8001.59.6)[ 801.59.6][801606068060606806068068068060680680680680680680687878780.038780.066710.066780.06710.06710.06710.06710.038710.06710.038710.067107878787878787878787878787878787878787878780. 2021年2月23日 14时27分29秒[800.095258]注册INTE ** CE [为wlan0] MAC:B0:02:47:3F:A2:9F [800.095258] [800.103806] dhd_prot_ioctl:已总线关闭我们什么都没有做 [800.111162] bcmsdh_oob_intr_unregister:输入 [800.115970] bcmsdh_oob_intr_unregister:IRQ未注册 [800.122628] dhd_txglom_enable:启用0 [800.126828] dhd_conf_set_txglom_params:swtxglom = 0,txglom_ext = 0 [800.133694] dhd_conf_set_txglom_params:txglom_bucket_size = 0 [800.140091] dhd_conf_set_txglom_params:txglomsize = 0,deferred_tx_len = 0,bus_txglom = 0 [800.148713] dhd_conf_set_txglom_params:tx_in_rx = 1,tx_max_offset = 0 [800.155884] dhd_bus_devreset:WLAN OFF DONE [800.160892] wifi_platform_set_power = 0 ![800.165102] ==拉低WL_REG_ON ====== [800.171700] dhdsdio_probe :锁被释放。 [800.177646]dhd_module_init:退出错误=0 a40-p1:/# |
1个回答
A40i android系统自带驱动和wifi1不支持AP618
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
458 浏览 0 评论
716 浏览 1 评论
620 浏览 1 评论
1850 浏览 1 评论
3099 浏览 1 评论
GMT+8, 2024-12-20 17:48 , Processed in 0.700210 second(s), Total 72, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
