[make@archlinux tools]$ 。/phoenixMC
Version: v1.2.00815b(by notebook) phoenixMC_u -A [debug flash address] (default: 0x00000000) phoenixMC_u -b [baud rate] (default: 921600) phoenixMC_u -B [flash debug bin file for write] (default: a.bin) phoenixMC_u -c [com dev] (default: /dev/ttyUSB0) phoenixMC_u -C [config file] (default: 。/settings.ini) phoenixMC_u -d [debug log level] (default: 0) phoenixMC_u -D [debug flash mode] (default: n=NULL) phoenixMC_u -e [enable etf image] (default: 0) phoenixMC_u -f [enable flash compat] (default: 1) phoenixMC_u -g [enable combine images] phoenixMC_u -G [combine image path] (default: combine_image.cimg) phoenixMC_u -h [help msg] phoenixMC_u -i [wlan image path] (default: xr-system.img) phoenixMC_u -I [ETF image path] (default: xr-system_etf.img) phoenixMC_u -l [log file path] (default: 。/log/log.txt) phoenixMC_u -L [debug flash length] (default: 0x00000200) phoenixMC_u -r [read and check after write] (default: 0) phoenixMC_u -s [show image info] phoenixMC_u -u [update changed blocks only] (default: 1) phoenixMC_u -v [show version] When it‘s upgrading, input ’stop‘ to stop it if you need. --------------SETTING-------------- COM:/dev/ttyUSB0 Baud:921600 Log path:。/log/log.txt Log level:0 Image path:。./out/xr_system.img ETF image path:xr_system_etf.img Read and check:NO Update change only:YES Program ETF image:NO Use flash compat:YES ************************************************* firmware information ************************************************* ******************************************************************************************************************* bin version: 5 bin count: 6 No. ID sram_offs data_size next_section attribute private 1 0xA5FF5A00 0x00230000 0x000061C0 0x00008000 0x00000001 0xFFFFFFFFFFFFFFFFFC05FFFF 2 0xA5FE5A01 0x00201000 0x0000EDB0 0x00018000 0x00000001 0xFFFFFFFFFFFFFFFFFFFFFFFF 3 0xA5FD5A02 0xFFFFFFFF 0x0008B360 0x0010B800 0x00000002 0xFFFFFFFFFFFFFFFFFFFFFFFF 4 0xA5FA5A05 0xFFFFFFFF 0x00000910 0x0010C400 0x00000001 0xFFFFFFFFFFFFFFFFFFFFFFFF 5 0xA5F95A06 0xFFFFFFFF 0x00006394 0x00112800 0x00000001 0xFFFFFFFFFFFFFFFFFFFFFFFF 6 0xA5F85A07 0xFFFFFFFF 0x00000318 0xFFFFFFFF 0x00000001 0xFFFFFFFFFFFFFFFFFFFFFFFF ******************************************************************************************************************* not Combined image!! 3%: Opening com.。. magic:0x202C7373, 0x4D4F5242 Invalid response! 我只修改了/home/make/xr806_openharmony/device/xradio/xr806/ BUILD.gn import(“//build/lite/config/subsystem/lite_subsystem.gni”) import(“//build/lite/config/component/lite_component.gni”) import(“//base/security/huks/build/config.gni”) build_ext_component(“libSDK”) { exec_path = rebase_path(“。”, root_build_dir) outdir = rebase_path(“$root_out_dir”) command = “。/build.sh ${outdir}” deps = [ “//build/lite/:ohos”, “//kernel/liteos_m:kernel”, “os:liteos_glue”, ] if (IsBootloader == “false”) { deps += [ “adapter/hals:adapter”, #“adapter/console:app_console”, “ohosdemo:ohosdemo” ] } if (disable_huks_binary == true) { deps += [ “//base/security/huks/frameworks/huks_lite:huks_sdk”, ] } } group(“xr806”) { } ```` |
只有小组成员才能发言,加入小组>>
1310 浏览 0 评论
为了学习内核开发,大佬手搓了一个轻量级操作系统YiYiYa OS
1346 浏览 0 评论
1015 浏览 0 评论
1152 浏览 0 评论
1019 浏览 0 评论
【开源硬件大赛】基于全志V853设计的全功能BTB学习开发板
3288浏览 8评论
2940浏览 5评论
1762浏览 4评论
全志V85x硬件设计大赛作品精选第二期,快来Pick你心目中的最佳方案
82962浏览 3评论
3349浏览 3评论
GMT+8, 2024-9-28 16:27 , Processed in 0.705281 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
