电子发烧友论坛|
前天经过大佬指点已经顺利的将melis跑在D1上了。
现在又切换到D1S上来跑,发现遇到类似问题,跑起来就挂了。 根据当时D1的修改配置方法,在F133的project配置里已经是类似D1上面的配置修改了,但是不知道为啥,还会起来就挂。 下面是启动日志: [142]HELLO! BOOT0 is starting! [144]BOOT0 commit : 889f614 ***i2ekernel =============================================================================================================== | /'_/` (_ ) _ /'_ ) /'_ ` /' _` | | | | __ | | (_) ___ ______ _ _ (_)_) | ( (_) | | ( ) | | | | (_) | /'__` | | | |/',__)(______)( ) ( ) _(_ < __, | | | | | | | | | | |( ___/ | | | |__, | _/ |( )_) | _ | | _ | (_) | | | (_) (_)`____)(___)(_)(____/ `___/'`____)(_) (_)(_)`___/' | |version : V3.9.0 | |commitid: 976499a346a3d5d6d80047f3844d1d5c3e37ac55 | |sunxiver: 30800 | |timever : Thu, 04 Nov 2021 20:14:43 +0800 | |compiler: gcc version 8.4.0 (T-HEAD RISCV Tools V1.10.2 B20201104) | |optimal : -Os -g -gdwarf-2 -gstrict-dwarf | |linker : GNU ld (GNU Binutils) 2.32 | |newlibc : 3.0.0 | |author : zhouji | =============================================================================================================== [DBG]: [__mount_parts:0273]: classname=DMS [DBG]: [__mount_parts:0274]: devname=dms01 [DBG]: [__mount_parts:0301]: find last lun. [DBG]: [__mount_parts:0331]: nPart = 1. [DBG]: [__mount_parts:0460]: dmsPart: "DMSdms010" is linked to symbel "B". [ERR]: [esFSYS_pread:0318]: fs fatal err [ERR]: [esFSYS_pread:0318]: fs fatal err [ERR]: [esFSYS_pread:0318]: fs fatal err [ERR]: [esFSYS_pread:0318]: fs fatal err [DBG]: [esFSYS_mntfs:0317]: devfs,mount on B. [DBG]: [kservice_maintask:0834]: partition [B] plug in.. [DBG]: [__mount_parts:0273]: classname=DISK [DBG]: [__mount_parts:0274]: devname=RAMDISK [DBG]: [__mount_parts:0301]: find last lun. [DBG]: [__mount_parts:0331]: nPart = 1. [DBG]: [__mount_parts:0460]: rawpart: "DISKRAMDISK0" is linked to symbel "C". [ERR]: [esFSYS_mntfs:0298]: identify the filesystem failure. [ERR]: [cheduler startup [DBG]: [__mount_parts:0273]: classname=DISK [DBG]: [__mount_parts:0274]: devname=ROOTFS [DBG]: [__mount_parts:0301]: find last lun. [DBG]: [__mount_parts:0331]: nPart = 1. [DBG]: [__mount_parts:0460]: rawpart: "DISKROOTFS0" is linked to symbel "D". [DBG]: [esFSYS_mntfs:0317]: minfs,mount on D. [DBG]: [kservice_maintask:0834]: partition [D] plug in.. [DBG]: [melis_udisk_part_check:0553]: melis_udisk_part_check 553 copy udisk_buff [DBG]: [__mount_parts:0273]: classname=DISK [DBG]: [__mount_parts:0274]: devname=UDISK [DBG]: [__mount_parts:0301]: find last lun. [DBG]: [__mount_parts:0331]: nPart = 1. [DBG]: [__mount_parts:0423]: rawpart: "DISKUDISK0" is linked to symbel "E". [ERR]: [esFSYS_mntfs:0298]: identify the filesystem failure. [ERR]: [__mount_parts:0501]: mount E failure. SDC:hal_sdc_create host:0x401b65d8 id:0 [ERR] SDC:name sdc0_d1,port 6,port_num 0,mul_sel 2, pull 1, drv_level 1 [ERR] SDC:name sdc0_d0,port 6,port_num 1,mul_sel 2, pull 1, drv_level 1 [ERR] SDC:name sdc0_clk,port 6,port_num 2,mul_sel 2, pull 1, drv_level 1 [ERR] SDC:name sdc0_cmd,port 6,port_num 3,mul_sel 2, pull 1, drv_level 1 [ERR] SDC:name sdc0_d3,port 6,port_num 4,mul_sel 2, pull 1, drv_level 1 [ERR] SDC:name sdc0_d2,port 6,port_num 5,mul_sel 2, pull 1, drv_level 1 SDC:Not implement __mci_restore_io,793 SDC:Not imp hal_sdc_init,2206 SDC:hal_sdc_init,2239 no imp SDC:hal_sdc_init,2248 no imp SDC:SDC Host Capability:0x3820f Ocr avail:0x3f0000 SDC:Not implement __mci_hold_io,778 SDC:SDC cd_mode:2 present_val:0 SDC:SDC id:0 dma_use:1 present:0 driver version SD/MMC/SDIO Host Controller Driver(v0.28 2021-08-24 16:50) init ok. host_id =0! [ERR]: [hal_ths_init:0094]: 0x2009404, 0x2009400, 0x2009430, 0x2009408 key name:thermal_sensor key size:64 key offset:20 thermal_sensor: 42 01 bb 98 0e b0 9d 01 the cir_master_init success phy_vbase : 0x4200800, u***c_no : 1, efuse : 0x19db00e [u***_new_phy_print][79] reg[DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init! [DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init! 0x1c : 0x4 [u***_new_phy_print][80] reg [DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init! [DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init! 0x30 : 0xcb [u***_new_phy_print][81] reg 0x60 : 0x22b8 [u***_new_phy_print][82] reg 0x40 : 0x8c [u***_new_phy_print][79] reg 0x1c : 0x0 [u***_new_phy_print][80] reg 0x30 : 0x18b [u***_new_phy_print][81] reg 0x60 : 0x22b8 [u***_new_phy_print][82] reg 0x40 : 0x7c [DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init! [DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init! [DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init! [DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init! [DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init! [DBG]: [console_LKeyDevEvent:0530]: input sys keydev not init! [DBG]: [LDR_LoadFile:0247]: filepath = d:modslib.mod. [DBG]: [LDR_LoadFile:0247]: filepath = d:moddisplay.mod. [DBG]: [LDR_LoadFile:0247]: filepath = d:modmixture.mod. [DBG]: [layer_request:0689]: requested: ch:0, id:0 disp_mgr.req_layer_cnt = 1 [DBG]: [mod2drv_layerinfo:0366]: lbc_mode = 0 [ERR]: [open_lcd_backlight:0610]: get backlight err,default to 100 [DBG]: [LDR_LoadFile:0247]: filepath = d:modcharset.mod. msh />Execute startup script begin.............. install mod para num [2]: insmod d:modorange.mod [DBG]: [LDR_LoadFile:0247]: filepath = d:modorange.mod. Mod:d:modorange.mod Installed!, mod id=120 install mod para num [2]: insmod d:appsdesktop.mod [DBG]: [LDR_LoadFile:0247]: filepath = d:appsdesktop.mod. [DBG]: [DESKTOP_MOpen:0078]: DESKTOP_MOpen. [DBG]: [LDR_LoadFile:0247]: filepath = d:appsinit.axf. Mod:d:appsdesktop.mod Installed!, mod id=127 ...............Execute startup script end [DBG]: [msg_srv_init_key_channel:0150]: emit_ctr.h_keyGraber=0x40d6d1a0 [DBG]: [msg_srv_init_key_channel:0161]: LdevID=0 [DBG]: [application_init_process:0836]: & application_init_process enter! & dsk_reg_read_config_file 571 e:setting.bin eLIBs_fopen fail dsk_reg_init_para 797 config not ok, format e: [DBG]: [esFSYS_mntfs:0317]: fat,mount on E. [DBG]: [kservice_maintask:0834]: partition [E] plug in.. [DBG]: [application_init_process:0854]: application_init_process 854 before live_init [DBG]: [live_init:0040]: ~~~~~~~~~~~~~~before dsk_set_isn_charset~~~~~~~~~~~ [DBG]: [alsa_open_pcm:0218]: open pcm! card:[audiocodec], pcmFlag:[1](0-cap;1-play) [SND_ERR][ksnd_pcm_prepare:2005]unsupport state transform. [DBG]: [dsk_display_set_lcd_brightness:0297]: setting lcd_bright=176 [DBG]: [application_init_process:0862]: application_init_process 862 before gscene_bgd_init [DBG]: [gscene_bgd_is_file_exist:0620]: file is exist:d:resbg_default0.jpg [DBG]: [gscene_bgd_init:0130]: bgd_com->screen_size.width = 800 bgd_com->screen_size.height = 480 ftype = 1 [DBG]: [application_init_process:0883]: .start device monitor ....................................... [DBG]: [application_init_process:0891]: application_init_process 891 before init_mainwin_create [DBG]: [dsk_display_set_lcd_brightness:0297]: setting lcd_bright=192 [DBG]: [__hbar_layer_create:0093]: hbar fb 800 46 gui_dir=0 [DBG]: [__hbar_layer_create:0094]: hbar src 0 0 800 46 [DBG]: [__hbar_layer_create:0095]: hbar scn 0 0 800 46 [DBG]: [reset_headbar_data:0273]: xxxxxx para->data.volume = 30 [DBG]: [reset_headbar_data:0277]: xxxxxx 亮 = 11 [ERR]: [esPINS_ReadPinData:0640]: 引脚句柄无效! [DBG]: [application_init_process:0897]: application_init_process 897 前 _process_init [DBG]: [applet_info_manager_load_dir:0307]: 查找目录文件 d:appsphy_vbase : 0x4101800, u***c_no : 0, efuse : 0x19db00e [u***_new_phy_print][79] 注册 0x1c:0x0 [u***_new_phy_print][80] 注册 0x30:0x18b [u***_new_phy_print][81] 注册 0x60:0x22b8 [u***_new_phy_print][82] 注册 0x40:0x7c [u***_new_phy_print][79] 注册 0x1c:0x0 [u***_new_phy_print][80] 注册 0x30:0x18b [u***_new_phy_print][81] 注册 0x60:0x22b8 [u***_new_phy_print][82] 注册 0x40:0x7c 桌面app_root.desktop! [DBG]: [applet_info_manager_load_file:0267]: 文件名 = d:appsdesktopapp_root.desktop len=124 [DBG]:[__activity_load_common:0395]:加载应用程序application://app_root。 [DBG]: [LDR_LoadFile:0247]: 文件路径 = d:appsapp_root.axf。 card_detect 删除 sdmmc_test->card_id=0 [警告] SD:mmc_card_open 卡不退出!编号:0 开卡失败 [DBG]: [app_home_create:0657]: ******** 进入多屏首页应用程序************** [DBG]: [gscene_bgd_is_file_exist:0620]: 文件存在:d:resbg_default0.jpg [DBG]: [gscene_bgd_set_status_show:0170]: bkpic: d:resbg_default0.jpg。 [DBG]: [LDR_LoadFile:0247]: 文件路径 = d:modvcoder.mod。 [DBG]:[mod2drv_layerinfo:0366]:lbc_mode = 0 [ERR]: [Mod_Display_MIoctrl:1771]: 显示模式中没有这个 CMD [DBG]: [dsktop_scene_get_cur_app:0664]: g_last_desk_app_index:0 [DBG]:[desktop_scene_create:0582]:宽度= 800,高度= 480 [DBG]: [desktop_scene_create:0587]: cur_desk_app_index:0 [DBG]: [GUI_LogicLayerRequest:0527]: src.w = 800 src.h = 480 [DBG]: [layer_request:0689]: 请求: ch:1, id:0 disp_mgr.req_layer_cnt = 1 [DBG]: [GUI_LogicLayerRequest:0527]: src.w = 800 src.h = 46 [DBG]: [layer_request:0689]: 请求: ch:1, id:1 disp_mgr.req_layer_cnt = 2 [DBG]: [reset_headbar_data:0273]: xxxxxx para->data.volume = 30 [DBG]: [reset_headbar_data:0277]: xxxxxx 亮 = 11 [DBG]: [app_root_wincreate:4387]: root win = 40eff8f8 [DBG]: [application_init_process:0918]: GUI_GetMessageEx 之前的 application_init_process 918 |
1个回答
买个1S的开发板就可以接了
只有小组成员才能发言,加入小组>>
【实测】用全志A733平板搭建一个端侧Deepseek算力平台
1669 浏览 0 评论
2534 浏览 0 评论
1589 浏览 0 评论
1780 浏览 0 评论
全志T113双核异构处理器的使用基于Tina Linux5.0——RTOS系统定制开发
2474 浏览 0 评论
6149浏览 1评论
花费200元,我用全志H616和雪糕棒手搓了一台可UI交互的视觉循迹小车
9489浏览 1评论
用39块钱的全志V851se视觉开发板做了个小相机,还可以物品识别、自动追焦!
11223浏览 1评论
2326浏览 1评论
1633浏览 0评论
/9
GMT+8, 2025-12-2 07:01 , Processed in 0.677527 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3297
