电子发烧友论坛|
root@tinaLinux:/# wifi_connect_ap_test test test
================================== connect wpa_supplicant failed,please check wifi driver! wifi on failed spi nand 自带的固件是这样的: root@TinaLinux:/# wifi_connect_ap_test ssid_ubuntu 123456785 ================================== Connecting to the network(ssid_ubuntu)...... [ 49.066175] [STA_WRN] Freq 2412 (wsm ch: 1) prev: 3. [ 49.072027] wlan0: authenticate with e4:26:8b:89:a9:f8 (try 1) [ 49.083424] [STA_WRN] [HT40][xradio_join_work][bss_ht_info]: [ 49.083424] [primary_chan :0x00000001] [ 49.083424] [ht_param :0x00000000] [ 49.083424] [operation_mode:0x00000017] [ 49.083424] [stbc_param :0x00000000] [ 49.083424] [basic_set[0] :0x00000000] [ 49.111324] [STA_WRN] [HT40][xradio_join_work][PhyModeCfg:0x0007] [ 49.111324] [ModemFlags :0x00000007] [ 49.111324] [ChWidthCfg :0x00000000] [ 49.111324] [PriChCfg :0x00000000] [ 49.111324] [BandCfg :0x00000000] [ 49.111324] [STBC_Enable :0x00000000] [ 49.111324] [PreambleCfg :0x00000000] [ 49.111324] [SGI_Enable :0x00000000] [ 49.111324] GF_Enable :0x00000000] [ 49.173244] wlan0: authenticated [ 49.177518] wlan0: associate with e4:26:8b:89:a9:f8 (try 1) [ 49.192728] wlan0: RX AssocResp from e4:26:8b:89:a9:f8 (capab=0x1431 status=0 aid=78) [ 49.202004] wlan0: associated [ 49.212504] [AP_WRN] [STA] ASSOC HTCAP 11N 58 [ 49.217367] [AP_WRN] [HT40][xradio_bss_info_changed][ht_prot:0x0000000e][HtProtMode:0x0003][Green:0x0004] [ 49.217843] [AP_WRN] [HT40][xradio_bss_info_changed][PhyModeCfg:0x5007] [ 49.217843] [ModemFlags :0x00000007] [ 49.217843] [ChWidthCfg :0x00000000] [ 49.217843] [PriChCfg :0x00000000] [ 49.217843] [BandCfg :0x00000000] [ 49.217843] [STBC_Enable :0x00000000] [ 49.217843] [PreambleCfg :0x00000001] [ 49.217843] [SGI_Enable :0x00000001] [ 49.217843] [GF_Enable :0x00000000] [ 49.347203] [TXRX_WRN] [RX] IF=0, No key found. [ 49.652668] [TXRX_WRN] [RX] IF=0, No key found. [ 49.859090] [TXRX_WRN] [RX] IF=0, No key found. [ 51.700693] [TXRX_WRN] [RX] IF=0, No key found. [ 51.906338] [TXRX_WRN] [RX] IF=0, No key found. [ 53.646240] [TXRX_WRN] [RX] IF=0, No key found. [ 53.851963] [TXRX_WRN] [RX] IF=0, No key found. [ 55.694229] [TXRX_WRN] [RX] IF=0, No key found. [ 57.641342] [TXRX_WRN] [RX] IF=0, No key found. [ 59.288146] wlan0: deauthenticating from e4:26:8b:89:a9:f8 by local choice (reason=3) [ 59.297210] [WSM_WRN] Issue unjoin command(TX). [ 59.303604] [WSM_WRN] STA mode, send_deauth_to_self [ 59.309107] [TXRX_WRN] Issue unjoin command(TX) by self. |
2个回答
重新下载一份出场固件试试效果
把同一个 img 文件烧录到 spi flash,wifi连接正常,这是 /etc 目录无写入权限引起
只有小组成员才能发言,加入小组>>
【实测】用全志A733平板搭建一个端侧Deepseek算力平台
1669 浏览 0 评论
2534 浏览 0 评论
1589 浏览 0 评论
1780 浏览 0 评论
全志T113双核异构处理器的使用基于Tina Linux5.0——RTOS系统定制开发
2474 浏览 0 评论
6149浏览 1评论
花费200元,我用全志H616和雪糕棒手搓了一台可UI交互的视觉循迹小车
9489浏览 1评论
用39块钱的全志V851se视觉开发板做了个小相机,还可以物品识别、自动追焦!
11223浏览 1评论
2326浏览 1评论
1633浏览 0评论
/9
GMT+8, 2025-12-2 03:59 , Processed in 0.656098 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2285
