User下的文件:
stm32f10x.h:这个文件类似于51的reg51.h,但功能更多一些,具体内容看文件开头的注释,如下 /* @brief CMSIS Cortex-M3 Device Peripheral Access Layer Header File. * This file contains all the peripheral register's definitions, bits * definitions and memory mapping for STM32F10x Connectivity line, * High density, High density value line, Medium density, * Medium density Value line, Low density, Low density Value line * and XL-density devices. * * The file is the unique include file that the application programmer * is using in the C source code, usually in main.c. This file contains: * - Configuration section that allows to select: * - The device used in the target application * - To use or not the peripheral’s drivers in application code(i.e. * code will be based on direct access to peripheral’s registers * rather than drivers API), this option is controlled by * "#define USE_STDPERIPH_DRIVER" * - To change few application-specific parameters such as the HSE * crystal frequency * - Data structures and the address mapping for all peripherals * - Peripheral's registers declarations and bits definition * - Macros to access peripheral’s registers hardware */简单来说,此为外设接口层头文件,包括了各个型号的单片机寄存器定义和位定义及内存映射,通过宏定义可以进行一些配置,具体如下 通过宏定义选择符合自己单片机的存储空间版本 #if !defined (STM32F10X_LD) && !defined (STM32F10X_LD_VL) && !defined (STM32F10X_MD) && !defined (STM32F10X_MD_VL) && !defined (STM32F10X_HD) && !defined (STM32F10X_HD_VL) && !defined (STM32F10X_XL) && !defined (STM32F10X_CL) #error "Please select first the target STM32F10x device used in your application (in stm32f10x.h file)"#endif所以前面定义了STM32F10X_HD 当然除啦在工具链里设置,也可以直接修改这个文件,如下 /* Uncomment the line below according to the target STM32 device used in your application */#if !defined (STM32F10X_LD) && !defined (STM32F10X_LD_VL) && !defined (STM32F10X_MD) && !defined (STM32F10X_MD_VL) && !defined (STM32F10X_HD) && !defined (STM32F10X_HD_VL) && !defined (STM32F10X_XL) && !defined (STM32F10X_CL) /* #define STM32F10X_LD */ /*!< STM32F10X_LD: STM32 Low density devices */ /* #define STM32F10X_LD_VL */ /*!< STM32F10X_LD_VL: STM32 Low density Value Line devices */ /* #define STM32F10X_MD */ /*!< STM32F10X_MD: STM32 Medium density devices */ /* #define STM32F10X_MD_VL */ /*!< STM32F10X_MD_VL: STM32 Medium density Value Line devices */ /* #define STM32F10X_HD */ /*!< STM32F10X_HD: STM32 High density devices */ /* #define STM32F10X_HD_VL */ /*!< STM32F10X_HD_VL: STM32 High density value line devices */ /* #define STM32F10X_XL */ /*!< STM32F10X_XL: STM32 XL-density devices */ /* #define STM32F10X_CL */ /*!< STM32F10X_CL: STM32 Connectivity line devices */#endif把相应的取消注释即可 通过宏定义选择是否适用外设驱动库文件 #if !defined USE_STDPERIPH_DRIVER/** * @brief Comment the line below if you will not use the peripherals drivers. In this case, these drivers will not be included and the application code will be based on direct access to peripherals registers */ /*#define USE_STDPERIPH_DRIVER*/#endif通过宏定义选择正确的外部晶振频率,注意这并不是可以随便改的,连的是8M就要选择相应的,stm32f10x外接晶振的频率范围应该是4-16mhz #if !defined HSE_VALUE #ifdef STM32F10X_CL #define HSE_VALUE ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */ #else #define HSE_VALUE ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */ #endif /* STM32F10X_CL */#endif /* HSE_VALUE */ 通过宏定义设置晶振启动等待时间 /** * @brief In the following line adjust the External High Speed oscillator (HSE) Startup Timeout value */#define HSE_STARTUP_TIMEOUT ((uint16_t)0x0500) /*!< Time out for HSE start up */#define HSI_VALUE ((uint32_t)8000000) /*!< Value of the Internal oscillator in Hz*/晶振起振后到输出稳定信号之间的等待时间就是在这里设置 后面是各个型号中断号的定义、库函数用到的结构体的定义,寄存器地址的定义,位定义 最后,如果定义了USE_STDPERIPH_DRIVER #ifdef USE_STDPERIPH_DRIVER #include "stm32f10x_conf.h"#endif需要include上述头文件 stm32f10_conf.h:将所有库函数的头文件include进来,以及定义了个检查参数的宏定义 stm32f10x_it.c:这是一个中断处理文件,_it结尾,就是interrupt(中断)的意思,说明这个是整个工程的中断处理函数,要是没有用到中断的话就可以不添加进去,还有,也可以去掉,将中断函数添加到其它.c文件里也行 StartUp文件夹里的其余文件: core_cm3.h:这个文件写了stm32内核相关的寄存器定义(stm32f10x.h中也没有的)及内核级的函数声明,这里顺便补充下一些基本的概念:单片机个人理解是将本来计算机的基本组成部分进行简化然后全都集成在一块芯片上,众所周知,计算机分为五个部分:运算器,存储器,控制器,输入设备,输出设备,如果单片机IO口看作输入输出设备,那么单片机就具备了这五个部分,而运算器和控制器的架构应该就是常说的内核,类似于电脑中的cpu,结构如下 顺便提一下cortex m3的存储(https://blog.csdn.net/bulebin/article/details/74093147): 我看了下stm32使用cortex m3的内核,所以存储的安排也是符合上表的。 core_cm3.c:这个文件提供了一些汇编级函数实现,例如提供了中断屏蔽的汇编实现,若没使用这些函数删除它不会影响编译,但例如你要做软复位函数时,你就会使用中断屏蔽在那个时候你删除它就会编译失败。 最后就是system_stm32f10x.h和.c文件的了解了,.h就是.c的函数声明,没啥好说的,重点讲讲system_stm32f10x.c: |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1658 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1571 浏览 1 评论
998 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
695 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1617 浏览 2 评论
1876浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
662浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
528浏览 3评论
547浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
517浏览 3评论
GMT+8, 2024-11-29 06:53 , Processed in 0.626765 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
