参照 JEDEC eMMC标准:JESD84-B51 (Revision of JESD84-B50.1, July 2014) 驱动芯片采用stm32h7xx芯片。通过官方HAL库中stm32h7xx_hal_mmc.h文件驱动,采用8bit数据传输模式,与SD卡驱动类似。实测写入速度6-10MB/s左右。 初始化代码清单: HAL_StatusTypeDef SDMMC1_MMC_Init(void) { hmmc1.Instance = SDMMC1; hmmc1.Init.ClockEdge = SDMMC_CLOCK_EDGE_RISING; hmmc1.Init.ClockPowerSave = SDMMC_CLOCK_POWER_SAVE_DISABLE; hmmc1.Init.BusWide = SDMMC_BUS_WIDE_8B; hmmc1.Init.HardwareFlowControl = SDMMC_HARDWARE_FLOW_CONTROL_DISABLE; hmmc1.Init.ClockDiv = 1; if (HAL_MMC_Init(&hmmc1) != HAL_OK) { Error_Handler(); } return HAL_OK; } 底层驱动代码清单: void HAL_MMC_MspInit(MMC_HandleTypeDef* hmmc) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(hmmc->Instance==SDMMC1) { /* USER CODE BEGIN SDMMC1_MspInit 0 */ /* Peripheral clock enable */ __HAL_RCC_SDMMC1_CLK_ENABLE(); __HAL_RCC_GPIOC_CLK_ENABLE(); __HAL_RCC_GPIOD_CLK_ENABLE(); /**SDMMC1 GPIO Configuration PC8 ------> SDMMC1_D0 PC9 ------> SDMMC1_D1 PC10 ------> SDMMC1_D2 PC11 ------> SDMMC1_D3 PB8 ------> SDMMC1_D4 PB9 ------> SDMMC1_D5 PC6 ------> SDMMC1_D6 PC7 ------> SDMMC1_D7 PC12 ------> SDMMC1_CK PD2 ------> SDMMC1_CMD */ GPIO_InitStruct.Pin = GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_8 |GPIO_PIN_9|GPIO_PIN_6|GPIO_PIN_7; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF12_SDIO1; HAL_GPIO_Init(GPIOC, &GPIO_InitStruct); GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF12_SDIO1; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); GPIO_InitStruct.Pin = GPIO_PIN_2; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF12_SDIO1; HAL_GPIO_Init(GPIOD, &GPIO_InitStruct); HAL_NVIC_SetPriority(SDMMC1_IRQn,1,1); //配置SDMMC1中断 HAL_NVIC_EnableIRQ(SDMMC1_IRQn); //使能SDMMC1中断 HAL_NVIC_SetPriority(SysTick_IRQn, 0x0E ,0); } } 在DMA模式下,从MMC卡的指定地址读取数据: /** * @brief 在DMA模式下,从MMC卡的指定地址读取数据 * @param pData:指向将包含要传输的数据的缓冲区的指针 * @param ReadAddr:要读取数据的地址 * @param NumOfBlocks:要读取的MMC块数量 * @retval eMMC状态 */ uint8_t BSP_MMC_ReadBlocks_DMA(uint8_t *pData, uint32_t ReadAddr, uint32_t NumOfBlocks) { HAL_StatusTypeDef Status = HAL_OK; if(HAL_MMC_ReadBlocks_DMA(&hmmc1, pData, ReadAddr, NumOfBlocks) != HAL_OK) { Status = HAL_ERROR; } return Status; } 在DMA模式下,向MMC卡的指定地址写入数据: /** * @brief 在DMA模式下,向MMC卡的指定地址写入数据 * @param pData:指向将包含要传输的数据的缓冲区的指针 * @param WriteAddr:要写入数据的地址 * @param NumOfBlocks:要写的MMC块的数量 * @retval MMC状态 */ uint8_t BSP_MMC_WriteBlocks_DMA(uint8_t *pData, uint32_t WriteAddr, uint32_t NumOfBlocks) { HAL_StatusTypeDef Status = HAL_OK; /* Write block(s) in DMA transfer mode */ if (HAL_MMC_WriteBlocks_DMA(&hmmc1, pData, WriteAddr, NumOfBlocks) != HAL_OK) { Status = HAL_ERROR; } return Status; } 擦除eMMC卡数据: /** * @brief 擦除eMMC卡数据 * @param 无 * @retval 无 */ void MMC_EraseTest(void) { HAL_StatusTypeDef Status = HAL_OK; HAL_StatusTypeDef EraseStatus = HAL_OK; if (Status == HAL_OK) { Status = HAL_MMC_Erase(&hmmc1, 0x00, (BLOCK_SIZE * NUMBER_OF_BLOCKS)); //等待擦除完成 if(Wait_SDCARD_Ready() != HAL_OK) { EraseStatus = HAL_ERROR; } } if(EraseStatus != HAL_OK) { Error_Handler(); } } eMMC卡等待擦除完成函数: /** * @brief eMMC卡等待擦除完成函数 * @param 无 * @retval HAL_OK:擦除成功;HAL_ERROR:擦除失败 */ static HAL_StatusTypeDef Wait_SDCARD_Ready(void) { uint32_t loop = MMC_TIMEOUT; /* Wait for the Erasing process is completed */ /* Verify that SD card is ready to use after the Erase */ while(loop > 0) { loop--; if(HAL_MMC_GetCardState(&hmmc1) == HAL_MMC_CARD_TRANSFER) { return HAL_OK; } } return HAL_ERROR; } 最近移植的eMMC卡的驱动程序,分享出来希望对各位开发者有所帮助。还移植了FATFS文件系统到eMMC驱动程序中,之后整理好再分享。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1481 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1456 浏览 1 评论
864 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
621 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1486 浏览 2 评论
1813浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
559浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
479浏览 3评论
469浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
451浏览 3评论
GMT+8, 2024-10-22 02:42 , Processed in 0.722327 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
