1个回答
0. 准备工作与说明
0.1 准备工作 请先下载以下文件,里面有文档: 参考GIT中的文档,安装好虚拟机,从GIT总下载Liteos-a源码,打上IMX6ULL的补丁。 0.2 说明 1. Makefile编译系统分析 1.1 变量 1. LITEOSTOPDIR // kernel/liteos_a 2. LITEOSTHIRDPARTY // third_party 3. LITEOS_MK_PATH // kernel/liteos_a/tools/build/mk 4. MK_PATH = $(LITEOSTOPDIR)/tools/build/mk // kernel/liteos_a/tools/build/mk 1.2 包含的文件 Makefile -include $(LITEOSTOPDIR)/tools/build/config.mk -include $(LITEOSTOPDIR)/tools/build/mk/los_config.mk -include $(LITEOSTOPDIR)/.config include $(LITEOSTOPDIR)/arch/cpu.mk -include $(LITEOSTOPDIR)/arch/arm/arm.mk include $(LITEOSTOPDIR)/platform/bsp.mk include $(LITEOSTOPDIR)/../../vendor/nxp/imx6ull/imx6ull.mk include $(LITEOSTOPDIR)/../../drivers/hdf/lite/hdf_lite.mk include $(LITEOSTOPDIR)/../../vendor/nxp/hdf/hdf_vendor.mk -include $(LITEOSTOPDIR)/3rdParty/3rdParty.mk -include $(LITEOS_MK_PATH)/liteos_tables_ldflags.mk -include $(LITEOS_MK_PATH)/dynload.mk 1.3 把Makefile全部展开 得到了一个Makefile_all.txt, 分析Makefile_all.txt,就可以知道编译过程。 1.4 分析在kernel/liteos_a下执行make的过程 1.4.1 第1个目标 all: $(OUT) $(BUILD) $(LITEOS_TARGET) $(APPS) 1.4.2 目标:OUT OUT目标: # .config文件中, LOSCFG_PLATFOR OUT = $(LITEOSTOPDIR)/out/$(LITEOS_PLATFORM) $(OUT): $(LITEOS_MENUCONFIG_H) $(HIDE)mkdir -p $(OUT)/lib $(HIDE)$(CC) -I$(LITEOS_PLATFORM_BASE)/include -I$(BOARD_INCLUDE_DIR) -E $(LITEOS_PLATFORM_BASE)/board.ld.S -o $(LITEOS_PLATFORM_BASE)/board.ld -POUT的依赖:LITEOS_MENUCONFIG_H LITEOS_MENUCONFIG_H = $(LITEOSTOPDIR)/include/generated/autoconf.h KCONFIG_FILE_PATH = $(LITEOSTOPDIR)/Kconfig $(LITEOS_MENUCONFIG_H): ifneq ($(LITEOS_PLATFORM_MENUCONFIG_H), $(wildcard $(LITEOS_PLATFORM_MENUCONFIG_H))) $(HIDE)$(MAKE) genconfig endif genconfig:$(MENUCONFIG_PATH)/conf $(HIDE)mkdir -p include/config include/generated $< --silentoldconfig $(KCONFIG_FILE_PATH) -mv -f $(LITEOS_MENUCONFIG_H) $(LITEOS_PLATFORM_MENUCONFIG_H) 1.4.3 目标:BUILD 创建目录 kernel/liteos_a/imx6ull/obj OUT = $(LITEOSTOPDIR)/out/$(LITEOS_PLATFORM) BUILD = $(OUT)/obj $(BUILD): $(HIDE)mkdir -p $(BUILD) 1.4.4 目标:LITEOS_TARGET LITEOS_TARGET = liteos $(LITEOS_TARGET): $(__LIBS) $(HIDE)touch $(LOSCFG_ENTRY_SRC) $(HIDE)for dir in $(LITEOS_SUBDIRS); do $(MAKE) -C $$dir all || exit 1; done $(LD) $(LITEOS_LDFLAGS) $(LITEOS_TABLES_LDFLAGS) $(LITEOS_DYNLDFLAGS) -Map=$(OUT)/$@.map -o $(OUT)/$@ --start-group $(LITEOS_LIBDEP) --end-group # $(SIZE) -t --common $(OUT)/lib/*.a >$(OUT)/$@.objsize $(OBJCOPY) -O binary $(OUT)/$@ $(LITEOS_TARGET_DIR)/$@.bin $(OBJDUMP) -t $(OUT)/$@ |sort >$(OUT)/$@.sym.sorted $(OBJDUMP) -d $(OUT)/$@ >$(OUT)/$@.asm # $(NM) -S --size-sort $(OUT)/$@ >$(OUT)/$@.size 目标:__LIBS # 没做什么事 __LIBS = libs $(__LIBS): $(OUT) $(CXX_INCLUDE)命令:$(HIDE)touch $(LOSCFG_ENTRY_SRC) 每次都要编译los_config.c,touch一下 LOSCFG_ENTRY_SRC = $(LITEOSTOPDIR)/kernel/common/los_config.c命令:进入每个LITEOS_SUBDIRS,执行make,后面重点讲解各个子目录的编译 # LIB_SUBDIRS 等于一系列的目录 LIB_SUBDIRS := LIB_SUBDIRS += arch/arm/$(LITEOS_ARCH_ARM) # 就是arch/arm/arm LIB_SUBDIRS += $(PLATFORM_BSP_HISI_BASE) LIB_SUBDIRS += $(LITEOSTOPDIR)/kernel/common LIB_SUBDIRS += kernel/base LIB_SUBDIRS += $(IMX6ULL_BASE_DIR)/board LIB_SUBDIRS += $(IMX6ULL_BASE_DIR)/driver/mtd/common LIB_SUBDIRS += $(IMX6ULL_BASE_DIR)/driver/mtd/spi_nor LIB_SUBDIRS += $(IMX6ULL_BASE_DIR)/driver/imx6ull-fb LIB_SUBDIRS += $(IMX6ULL_BASE_DIR)/driver/imx6ull-uart LIB_SUBDIRS += kernel/extended/cpup LIB_SUBDIRS += lib/libc LIB_SUBDIRS += lib/libsec LIB_SUBDIRS += lib/libscrew LIB_SUBDIRS += fs/fat LIB_SUBDIRS += fs/jffs2 LITEOS_SUBDIRS = $(LIB_SUBDIRS) $(HIDE)for dir in $(LITEOS_SUBDIRS); do $(MAKE) -C $$dir all || exit 1; done链接及各类处理 $(LD) $(LITEOS_LDFLAGS) $(LITEOS_TABLES_LDFLAGS) $(LITEOS_DYNLDFLAGS) -Map=$(OUT)/$@.map -o $(OUT)/$@ --start-group $(LITEOS_LIBDEP) --end-group # $(SIZE) -t --common $(OUT)/lib/*.a >$(OUT)/$@.objsize $(OBJCOPY) -O binary $(OUT)/$@ $(LITEOS_TARGET_DIR)/$@.bin $(OBJDUMP) -t $(OUT)/$@ |sort >$(OUT)/$@.sym.sorted $(OBJDUMP) -d $(OUT)/$@ >$(OUT)/$@.asm # $(NM) -S --size-sort $(OUT)/$@ >$(OUT)/$@.size 1.4.5 怎么编译各个子目录 第1行包含config.mk 这是包含一些预先定义的变量,比如默认的编译选项等。定义了LOCAL_SRCS 等于一系列C文件,这就是要编译的源文件。定义了LOCAL_INCLUDE 这是头文件的目录定义了LOCAL_FLAGS 这是编译选项定义了MODULE_NAME 一般等于当前目录的名字,比如fat,以后就编译得到libfat.a怎么编译?看最后一行 include $(MODULE) MODULE就是: MODULE = $(MK_PATH)/module.mk # kernel/liteos_a/tools/build/mk/module.mk 分析module.mk: # 找到第1个目标 all : $(LIB) # LIB是什么, 如果没定义LOCAL_SO,LIB就是 lib$(MODULE_NAME).a, 比如 libfat.a ifeq ($(LOCAL_SO), y) LIBSO := $(OUT)/lib/lib$(MODULE_NAME).so LIBA := $(OUT)/lib/lib$(MODULE_NAME).a else LIBSO := LIBA := $(OUT)/lib/lib$(MODULE_NAME).a endif LIB := $(LIBA) $(LIBSO) # 怎么编译 LIBA ? 看下图 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1800 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1629 浏览 1 评论
1096 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
735 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1684 浏览 2 评论
1944浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
744浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
578浏览 3评论
601浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
564浏览 3评论
GMT+8, 2024-12-27 01:30 , Processed in 0.959826 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
