UART是单片机的一种重要的通信接口,通信参数涉及到波特率、数据长度、奇偶校验、停止位。
工业上往往有要求在线修改(无需重启单片机)串口通信参数的要求,同时对奇偶校验也有要求,除无校验、奇校验、偶校验外,还有MARK校验和SPACE校验: void bsp_SetUartBaud(COM_PORT_E _ucPort,uint32_t _baud,uint16_t _wordLen, uint16_t _parity, uint16_t _stopBits) { USART_InitTypeDef USART_InitStructure; USART_InitStructure.USART_BaudRate = _baud; if (_parity==0) { USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_Parity = USART_Parity_No ; } else if (_parity==1) { if (_wordLen==7) { USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_Parity = USART_Parity_Odd ; } else { USART_InitStructure.USART_WordLength = USART_WordLength_9b; USART_InitStructure.USART_Parity = USART_Parity_Odd ; } } else if (_parity==2) { if (_wordLen==7) { USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_Parity = USART_Parity_Even ; } else { USART_InitStructure.USART_WordLength = USART_WordLength_9b; USART_InitStructure.USART_Parity = USART_Parity_Even ; } } else if (_parity==3)//Mark校验 { USART_InitStructure.USART_WordLength = USART_WordLength_9b; USART_InitStructure.USART_Parity = USART_Parity_No ; } else if (_parity==4)//Space校验 { USART_InitStructure.USART_WordLength = USART_WordLength_9b; USART_InitStructure.USART_Parity = USART_Parity_No ; } if (_stopBits==1) USART_InitStructure.USART_StopBits = USART_StopBits_1; else USART_InitStructure.USART_StopBits = USART_StopBits_2; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; switch (_ucPort) { case COM1:USART_Init(USART1, &USART_InitStructure);break; case COM2:USART_Init(USART2, &USART_InitStructure);break; case COM3:USART_Init(USART3, &USART_InitStructure);break; case COM4:USART_Init(UART4, &USART_InitStructure);break; case COM5:USART_Init(UART5, &USART_InitStructure);break; default:USART_Init(USART1, &USART_InitStructure);break; } } void COM_SendString(COM_PORT_E _ucPort, uint8_t* Data,u16 Len,uint16_t Parity) { uint16_t i=0; USART_TypeDef *pUart; pUart = ComToUart(_ucPort); if (pUart == 0) { return; } USART_ClearFlag(pUart,USART_FLAG_TC); for(i=0;i switch (Parity) { case 3:USART_SendData(pUart, 0x100 | *Data);break;//MARK校验 case 4:USART_SendData(pUart, 0xFF & *Data);break;//SPACE校验 default:USART_SendData(pUart, *Data);break; } while( USART_GetFlagStatus(pUart, USART_FLAG_TC) == RESET ); Data++; } } 另外,串口在接收数据时,数据的长度是不固定的,这种情况下就要使用IDLE中断。 IDLE中断是在串口接收完一串完整数据后,电平归0一段时间(不同波特率下这段时间会有区别)产生的中断,IDLE中断的产生代表数据传输过程完毕: static void InitHardUart(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; #if UART1_FIFO_EN == 1 /* 串口1 TX = PA9 RX = PA10 或 TX = PB6 RX = PB7*/ /* 第1步:打开GPIO和USART部件的时钟 */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); /* 第2步:将USART Tx的GPIO配置为推挽复用模式 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOA, &GPIO_InitStructure); /* 第3步:将USART Rx的GPIO配置为浮空输入模式 由于CPU复位后,GPIO缺省都是浮空输入模式,因此下面这个步骤不是必须的 但是,我还是建议加上便于阅读,并且防止其它地方修改了这个口线的设置参数 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /* 第4步: 配置串口硬件参数 */ USART_InitStructure.USART_BaudRate = UART1_BAUD; /* 波特率 */ USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No ; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1, &USART_InitStructure); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); /* 使能接收中断 */ USART_ITConfig(USART1, USART_IT_IDLE, ENABLE); /* 使能IDLE中断 */ /* USART_ITConfig(USART1, USART_IT_TXE, ENABLE); 注意: 不要在此处打开发送中断 发送中断使能在SendUart()函数打开 */ USART_Cmd(USART1, ENABLE); /* 使能串口 */ /* CPU的小缺陷:串口配置好,如果直接Send,则第1个字节发送不出去 如下语句解决第1个字节无法正确发送出去的问题 */ // USART_ClearFlag(USART1, USART_FLAG_TC); /* 清发送完成标志,Transmission Complete flag */ #endif } void USART1_IRQHandler(void) { uint8_t clear; if(USART_GetITStatus(USART1,USART_IT_RXNE) != RESET) { USART_ClearITPendingBit(USART1,USART_IT_RXNE); if (RxCount1 >=UART1_RX_BUF_SIZE) RxCount1=0; g_RxBuf1[RxCount1] = USART_ReceiveData(USART1); RxCount1++; } if (USART_GetITStatus(USART1,USART_IT_IDLE) != RESET) { clear=USART1->SR; clear=USART1->DR; RecvFinished1=1; } if(USART_GetFlagStatus(USART1,USART_FLAG_ORE) == SET) { USART_ClearFlag(USART1,USART_FLAG_ORE); USART_ReceiveData(USART1); } } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1763 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1617 浏览 1 评论
1059 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
723 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1670 浏览 2 评论
1935浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
726浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
567浏览 3评论
592浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
551浏览 3评论
GMT+8, 2024-12-21 17:33 , Processed in 0.555008 second(s), Total 72, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
