电子发烧友论坛|
硬件平台:STM32F103(自带5个串口)
5个串口同时工作不丢包-_- 相关宏定义 typedef enum { UartPort1, UartPort2, UartPort3, UartPort4, UartPort5, UartPort_USB, }UARTPORT; #define RXTIMEOUT 10 // 接收超时时间,如10mSec内未接收任何数据,当作一个接收包 #define UART_TXBUFFERLEN 0x100 //发送缓冲区大小 #define UART_RXBUFFERLEN 0x400 //接接缓冲区大小 typedef struct { //接收 volatile Uint rxHead; volatile Uint rxTail; volatile Uchar rxBuf[UART_RXBUFFERLEN]; volatile Uchar rxTimeOut_Base; volatile Uchar rxTimeOut; //发送 volatile Uint txHead; volatile Uint txTail; volatile BOOLEAN txEmpty; volatile Uchar baudrate; volatile Uchar txIdleTimeOut; volatile Uchar txIdleTimeOut_Base; volatile Uchar txBuf[UART_TXBUFFERLEN]; }UART_STRUCT; static UART_STRUCT uart1; static UART_STRUCT uart2; static UART_STRUCT uart3; static UART_STRUCT uart4; static UART_STRUCT uart5; 串口1初始化 USART_InitTypeDef USART_InitStruct; GPIO_InitTypeDef GPIO_InitStruct; NVIC_InitTypeDef NVIC_InitStruct; RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1, ENABLE ); GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; /* Configure USART1 Tx (PA9) as alternate function push-pull */ GPIO_InitStruct.GPIO_Pin = PIN_USART1_TXD; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init( PORT_USART1_TXD, &GPIO_InitStruct ); /* Configure USART1 Rx (PA10) as input floating */ GPIO_InitStruct.GPIO_Pin = PIN_USART1_RXD; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init( PORT_USART1_RXD, &GPIO_InitStruct ); USART_StructInit(&USART_InitStruct); USART_InitStruct.USART_BaudRate = 115200; USART_InitStruct.USART_WordLength = USART_WordLength_8b; USART_InitStruct.USART_StopBits = USART_StopBits_1; USART_InitStruct.USART_Parity = USART_Parity_No ; USART_InitStruct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_Init(USART1, &USART_InitStruct); /* Enable the USARTx Interrupt */ #if 1 // USART_ITConfig(USART2, USART_IT_TXE, ENABLE); USART_ITConfig(USART1, USART_IT_RXNE, ENABLE); NVIC_InitStruct.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0; NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStruct); #endif USART_Cmd(USART1, ENABLE); 串口2初始化 USART_InitTypeDef USART_InitStruct; GPIO_InitTypeDef GPIO_InitStruct; NVIC_InitTypeDef NVIC_InitStruct; RCC_APB1PeriphClockCmd( RCC_APB1Periph_USART2, ENABLE ); GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; /* Configure USART2 CTS (PA0) as input floating */ #if UART2_HARDWARE_FLOW GPIO_InitStruct.GPIO_Pin = PIN_USART2_CTS; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init( PORT_USART2_CTS, &GPIO_InitStruct ); #endif /* Configure USART2 Rx (PA3) as input floating */ GPIO_InitStruct.GPIO_Pin = PIN_USART2_RXD; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init( PORT_USART2_RXD, &GPIO_InitStruct ); /* Configure USART2 RTS (PA1) as alternate function push-pull */ #if UART2_HARDWARE_FLOW GPIO_InitStruct.GPIO_Pin = PIN_USART2_RTS; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init( PORT_USART2_RTS, &GPIO_InitStruct ); #endif /* Configure USART2 Tx (PA2) as alternate function push-pull */ GPIO_InitStruct.GPIO_Pin = PIN_USART2_TXD; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init( PORT_USART2_TXD, &GPIO_InitStruct ); USART_StructInit(&USART_InitStruct); USART_InitStruct.USART_BaudRate = 115200; USART_InitStruct.USART_WordLength = USART_WordLength_8b; USART_InitStruct.USART_StopBits = USART_StopBits_1; USART_InitStruct.USART_Parity = USART_Parity_No ; USART_InitStruct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; #if UART2_HARDWARE_FLOW USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_RTS; #else USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None; #endif USART_Init(USART2, &USART_InitStruct); #if 1 // USART_ITConfig(USART2, USART_IT_TXE, ENABLE); USART_ITConfig(USART2, USART_IT_RXNE, ENABLE); NVIC_InitStruct.NVIC_IRQChannel = USART2_IRQn; NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0; NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStruct); #endif USART_Cmd(USART2, ENABLE); 串口3初始化 USART_InitTypeDef USART_InitStruct; GPIO_InitTypeDef GPIO_InitStruct; NVIC_InitTypeDef NVIC_InitStruct; RCC_APB1PeriphClockCmd( RCC_APB1Periph_USART3, ENABLE ); GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; /* Configure USART1 Tx (PC10) as alternate function push-pull */ GPIO_InitStruct.GPIO_Pin = PIN_UART3_TXD; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init( PORT_UART3_TXD, &GPIO_InitStruct ); /* Configure USART1 Rx (PC11) as input floating */ GPIO_InitStruct.GPIO_Pin = PIN_UART3_RXD; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init( PORT_UART3_RXD, &GPIO_InitStruct ); USART_StructInit(&USART_InitStruct); USART_InitStruct.USART_BaudRate = 115200; USART_InitStruct.USART_WordLength = USART_WordLength_8b; USART_InitStruct.USART_StopBits = USART_StopBits_1; USART_InitStruct.USART_Parity = USART_Parity_No ; USART_InitStruct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_Init(USART3, &USART_InitStruct); /* Enable the USARTx Interrupt */ #if 1 USART_ITConfig(USART3, USART_IT_RXNE, ENABLE); NVIC_InitStruct.NVIC_IRQChannel = USART3_IRQn; NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0; NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStruct); #endif USART_Cmd(USART3, ENABLE); 串口4初始化 USART_InitTypeDef USART_InitStruct; GPIO_InitTypeDef GPIO_InitStruct; NVIC_InitTypeDef NVIC_InitStruct; RCC_APB1PeriphClockCmd( RCC_APB1Periph_UART4, ENABLE ); GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; #if 0 GPIO_InitStruct.GPIO_Pin = PIN_UART4_CTS; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init( PORT_UART4_CTS, &GPIO_InitStruct ); // GPIO_ResetBits(PORT_UART4_CTS,PIN_UART4_CTS); #endif /* Configure USART1 Tx (PC10) as alternate function push-pull */ GPIO_InitStruct.GPIO_Pin = PIN_UART4_TXD; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init( PORT_UART4_TXD, &GPIO_InitStruct ); /* Configure USART1 Rx (PC11) as input floating */ GPIO_InitStruct.GPIO_Pin = PIN_UART4_RXD; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init( PORT_UART4_RXD, &GPIO_InitStruct ); USART_StructInit(&USART_InitStruct); USART_InitStruct.USART_BaudRate = 115200; USART_InitStruct.USART_WordLength = USART_WordLength_8b; USART_InitStruct.USART_StopBits = USART_StopBits_1; USART_InitStruct.USART_Parity = USART_Parity_No ; USART_InitStruct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_Init(UART4, &USART_InitStruct); /* Enable the USARTx Interrupt */ #if 1 // USART_ITConfig(USART2, USART_IT_TXE, ENABLE); USART_ITConfig(UART4, USART_IT_RXNE, ENABLE); NVIC_InitStruct.NVIC_IRQChannel = UART4_IRQn; NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0; NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStruct); #endif USART_Cmd(UART4, ENABLE); 串口5初始化 USART_InitTypeDef USART_InitStruct; GPIO_InitTypeDef GPIO_InitStruct; NVIC_InitTypeDef NVIC_InitStruct; RCC_APB1PeriphClockCmd( RCC_APB1Periph_UART5, ENABLE ); GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; /* Configure USART1 Tx (PC10) as alternate function push-pull */ GPIO_InitStruct.GPIO_Pin = PIN_UART5_TXD; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init( PORT_UART5_TXD, &GPIO_InitStruct ); /* Configure USART1 Rx (PC11) as input floating */ GPIO_InitStruct.GPIO_Pin = PIN_UART5_RXD; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init( PORT_UART5_RXD, &GPIO_InitStruct ); USART_StructInit(&USART_InitStruct); USART_InitStruct.USART_BaudRate = 115200; USART_InitStruct.USART_WordLength = USART_WordLength_8b; USART_InitStruct.USART_StopBits = USART_StopBits_1; USART_InitStruct.USART_Parity = USART_Parity_No ; USART_InitStruct.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_Init(UART5, &USART_InitStruct); /* Enable the USARTx Interrupt */ #if 1 USART_ITConfig(UART5, USART_IT_RXNE, ENABLE); NVIC_InitStruct.NVIC_IRQChannel = UART5_IRQn; NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0; NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStruct); #endif USART_Cmd(UART5, ENABLE); |
中断处理
void USART_Irq_Function(UART_STRUCT *uart,USART_TypeDef *uartdef) { //接收到数据USART_ GetITStatus while (USART_GetITStatus(uartdef, USART_IT_RXNE)) { Uchar temp; USART_ClearFlag(uartdef, USART_FLAG_RXNE | USART_FLAG_ORE); temp = USART_ReceiveData(uartdef); if (((uart->rxHead + 1) % UART_RXBUFFERLEN) != uart->rxTail) { uart->rxBuf[uart->rxHead] = temp; uart->rxHead = (uart->rxHead + 1) % UART_RXBUFFERLEN; uart->rxTimeOut = uart->rxTimeOut_Base; } } //发送数据 if (USART_GetITStatus(uartdef,USART_IT_TXE)) { // USART_ClearFlag(uartdef, USART_FLAG_TXE); if (uart->txHead == uart->txTail) { uart->txEmpty = TRUE; USART_ITConfig(uartdef, USART_IT_TXE, DISABLE); } else { USART_SendData(uartdef, uart->txBuf[uart->txTail]); uart->txTail = (uart->txTail + 1) & (UART_TXBUFFERLEN - 1); uart->txIdleTimeOut = uart->txIdleTimeOut_Base; } } } extern void USART1_IRQHandler(void) { USART_Irq_Function(&uart1,USART1); } extern void USART2_IRQHandler(void) { USART_Irq_Function(&uart2,USART2); } extern void USART3_IRQHandler(void) { #ifdef INCLUDE_UARTPORT3 USART_Irq_Function(&uart3,USART3); #endif } extern void UART4_IRQHandler(void) { #ifdef INCLUDE_UARTPORT4 USART_Irq_Function(&uart4,UART4); #endif } extern void UART5_IRQHandler(void) { #ifdef INCLUDE_UARTPORT5 USART_Irq_Function(&uart5,UART5); #endif } 超时检查 //函 数:检查是否有收到数据包,1ms调用一次 //参 数无 //返 回:无 extern void checkUartRxTimeOut() { if (uart1.rxTimeOut) { if (--uart1.rxTimeOut == 0) { pushEvent(evCOM1,uart1.rxHead); } } if (uart2.rxTimeOut) { if (--uart2.rxTimeOut == 0) { pushEvent(evCOM2,uart2.rxHead); } } if (uart3.rxTimeOut) { if (--uart3.rxTimeOut == 0) { pushEvent(evCOM3,uart3.rxHead); } } if (uart4.rxTimeOut) { if (--uart4.rxTimeOut == 0) { pushEvent(evCOM4,uart4.rxHead); } } if (uart5.rxTimeOut) { if (--uart5.rxTimeOut == 0) { pushEvent(evCOM5,uart5.rxHead); } } if (uart1.txIdleTimeOut) uart1.txIdleTimeOut--; if (uart2.txIdleTimeOut) uart2.txIdleTimeOut--; #ifdef INCLUDE_UARTPORT3 if (uart3.txIdleTimeOut) uart3.txIdleTimeOut--; #endif #ifdef INCLUDE_UARTPORT4 if (uart4.txIdleTimeOut) uart4.txIdleTimeOut--; #endif #ifdef INCLUDE_UARTPORT5 if (uart5.txIdleTimeOut) uart5.txIdleTimeOut--; #endif } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4140 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2753 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14984 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3087浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1896浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2066浏览 3评论
1979浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2168浏览 3评论
/9
GMT+8, 2025-12-2 13:34 , Processed in 0.674327 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5889
