电子发烧友论坛|
使用stm32 cubeMX配置生成工程
发送数据的时候可以发送第一包数据,进入的数据直接跳过了,过了,了,,, 仿真的时候没有任何问题,可以所有数据 上图 分析: 封装stxm2F4中文参考手册 使能这种模式(将DMA_SCR3寄存器中的EN位置1)时,数据流会立即启动传输,从源完全填充FIFO 如果DMA_SxNDTR寄存器获取零、外设请求传输终止(在使用设备外设请求传输终止)流控制器的情况下)或DMA_SxCR寄存器中的EN位由软件清零,传输即会停止。 结合代码: //使能DMA数据流立即启动传输 #define __HAL_DMA_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= DMA_SxCR_EN) //传输终止 #define __HAL_DMA_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~DMA_SxCR_EN) HAL_StatusTypeDef HAL_UART_Transmit_DMA(UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size) { uint32_t *tmp; /* Check that a Tx process is not already ongoing */ if(huart->gState == HAL_UART_STATE_READY) { if((pData == NULL ) || (Size == 0)) { return HAL_ERROR; } /* Process Locked */ __HAL_LOCK(huart); huart->pTxBuffPtr = pData; huart->TxXferSize = Size; huart->TxXferCount = Size; huart->ErrorCode = HAL_UART_ERROR_NONE; huart->gState = HAL_UART_STATE_BUSY_TX; /* Set the UART DMA transfer complete callback */ huart->hdmatx->XferCpltCallback = UART_DMATransmitCplt; /* Set the UART DMA Half transfer complete callback */ huart->hdmatx->XferHalfCpltCallback = UART_DMATxHalfCplt; /* Set the DMA error callback */ huart->hdmatx->XferErrorCallback = UART_DMAError; /* Set the DMA abort callback */ huart->hdmatx->XferAbortCallback = NULL; /* Enable the UART transmit DMA Stream */ tmp = (uint32_t*)&pData; HAL_DMA_Start_IT(huart->hdmatx, *(uint32_t*)tmp, (uint32_t)&huart->Instance->DR, Size); /* Clear the TC flag in the SR register by writing 0 to it */ __HAL_UART_CLEAR_FLAG(huart, UART_FLAG_TC); /* Process Unlocked */ __HAL_UNLOCK(huart); /* Enable the DMA transfer for transmit request by setting the DMAT bit in the UART CR3 register */ SET_BIT(huart->Instance->CR3, USART_CR3_DMAT); return HAL_OK; } else { return HAL_BUSY; } } HAL_StatusTypeDef HAL_DMA_Start_IT(DMA_HandleTypeDef *hdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t DataLength) { HAL_StatusTypeDef status = HAL_OK; /* calculate DMA base and stream number */ DMA_Base_Registers *regs = (DMA_Base_Registers *)hdma->StreamBaseAddress; /* Check the parameters */ assert_param(IS_DMA_BUFFER_SIZE(DataLength)); /* Process locked */ __HAL_LOCK(hdma); if(HAL_DMA_STATE_READY == hdma->State) { /* Change DMA peripheral state */ hdma->State = HAL_DMA_STATE_BUSY; /* Initialize the error code */ hdma->ErrorCode = HAL_DMA_ERROR_NONE; /* Configure the source, destination address and the data length */ DMA_SetConfig(hdma, SrcAddress, DstAddress, DataLength); /* Clear all interrupt flags at correct offset within the register */ regs->IFCR = 0x3FU << hdma->StreamIndex; /* Enable Common interrupts*/ hdma->Instance->CR |= DMA_IT_TC | DMA_IT_TE | DMA_IT_DME; hdma->Instance->FCR |= DMA_IT_FE; if(hdma->XferHalfCpltCallback != NULL) { hdma->Instance->CR |= DMA_IT_HT; } /* Enable the Peripheral */ __HAL_DMA_ENABLE(hdma); } else { /* Process unlocked */ __HAL_UNLOCK(hdma); /* Return error status */ status = HAL_BUSY; } return status; } 在DMA发送中断中加入DMA中断使能即可 HAL_NVIC_SetPriority(DMA2_Stream7_IRQn, 1, 3); HAL_NVIC_EnableIRQ(DMA2_Stream7_IRQn); 直接上代码吧 /* USART1 init function */ static void MX_USART1_UART_Init(uint32_t BaudRate) { huart1.Instance = USART1; huart1.Init.BaudRate = 256000; huart1.Init.WordLength = UART_WORDLENGTH_8B; huart1.Init.StopBits = UART_STOPBITS_1; huart1.Init.Parity = UART_PARITY_NONE; huart1.Init.Mode = UART_MODE_TX_RX; huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE; huart1.Init.OverSampling = UART_OVERSAMPLING_16; if (HAL_UART_Init(&huart1) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } } void HAL_UART_MspInit(UART_HandleTypeDef* huart) { GPIO_InitTypeDef GPIO_InitStruct; if(huart->Instance==USART1) { /* USER CODE BEGIN USART1_MspInit 0 */ /* USER CODE END USART1_MspInit 0 */ /* Peripheral clock enable */ __HAL_RCC_USART1_CLK_ENABLE(); /**USART1 GPIO Configuration PA9 ------> USART1_TX PA10 ------> USART1_RX */ GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF7_USART1; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* USART1 DMA Init */ /* USART1_RX Init */ hdma_usart1_rx.Instance = DMA2_Stream2; hdma_usart1_rx.Init.Channel = DMA_CHANNEL_4; hdma_usart1_rx.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_usart1_rx.Init.PeriphInc = DMA_PINC_DISABLE; hdma_usart1_rx.Init.MemInc = DMA_MINC_ENABLE; hdma_usart1_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE; hdma_usart1_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE; hdma_usart1_rx.Init.Mode = DMA_NORMAL; hdma_usart1_rx.Init.Priority = DMA_PRIORITY_VERY_HIGH; hdma_usart1_rx.Init.FIFOMode = DMA_FIFOMODE_DISABLE; if (HAL_DMA_Init(&hdma_usart1_rx) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } __HAL_LINKDMA(huart,hdmarx,hdma_usart1_rx); /* USART1_TX Init */ hdma_usart1_tx.Instance = DMA2_Stream7; hdma_usart1_tx.Init.Channel = DMA_CHANNEL_4; hdma_usart1_tx.Init.Direction = DMA_MEMORY_TO_PERIPH; hdma_usart1_tx.Init.PeriphInc = DMA_PINC_DISABLE; hdma_usart1_tx.Init.MemInc = DMA_MINC_ENABLE; hdma_usart1_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE; hdma_usart1_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE; hdma_usart1_tx.Init.Mode = DMA_NORMAL; hdma_usart1_tx.Init.Priority = DMA_PRIORITY_HIGH; hdma_usart1_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE; if (HAL_DMA_Init(&hdma_usart1_tx) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } __HAL_LINKDMA(huart,hdmatx,hdma_usart1_tx); /* USART1 interrupt Init */ HAL_NVIC_SetPriority(USART1_IRQn, 1, 3); HAL_NVIC_EnableIRQ(USART1_IRQn); HAL_NVIC_SetPriority(DMA2_Stream7_IRQn, 1, 3); HAL_NVIC_EnableIRQ(DMA2_Stream7_IRQn); /* USER CODE BEGIN USART1_MspInit 1 */ /* USER CODE END USART1_MspInit 1 */ } } //不使用DMA发送 int fputc(int ch,FILE *f) { while((USART1->SR & 0x40) == 0); USART1->DR = (uint8_t)ch; return ch; } //使用DMA发送 void myprintf(UART_HandleTypeDef *huart, char *fmt,...){ char buffer[CMD_BUF_LEN-1]; uint8_t len=0; va_list arg_ptr; va_start(arg_ptr, fmt); len = vsnprintf(buffer, CMD_BUF_LEN+1, fmt, arg_ptr); //HAL_UART_Transmit(huart, (uint8_t*)buffer, len, 1*len); while(HAL_BUSY == HAL_UART_Transmit_DMA(huart, (uint8_t*)buffer, len)); va_end(arg_ptr); } //测试函数 //不使用DMA发送 printf( "system config completen"); printf( "system config complete2nnn"); //使用DMA发送 myprintf(&huart1, "hello stm32n"); myprintf(&huart1, "hello stm32 next1n"); myprintf(&huart1, "hello stm32 next2n"); myprintf(&huart1, "hello stm32 next3n"); myprintf(&huart1, "hello stm32 next4n"); myprintf(&huart1, "hello stm32 next5n"); myprintf(&huart1, "hello stm32 next6n"); 测试结果: |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4138 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2752 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14980 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3086浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1896浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2066浏览 3评论
1979浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2168浏览 3评论
/9
GMT+8, 2025-12-2 09:22 , Processed in 0.620797 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1004
