扫一扫,分享给好友
stm32前面三个串口名均为:USART+串口号(USART1,USART2,USART3)
第四第五位:UART+串口号(UART4,UART5) 相比前面少了个S,如果添加后不成功可以考虑是不是函数名出错; 下面位串口四的添加代码: void USART4_Init(u32 bound) //初始化 { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE); //USART4时钟设置 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); USART_DeInit(UART4); //复位串口3 //USART4_TX PC.10 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化PC10 //USART4_RX PC.11 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入 GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化PC11 //USART4初始化 USART_InitStructure.USART_BaudRate = bound; //一般为9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b;//8位数据位 USART_InitStructure.USART_StopBits = USART_StopBits_1;//1位停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式 USART_Init(UART4, &USART_InitStructure); //初始化串口 //Usart4 NVIC 配置 NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;//抢占优先级3 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; //子优先级3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 USART_ITConfig(UART4, USART_IT_RXNE, ENABLE);//开启中断 USART_Cmd(UART4, ENABLE); //使能串口 USART_ClearFlag(UART4, USART_FLAG_TXE); /* 清发送完成标志,Transmission Complete flag */ } void UART4_Send_Byte(u8 Data) //发送一个字节; { USART_SendData(UART4,Data); while( USART_GetFlagStatus(UART4, USART_FLAG_TC) == RESET ); } void UART4_IRQHandler(void) //中断接收处理函数; { u8 res; if(USART_GetITStatus(UART4,USART_IT_RXNE)!=RESET) { USART_ClearITPendingBit(UART4,USART_IT_RXNE); res=USART_ReceiveData(UART4); //printf("**************************n"); LED1 = ~LED1; TJC_RxFunction(res); } } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1780 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1621 浏览 1 评论
1081 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
728 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1679 浏览 2 评论
1938浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
731浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
570浏览 3评论
596浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
556浏览 3评论
GMT+8, 2024-12-23 17:27 , Processed in 0.402045 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
