电子发烧友论坛|
1个回答
这部分的启动代码,主要是将堆栈进行初始化,中断向量表以及中断函数进行定义。 这里将启动文件拆分出来进行理解。
Stack_Size EQU 0x00000400 AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE Stack_Size __initial_sp 这里将申请一段栈空间,AREA意思为申请的空间名为STACK,不对其进行初始化,可读可写,以三字节进行偏移,栈大小为 0x400 ; ; ; Heap_Size EQU 0x00000200 AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit PRESERVE8 THUMB 这里将申请一段堆空间,AREA意思为申请的空间名为HEAP,不对其进行初始化,可读可写,以三字节进行偏移,堆空间大小为0x200 ; Vector Table Mapped to Address 0 at Reset AREA RESET, DATA, READONLY EXPORT __Vectors EXPORT __Vectors_End EXPORT __Vectors_Size __Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler DCD NMI_Handler ; NMI Handler DCD HardFault_Handler ; Hard Fault Handler DCD MemManage_Handler ; MPU Fault Handler DCD BusFault_Handler ; Bus Fault Handler DCD UsageFault_Handler ; Usage Fault Handler DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD SVC_Handler ; SVCall Handler DCD DebugMon_Handler ; Debug Monitor Handler DCD 0 ; Reserved DCD PendSV_Handler ; PendSV Handler DCD SysTick_Handler ; SysTick Handler ; External Interrupts DCD WWDG_IRQHandler ; Window WatchDog DCD PVD_IRQHandler ; PVD through EXTI Line detection DCD TAMP_STAMP_IRQHandler ; Tamper and TimeStamps through the EXTI line DCD RTC_WKUP_IRQHandler ; RTC Wakeup through the EXTI line DCD FLASH_IRQHandler ; FLASH DCD RCC_IRQHandler ; RCC DCD EXTI0_IRQHandler ; EXTI Line0 DCD EXTI1_IRQHandler ; EXTI Line1 DCD EXTI2_IRQHandler ; EXTI Line2 DCD EXTI3_IRQHandler ; EXTI Line3 DCD EXTI4_IRQHandler ; EXTI Line4 DCD DMA1_Stream0_IRQHandler ; DMA1 Stream 0 DCD DMA1_Stream1_IRQHandler ; DMA1 Stream 1 DCD DMA1_Stream2_IRQHandler ; DMA1 Stream 2 DCD DMA1_Stream3_IRQHandler ; DMA1 Stream 3 DCD DMA1_Stream4_IRQHandler ; DMA1 Stream 4 DCD DMA1_Stream5_IRQHandler ; DMA1 Stream 5 DCD DMA1_Stream6_IRQHandler ; DMA1 Stream 6 DCD ADC_IRQHandler ; ADC1, ADC2 and ADC3s DCD CAN1_TX_IRQHandler ; CAN1 TX DCD CAN1_RX0_IRQHandler ; CAN1 RX0 DCD CAN1_RX1_IRQHandler ; CAN1 RX1 DCD CAN1_SCE_IRQHandler ; CAN1 SCE DCD EXTI9_5_IRQHandler ; External Line[9:5]s DCD TIM1_BRK_TIM9_IRQHandler ; TIM1 Break and TIM9 DCD TIM1_UP_TIM10_IRQHandler ; TIM1 Update and TIM10 DCD TIM1_TRG_COM_TIM11_IRQHandler ; TIM1 Trigger and Commutation and TIM11 DCD TIM1_CC_IRQHandler ; TIM1 Capture Compare DCD TIM2_IRQHandler ; TIM2 DCD TIM3_IRQHandler ; TIM3 DCD TIM4_IRQHandler ; TIM4 DCD I2C1_EV_IRQHandler ; I2C1 Event DCD I2C1_ER_IRQHandler ; I2C1 Error DCD I2C2_EV_IRQHandler ; I2C2 Event DCD I2C2_ER_IRQHandler ; I2C2 Error DCD SPI1_IRQHandler ; SPI1 DCD SPI2_IRQHandler ; SPI2 DCD USART1_IRQHandler ; USART1 DCD USART2_IRQHandler ; USART2 DCD USART3_IRQHandler ; USART3 DCD EXTI15_10_IRQHandler ; External Line[15:10]s DCD RTC_Alarm_IRQHandler ; RTC Alarm (A and B) through EXTI Line DCD OTG_FS_WKUP_IRQHandler ; USB OTG FS Wakeup through EXTI line DCD TIM8_BRK_TIM12_IRQHandler ; TIM8 Break and TIM12 DCD TIM8_UP_TIM13_IRQHandler ; TIM8 Update and TIM13 DCD TIM8_TRG_COM_TIM14_IRQHandler ; TIM8 Trigger and Commutation and TIM14 DCD TIM8_CC_IRQHandler ; TIM8 Capture Compare DCD DMA1_Stream7_IRQHandler ; DMA1 Stream7 DCD FMC_IRQHandler ; FMC DCD SDIO_IRQHandler ; SDIO DCD TIM5_IRQHandler ; TIM5 DCD SPI3_IRQHandler ; SPI3 DCD UART4_IRQHandler ; UART4 DCD UART5_IRQHandler ; UART5 DCD TIM6_DAC_IRQHandler ; TIM6 and DAC1&2 underrun errors DCD TIM7_IRQHandler ; TIM7 DCD DMA2_Stream0_IRQHandler ; DMA2 Stream 0 DCD DMA2_Stream1_IRQHandler ; DMA2 Stream 1 DCD DMA2_Stream2_IRQHandler ; DMA2 Stream 2 DCD DMA2_Stream3_IRQHandler ; DMA2 Stream 3 DCD DMA2_Stream4_IRQHandler ; DMA2 Stream 4 DCD ETH_IRQHandler ; Ethernet DCD ETH_WKUP_IRQHandler ; Ethernet Wakeup through EXTI line DCD CAN2_TX_IRQHandler ; CAN2 TX DCD CAN2_RX0_IRQHandler ; CAN2 RX0 DCD CAN2_RX1_IRQHandler ; CAN2 RX1 DCD CAN2_SCE_IRQHandler ; CAN2 SCE DCD OTG_FS_IRQHandler ; USB OTG FS DCD DMA2_Stream5_IRQHandler ; DMA2 Stream 5 DCD DMA2_Stream6_IRQHandler ; DMA2 Stream 6 DCD DMA2_Stream7_IRQHandler ; DMA2 Stream 7 DCD USART6_IRQHandler ; USART6 DCD I2C3_EV_IRQHandler ; I2C3 event DCD I2C3_ER_IRQHandler ; I2C3 error DCD OTG_HS_EP1_OUT_IRQHandler ; USB OTG HS End Point 1 Out DCD OTG_HS_EP1_IN_IRQHandler ; USB OTG HS End Point 1 In DCD OTG_HS_WKUP_IRQHandler ; USB OTG HS Wakeup through EXTI DCD OTG_HS_IRQHandler ; USB OTG HS DCD DCMI_IRQHandler ; DCMI DCD 0 ; Reserved DCD HASH_RNG_IRQHandler ; Hash and Rng DCD FPU_IRQHandler ; FPU __Vectors_End __Vectors_Size EQU __Vectors_End - __Vectors AREA |.text|, CODE, READONLY 这里申请一段复位段,用于存放中断向量表, __initial_sp代表栈顶地址 Reset_Handler 为复位中断向量入口地址。 重要: 当程序上电启动的时候,将会从SP堆栈指针将写入__initial_sp的地址,PC程序计数器将获取Reset_Handler 地址,跳转到复位中断函数,程序此时开始运行。 ; Reset handler Reset_Handler PROC EXPORT Reset_Handler [WEAK] IMPORT SystemInit IMPORT __main LDR R0, =SystemInit BLX R0 LDR R0, =__main BX R0 ENDP IMPORT 导入外部函数标识符,LDR将SystemInit地址载入R0,BLX进行跳转至R0处,执行代码,该函数在stm32f4xx.c中进行实现,这样我们也可以看出该文件主要用于系统的初始化,SystemInit函数定义如下: void SystemInit(void) { /* FPU settings ------------------------------------------------------------*/ #if (__FPU_PRESENT == 1) && (__FPU_USED == 1) SCB->CPACR |= ((3UL << 10*2)|(3UL << 11*2)); /* set CP10 and CP11 Full Access */ #endif /* Reset the RCC clock configuration to the default reset state ------------*/ /* Set HSION bit */ RCC->CR |= (uint32_t)0x00000001; /* Reset CFGR register */ RCC->CFGR = 0x00000000; /* Reset HSEON, CSSON and PLLON bits */ RCC->CR &= (uint32_t)0xFEF6FFFF; /* Reset PLLCFGR register */ RCC->PLLCFGR = 0x24003010; /* Reset HSEBYP bit */ RCC->CR &= (uint32_t)0xFFFBFFFF; /* Disable all interrupts */ RCC->CIR = 0x00000000; #if defined (DATA_IN_ExtSRAM) || defined (DATA_IN_ExtSDRAM) SystemInit_ExtMemCtl(); #endif /* DATA_IN_ExtSRAM || DATA_IN_ExtSDRAM */ /* Configure the System clock source, PLL Multiplier and Divider factors, AHB/APBx prescalers and Flash settings ----------------------------------*/ SetSysClock(); /* Configure the Vector Table location add offset address ------------------*/ #ifdef VECT_TAB_SRAM SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */ #else SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */ #endif } 该函数主要对时钟进行了配置,以及一些初始化 配置完之后进入到__main函数,该函数不是main而是编译器所标识的函数,编译器经过一些处理之后,调用用户的main函数,真正地,从汇编进入到C语言的世界 。用户在其中实现自己的用户代码。 除了该复位中断向量之外,STM32还有其他的中断向量,但是并不在启动文件中进行函数的定义,只是将其声明到外部,用户可以在外部用C语言进行定义。这些函数实现位于stm32f4xx_it.c中 ; Dummy Exception Handlers (infinite loops which can be modified) NMI_Handler PROC EXPORT NMI_Handler [WEAK] B . ENDP HardFault_Handler PROC EXPORT HardFault_Handler [WEAK] B . ENDP MemManage_Handler PROC EXPORT MemManage_Handler [WEAK] B . ENDP BusFault_Handler PROC EXPORT BusFault_Handler [WEAK] B . ENDP UsageFault_Handler PROC EXPORT UsageFault_Handler [WEAK] B . ENDP SVC_Handler PROC EXPORT SVC_Handler [WEAK] B . ENDP DebugMon_Handler PROC EXPORT DebugMon_Handler [WEAK] B . ENDP PendSV_Handler PROC EXPORT PendSV_Handler [WEAK] B . ENDP SysTick_Handler PROC EXPORT SysTick_Handler [WEAK] B . ENDP Default_Handler PROC EXPORT WWDG_IRQHandler [WEAK] EXPORT PVD_IRQHandler [WEAK] EXPORT TAMP_STAMP_IRQHandler [WEAK] EXPORT RTC_WKUP_IRQHandler [WEAK] EXPORT FLASH_IRQHandler [WEAK] EXPORT RCC_IRQHandler [WEAK] EXPORT EXTI0_IRQHandler [WEAK] EXPORT EXTI1_IRQHandler [WEAK] EXPORT EXTI2_IRQHandler [WEAK] EXPORT EXTI3_IRQHandler [WEAK] EXPORT EXTI4_IRQHandler [WEAK] EXPORT DMA1_Stream0_IRQHandler [WEAK] EXPORT DMA1_Stream1_IRQHandler [WEAK] EXPORT DMA1_Stream2_IRQHandler [WEAK] EXPORT DMA1_Stream3_IRQHandler [WEAK] EXPORT DMA1_Stream4_IRQHandler [WEAK] EXPORT DMA1_Stream5_IRQHandler [WEAK] EXPORT DMA1_Stream6_IRQHandler [WEAK] EXPORT ADC_IRQHandler [WEAK] EXPORT CAN1_TX_IRQHandler [WEAK] EXPORT CAN1_RX0_IRQHandler [WEAK] EXPORT CAN1_RX1_IRQHandler [WEAK] EXPORT CAN1_SCE_IRQHandler [WEAK] EXPORT EXTI9_5_IRQHandler [WEAK] EXPORT TIM1_BRK_TIM9_IRQHandler [WEAK] EXPORT TIM1_UP_TIM10_IRQHandler [WEAK] EXPORT TIM1_TRG_COM_TIM11_IRQHandler [WEAK] EXPORT TIM1_CC_IRQHandler [WEAK] EXPORT TIM2_IRQHandler [WEAK] EXPORT TIM3_IRQHandler [WEAK] EXPORT TIM4_IRQHandler [WEAK] EXPORT I2C1_EV_IRQHandler [WEAK] EXPORT I2C1_ER_IRQHandler [WEAK] EXPORT I2C2_EV_IRQHandler [WEAK] EXPORT I2C2_ER_IRQHandler [WEAK] EXPORT SPI1_IRQHandler [WEAK] EXPORT SPI2_IRQHandler [WEAK] EXPORT USART1_IRQHandler [WEAK] EXPORT USART2_IRQHandler [WEAK] EXPORT USART3_IRQHandler [WEAK] EXPORT EXTI15_10_IRQHandler [WEAK] EXPORT RTC_Alarm_IRQHandler [WEAK] EXPORT OTG_FS_WKUP_IRQHandler [WEAK] EXPORT TIM8_BRK_TIM12_IRQHandler [WEAK] EXPORT TIM8_UP_TIM13_IRQHandler [WEAK] EXPORT TIM8_TRG_COM_TIM14_IRQHandler [WEAK] EXPORT TIM8_CC_IRQHandler [WEAK] EXPORT DMA1_Stream7_IRQHandler [WEAK] EXPORT FMC_IRQHandler [WEAK] EXPORT SDIO_IRQHandler [WEAK] EXPORT TIM5_IRQHandler [WEAK] EXPORT SPI3_IRQHandler [WEAK] EXPORT UART4_IRQHandler [WEAK] EXPORT UART5_IRQHandler [WEAK] EXPORT TIM6_DAC_IRQHandler [WEAK] EXPORT TIM7_IRQHandler [WEAK] EXPORT DMA2_Stream0_IRQHandler [WEAK] EXPORT DMA2_Stream1_IRQHandler [WEAK] EXPORT DMA2_Stream2_IRQHandler [WEAK] EXPORT DMA2_Stream3_IRQHandler [WEAK] EXPORT DMA2_Stream4_IRQHandler [WEAK] EXPORT ETH_IRQHandler [WEAK] EXPORT ETH_WKUP_IRQHandler [WEAK] EXPORT CAN2_TX_IRQHandler [WEAK] EXPORT CAN2_RX0_IRQHandler [WEAK] EXPORT CAN2_RX1_IRQHandler [WEAK] EXPORT CAN2_SCE_IRQHandler [WEAK] EXPORT OTG_FS_IRQHandler [WEAK] EXPORT DMA2_Stream5_IRQHandler [WEAK] EXPORT DMA2_Stream6_IRQHandler [WEAK] EXPORT DMA2_Stream7_IRQHandler [WEAK] EXPORT USART6_IRQHandler [WEAK] EXPORT I2C3_EV_IRQHandler [WEAK] EXPORT I2C3_ER_IRQHandler [WEAK] EXPORT OTG_HS_EP1_OUT_IRQHandler [WEAK] EXPORT OTG_HS_EP1_IN_IRQHandler [WEAK] EXPORT OTG_HS_WKUP_IRQHandler [WEAK] EXPORT OTG_HS_IRQHandler [WEAK] EXPORT DCMI_IRQHandler [WEAK] EXPORT HASH_RNG_IRQHandler [WEAK] EXPORT FPU_IRQHandler [WEAK] WWDG_IRQHandler PVD_IRQHandler TAMP_STAMP_IRQHandler RTC_WKUP_IRQHandler FLASH_IRQHandler RCC_IRQHandler EXTI0_IRQHandler EXTI1_IRQHandler EXTI2_IRQHandler EXTI3_IRQHandler EXTI4_IRQHandler DMA1_Stream0_IRQHandler DMA1_Stream1_IRQHandler DMA1_Stream2_IRQHandler DMA1_Stream3_IRQHandler DMA1_Stream4_IRQHandler DMA1_Stream5_IRQHandler DMA1_Stream6_IRQHandler ADC_IRQHandler CAN1_TX_IRQHandler CAN1_RX0_IRQHandler CAN1_RX1_IRQHandler CAN1_SCE_IRQHandler EXTI9_5_IRQHandler TIM1_BRK_TIM9_IRQHandler TIM1_UP_TIM10_IRQHandler TIM1_TRG_COM_TIM11_IRQHandler TIM1_CC_IRQHandler TIM2_IRQHandler TIM3_IRQHandler TIM4_IRQHandler I2C1_EV_IRQHandler I2C1_ER_IRQHandler I2C2_EV_IRQHandler I2C2_ER_IRQHandler SPI1_IRQHandler SPI2_IRQHandler USART1_IRQHandler USART2_IRQHandler USART3_IRQHandler EXTI15_10_IRQHandler RTC_Alarm_IRQHandler OTG_FS_WKUP_IRQHandler TIM8_BRK_TIM12_IRQHandler TIM8_UP_TIM13_IRQHandler TIM8_TRG_COM_TIM14_IRQHandler TIM8_CC_IRQHandler DMA1_Stream7_IRQHandler FMC_IRQHandler SDIO_IRQHandler TIM5_IRQHandler SPI3_IRQHandler UART4_IRQHandler UART5_IRQHandler TIM6_DAC_IRQHandler TIM7_IRQHandler DMA2_Stream0_IRQHandler DMA2_Stream1_IRQHandler DMA2_Stream2_IRQHandler DMA2_Stream3_IRQHandler DMA2_Stream4_IRQHandler ETH_IRQHandler ETH_WKUP_IRQHandler CAN2_TX_IRQHandler CAN2_RX0_IRQHandler CAN2_RX1_IRQHandler CAN2_SCE_IRQHandler OTG_FS_IRQHandler DMA2_Stream5_IRQHandler DMA2_Stream6_IRQHandler DMA2_Stream7_IRQHandler USART6_IRQHandler I2C3_EV_IRQHandler I2C3_ER_IRQHandler OTG_HS_EP1_OUT_IRQHandler OTG_HS_EP1_IN_IRQHandler OTG_HS_WKUP_IRQHandler OTG_HS_IRQHandler DCMI_IRQHandler HASH_RNG_IRQHandler FPU_IRQHandler B . ENDP ALIGN stm32f4xx_it.c中的中断函数是空的,中断的优先级为-3到6,其他的由用户要使用时定义 最后,在最开始的时候已经开辟了两个空间-堆和栈,现在对其进行外部声明,对其进行初始化 ;******************************************************************************* ; User Stack and Heap initialization ;******************************************************************************* IF :DEF:__MICROLIB EXPORT __initial_sp EXPORT __heap_base EXPORT __heap_limit ELSE IMPORT __use_two_region_memory EXPORT __user_initial_stackheap __user_initial_stackheap LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR ALIGN ENDIF END ;************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE***** 一般在编译器里有定义__MICROLIB,所以是使用上半部分的地址 总结: 这部分启动代码,主要对将堆栈进行初始化,中断向量表以及中断函数进行定义,进行系统时钟的初始化,进入main函数。 接下来就是分析库函数,对寄存器进行怎样的封装,使我们更加方便的使用STM32芯片 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4138 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3228 浏览 1 评论
2752 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2181 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
14980 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3086浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1896浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2066浏览 3评论
1979浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2168浏览 3评论
/9
GMT+8, 2025-12-2 09:22 , Processed in 0.626485 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3124
